Change in AIM wording concerning procedure turn
Old October 6th 05, 05:09 PM
Mark Hansen
On 10/6/2005 08:23, Ron Garret wrote:
Ron Rosenfeld wrote:
OK, so say you're flying AVX V21 SLI FUL. Fullerton ATIS says the VOR-A
is in use. Then you lose comm. What would you do and why?
Being more familiar with Jepp charts, and having to rely on NACO charts for
that approach, perhaps I am missing some subtlety.
But assuming a non-emergency situation, not getting into the discussion of
what to do at SLI if you're ahead of your ETA, and also assuming IMC, I
would maintain the V21 MEA of 4000' until reaching SLI. At SLI I would
execute a racetrack type procedure turn on the SE side of the final
approach course, descending to 2600'. Passing SLI inbound I would cross
BWALT at or above 1500' and then continue my descent to the MDA and land if
I met the requirements of 91.175 and the runway were clear.
As to why? I would do that because that's how that SIAP is charted
No, it isn't. There is no "racetrack type procedure turn" on the chart.
There is a hold that is part of the missed approach. And if you fly
that hold so as to end up at SLI inbound then you've flown it in the
wrong direction.
I think Ron said he wasn't as familiar with the government charts.
However, if you look at the chart, the procedure turn is indicated
with the Barb, pointing 155 degrees. You can see, also, that if you
use AIBAS IAF, no procedure turn is necessary.
There is no provision I see for descending to the MEA prior to SLI absent
an emergency.
Huh? The MEA is 4000. I think you meant that you see no provision for
descending to 2600 on V21 prior to SLI. And you're right. There isn't
any.
So, once again, what do you do and why?
When you hit the VOR, you turn outbound for the procedure turn, 200
degrees. During the outbound leg (and the procedure turn) you can
begin your descent to 2600'. You should time it such that you are
at 2600' before you get back to the VOR.
Note that you need to remain within 10NM of the VOR during the turn,
so you can go outbound quite a log way (to aid in the descent) before
actually beginning the physical turn.
rg
Mark Hansen, PP-ASEL, Instrument Airplane
Sacramento, CA
Old October 6th 05, 06:51 PM
Ron Garret
wrong direction.
There are two Rons in play here :-) Ron G. (that's me) is looking at a
government chart.
True, but you're not coming from ALBAS. You're coming in on V21. (As
an aside, doesn't it make intuitive sense that, from a TERPS point of
view, if no procedure turn is required from ALBAS that none should be
required coming from V21?)
I presume you mean turn to a 200 heading, not turn 200 degrees. V21 is
on a 202 heading. You would be turning 178 degrees or 182 degrees
depending on which way you made the turn. Now...
Do you really turn to a 200 heading, or do you turn to intercept the SLI
200 radial? Those are not the same maneuver.
Do you turn left or right and why?
At what point are you "established on the outbound leg", when you reach
a 200 heading, or when you are established on the SLI 200 radial?
Finally, suppose you flew this Byzantine procedure... by the time you
got to the actual procedure turn (which, I note in passing, would be
your SECOND course reversal) you would be in almost exactly the same
spot as you were just minutes ago when you were on V21. Why is it safe
to descend now but not then?
rg
Old October 6th 05, 08:32 PM
Mark Hansen
wrong direction.
government chart.
Thanks, but I wasn't confused about that. ;-)
My point was that *if you were using ALBAS*, you would not need the
procedure turn. According to the SIAP, if you're using the VOR as
the IAF, you would need to use the procedure turn.
(As
Victor 21 is not a feeder route for the approach. If it was, it would
be charted as such. So you may be able to argue your point with the
procedure designers...
Yes, you can because I said "Turn, 200 degrees" instead of "turn 200 degrees",
which wouldn't make any sense anyway...
Sorry it wasn't clear.
V21 is
Right, because V21 is not a feeder route...
You intercept the radial, of course...
You turn toward the protected side of the procedure area, which is to
the southeast.
I'll bet you can answer that one yourself ;-)
What is the MEA on the victor airway (I don't have it here...) Something
like 4000'? They aren't going to change the MEA of the airway just to
satisfy an approach (or at least they didn't in this case). So, you'll
be approaching the VOR at 4000' ... much to high to begin the approach.
Now if you look at the feeder route from AIBAS, it has a minimum
altitude of 2600'. This is exactly what you want. If you don't want
to do the PT, use this IAF rather than the VOR.
Note that WILMA requires a PT because it is not aligned within 30
degrees of the FAC...
Now, if they created a fix somewhere out on V21, and wrote a feeder
route from that fix, then you could. Effectively, you've be flying
V21 to the fix, then initiating the SIAP from there. However, they
didn't, so you can't ;-)
That gets in to why the designers set up the approach this way, which
I don't know. As a pilot using the procedure, I need only to interpret
the chart. I don't really have to understand the "whys" behind it.
rg
Sacramento, CA
Old October 7th 05, 06:40 AM
Ron Garret
OK, I'll buy that.
I wonder if Steven P. McNicoll buys it too.
And I wonder what Socal Approach would have to say about it. (I think
I'll go find out. What a great excuse to fly to Catalina!)
rg
Old October 7th 05, 09:04 PM
Steven P. McNicoll
"Ron Garret" wrote in message
OK, I'll buy that.
I'd create a fix on V21 where it crosses V25, I'd call it MCNIC. I'd make
the MEA on V21 between MCNIC and SLI 2600'. I wouldn't show it as a feeder
route, I'd make MCNIC an IAF just like ALBAS.
Old October 14th 05, 12:58 AM
Ron Garret
OK, I'll buy that.
Well, I did this experiment today. Flew VNY-AVX-FUL-VNY. It was a
gorgeous day, though I didn't get to do as much sightseeing as I would
have liked. All those approaches keep you busy!
So coming out of AVX I was cleared V21 SLI Direct, but coming out of AVX
I was immediately put on a 050 vector, which is not actually a vector to
SLI but takes you about 15nm east. So I asked Socal if I lost comm just
then what would he expect me to do? The controller seemed a little
taken aback, as if lost comm. was not something that he ever thought
about, but then improvised that he'd expect me to fly the vector until
abeam SLI, then turn towards SLI. But he added that "no one ever flies
their clearance around here. We always just give out vectors."
So I guess the bottom line is that as a practical matter no one ever
flies a PT in southern california because we always get vectors to final.
rg
Old October 7th 05, 08:37 PM
Steven P. McNicoll
"Mark Hansen" wrote in message
Feeder routes are depicted on SIAPs to designate routes for aircraft to
proceed from the en route structure to the IAF. Charting V21 as a feeder
route would be superfluous as the airway already performs that function.
Note that they did superfluously chart a feeder route from WILMA, that route
is also known as V8. Go figure.
The MEA on V21 southwest of SLI is 4000. One has to wonder why it's that
high near the VOR. It's certainly not required by terrain or obstruction
and the A/FD shows no navaid restrictions that would affect it. V21 crosses
V25 about nine miles southwest of SLI, it seems there could easily be a
named intersection at that point with an MEA change. A MOCA would seem to
be appropriate as well.
There are many examples of routes marked NoPT that are offset by more than
thirty degrees.
Old October 7th 05, 08:55 PM
Ron Garret
In article .net,
thirty degrees.
So what would you do in the situation I described? You're at 4000 feet
on V21 going to FUL. You have not been cleared for the approach or told
to descend when you lose comm. If you go straight in you'll get to FUL
right at your filed ETA.
rg
Old October 7th 05, 10:16 PM
Steven P. McNicoll
I answered that the first time you asked. I'd go straight in on the 020
radial.
Old October 8th 05, 12:16 AM
Ron Garret
In article .net,
radial.
My news server seems to have some lag. I presume this is your answer:
I can't tell if you're being serious or not. As far as I know pilots
can't create fixes, and certainly not while they're in the air.
So let me be clear: if you were actually flying this route and lost comm
you'd start a descent at MCNIC. I think I'd do the same thing. But I
also think I'd technically be in violation of the FARs. Do you agree?
rg
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
