Change in AIM wording concerning procedure turn
Old October 6th 05, 08:30 PM
Ron Garret
In article . net,
"Steven P. McNicoll" wrote:
"Ron Rosenfeld" wrote in message
Where does it state that the determination as to when a course reversal is
necessary is to be made by the pilot?
Where does it state when a course reversal is necessary at all?
By regulation we are required to fly a SIAP as published when it is
necessary, and the SIAP is regulatory by inclusion by reference into 14
CFR 97.
I don't think anybody disputes that, but you're saying we are also required
by regulation to fly a SIAP as published when it is NOT necessary. Yet you
can't cite any regulation that says that.
If the SIAP includes a procedure turn, without qualification as to how one
is approaching that point (i.e. NoPT routings), then it becomes regulatory
by virtue of the above.
Alright, here's a real world example for you. You're flying AWI123 from
KORD to KGRB, Chicago departure puts you in the east departure track on a
360 heading and hands you off to Chicago Center. Around the Kenosha, WI,
area Chicago Center tells you to proceed direct to GRB VORTAC. Down the
road a piece you're handed off to Green Bay approach. At GRB the ILS RWY 36
approach is in use, and the approach controller notices you're present track
will intercept the localizer about fifteen miles from DEPRE, the LOM/IAF.
On initial contact you're told "descend and maintain 3,000 join the runway
36 localizer". About three minutes later you hear the same instruction
issued to EGF456. When you're about five miles from DEPRE the approach
controller says "AWI123 cleared ILS runway three six contact tower one one
eight point seven." When you reach DEPRE will you continue towards the
runway or will you start a procedure turn?
http://www.myairplane.com/databases/...s/00873I36.PDF
I don't think that's a very good example because (one could argue)
you're being radar vectored to the approach, which is specifically cited
in the AIM as one of the situations where a PT is not needed.
rg
Old October 6th 05, 09:50 PM
Steven P. McNicoll
"Ron Garret" wrote in message
You're not being radar vectored to the approach in this example. The last
vector was issued by Chicago departure, Chicago Center then issued direct to
GRB VORTAC. That's the route clearance you're operating on when Green Bay
approach instructs you to join the runway 36 localizer.
Old October 6th 05, 10:15 PM
Ron Garret
In article .net,
Yes, but I would think that the instruction to join the localizer
constitutes a radar vector, notwithstanding the fact that the controller
may or may not have actually voiced the word "vector".
rg
Old October 7th 05, 01:52 AM
Steven P. McNicoll
The instruction to join the localizer does not constitute a radar vector.
If you're being vectored the controller will either assign a magnetic
heading to be flown or tell you to turn some number of degrees left or
right.
Old October 6th 05, 10:12 PM
Ron Rosenfeld
On Thu, 06 Oct 2005 18:06:34 GMT, "Steven P. McNicoll"
If I understand your scenario properly, I have intercepted the FAC about 15
miles South of DEPRE and then turned inbound (to the N, towards DEPRE). I
am at 3000'. At 5 miles from DEPRE I am cleared for the approach. I should
be below the GP at that point so I would just continue along until
intercepting the GP, and then descend into the airport.
The presence of an aircraft behind me is irrelevant.
What is your point?
Old October 6th 05, 11:18 PM
Tim Auckland
On Thu, 06 Oct 2005 17:12:16 -0400, Ron Rosenfeld
What is your point?
Ron,
You've lsot me a bit here. I thought your earlier posts and
references to 97.20 were arguing that a procedure turn is mandatory by
regulation in all cases when it's charted and the standard exceptions
(NoPT, vectors to final, etc.) don't apply.
The standard exceptions don't apply in this scenario proposed by
Steven.
If I misunderstood your earlier posts about 97.20, then perhaps we've
had a similar point of view all along.
I'm intrigued.
Tim.
Old October 7th 05, 04:20 AM
Ron Rosenfeld
What is your point?
Ron,
Steven.
I'm intrigued.
Tim.
As I just wrote to Steve, I would have assumed that ATC was setting this up
as a "radar vectors to final situation" and queried them to ensure there
was no misunderstanding since they did not use the standard verbiage. But
the way I was set up was identical to that used for radar vectors to final.
Old October 7th 05, 01:46 AM
Steven P. McNicoll
15
I
should
What is your point?
Why did you not execute the procedure turn? You've not been vectored to a
final approach course or fix, you're not an a segment marked NoPT, and
you've not been cleared for a timed approach from a holding fix. Is it not
your position that if the procedure has a PT charted it must be flown unless
one of those applies?
Old October 7th 05, 04:14 AM
Ron Rosenfeld
On Fri, 07 Oct 2005 00:46:46 GMT, "Steven P. McNicoll"
15
I
should
What is your point?
I would have assumed this was a "radar vectors to final" situation and
queried ATC to verify, since they didn't use the magic words that I
understand to be necessary for me to assume radar vectors. But ATC has had
me lined up with the FAC for quite some distance; I've been in radar
contact; I've been assigned an appropriate altitude to intercept the GP
from below; I've not crossed any IAF prior to DEPRE.
If that confirmation is not forthcoming, then I would inform ATC that I am
obliged to execute a procedure turn at DEPRE. I would maintain my last
assigned altitude of 3000' until crossing DEPRE.
Old October 7th 05, 04:40 AM
Steven P. McNicoll
news
Why would you have assumed it was a "radar vectors to final" situation if
they didn't use the magic words that you understand to be necessary to
assume radar vectors? You're not being vectored in this situation, that
should be clear.
But ATC has had
The approach controller did nothing to line you up with the FAC. He simply
told you to intercept the FAC as your previous clearance of direct GRB
VORTAC crossed it some fifteen miles from the LOM at a shallow angle.
And when they informed you that you weren't being vectored you'd proceed to
fly the PT turn, which upon completion you'd be in the exact same position.
Of course, that wouldn't happen. Upon informing ATC you felt obligated to
fly the PT they'd vector you out of the way of the following traffic. Then
they'd either vector you back to the FAC, which would prohibit flying the
PT, or send you direct to the IAF so you could happily fly your PT without
endangering anyone else.
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
