It actually happened today!! Vacuum failure in IMC.
Old October 9th 05, 12:05 AM
skym
I don't remember if the a/p was on but I think it was. I know that may
seem weird, but the whole thing was so unexpected (naturally), that I
just focused on acting and my memory is . If it was on, the a/p would
have been on nav mode rather than hdg mode since I had been given a
clearance to a VOR, "then as filed", so I would have dialed in the VOR
freq and set the a/p to it.
Eventually, after getting some no-gyro vectors using the t/c and timed
turns on the compass, and alt instructions, I set up the GPS to CLT and
set the a/p to it. At that point I began to breathe easier.
Old October 11th 05, 01:20 AM
John Doe
"skym" wrote in message
Departed Asheville NC today into IMC enroute to Columbia SC. Well into
IMC and about 6500 MSL the DG started to slowly just start rotating and
the AI started to lean over. Backup vacuum-no help. I couldn't
believe this was happening in IMC; I only fly it about 5% of the time.
Columbia was just a bit above minimums. I was not prepared to try an
ILS with no operative DG, and most of the GPS approaches at CAE want a
WAAS capable GPS, which my G430 isn't.
Bit the bullet and dialed 7700 and declared an emergency. Asheville
approach offered a no-gyro radar directed approach back into AV which I
declined, since the mountainous terrain was not an attractive option in
this situation, at least to me (even though I live in Montana). They
gave me vectors to Charlotte, at my request, since it had similar
weather, but friendlier terrain. As I was descended into CLT I saw a
huge hole and an airport just below. Told CLT approach I saw an
airport and could descend visually to it, and since I seem to have read
somewhere that it is best just to get on the ground ASAP in this type
of situation, said that I just wanted to land there. They gave me the
name and ID of the airport (Shelby NC), and I landed without incident.
Lessons learned:
1. Keep up on your partial panel skills. Do not underestimate the
utility of the turn coordinator (or needle/ball).
2. Carry something to cover the failed instruments; they will distract
you. (Fortunately, I had covers.)
3. An STEC A/P which runs on the TC, rather than the vacuum
instruments, is the way to go.
4. If you have a good a/p and coupled GPS, they can fill in very well.
5. Don't be afraid to declare an emergency, and accept their help.
ATC at CAE, Greer (sp?) approach, and CLT approach were ultra
professional and very helpful.
I'm not a highly experienced instr pilot, but stuck with what I've been
trained to do, kept cool (I hope/think), and "dealt with it".
Now, for the paperwork.
I've dialed 7700 atleast 10 times in the last 2400 hours of flying and after
you've done it once, it's becomes much less of a big deal.
Glad everything worked out for you.
Old October 11th 05, 04:06 AM
Brad Zeigler
after you've done it once, it's becomes much less of a big deal.
You've had an emergency averaging once every 240 hours????
Old October 11th 05, 04:35 PM
Newps
You need a better mechanic.
Old October 12th 05, 12:23 AM
Matt Whiting
Or a better pilot.
Matt
My first in-flight mechanical failure Peter R. Piloting 52 October 5th 04 09:05 PM
TSA requirement of Security Awareness Training dancingstar Piloting 3 October 5th 04 02:17 AM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 08:27 AM
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
