Change in AIM wording concerning procedure turn
Old October 7th 05, 01:33 AM
Steven P. McNicoll
"rps" wrote in message
Steven P. McNicoll said:
"If you begin descent when ten miles from DEPRE you've busted your
altitude. The last instruction was 'descend and maintain 3,000, join the
runway 36 localizer', approach clearance was issued at five miles from
DEPRE."
I thought the last instruction was "AWI123 cleared ILS runway three six
contact tower one one eight point seven." You may not be able to
intercept the glideslope from 3000 (e.g., if the signal is weak there),
which is why I suggest descending.
You might want to read the scenario again. The approach clearance was
issued when the aircraft was five miles from DEPRE, so when you're ten miles
from DEPRE that hasn't happened yet. When ten miles from DEPRE the last
instruction was indeed "descend and maintain 3,000, join the runway 36
localizer". When you're five miles from DEPRE you're about 700' below the
glideslope and less than tem miles from the GS transmitter. The signal is
fine.
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
