Change in AIM wording concerning procedure turn
Old October 7th 05, 09:58 PM
Steven P. McNicoll
"Jose" wrote in message
Ok, now let's change the example a bit.
This time, on initial contact you're told "maintain 5,000 join the runway
36 localizer" Then, five miles from DEPRE the approach controller says
"AWI123 cleared ILS runway three six contact tower one one eight point
seven."
You acknowledge, then lose coms. Dive? PT? Racetrack?
I don't get in that position. When I'm about nine miles from DEPRE, as I'm
about to intercept the GS at 5,000', I ask the controller if I'm cleared for
the approach. He responds, "AWI123 cleared ILS runway 36 approach", and I
start down on the GS. When my comm radios mysteriously fail four miles down
the road while all my other avionics continue operating flawlessly I just
continue on a normal ILS approach and land.
Old October 7th 05, 10:10 PM
Jose
Well, it might not happen that way. When you ask if you're cleared for
the approach, the controller responds "negative, maintain five thousand,
I'll have clearance for you shortly." Then he gets busy. Controllers
get busy sometimes, don't they?
Two minutes later you are at five thousand and five miles from DEPRE,
and get the approach clearance.
Jose
Get high on gasoline: fly an airplane.
Old October 7th 05, 10:27 PM
Steven P. McNicoll
Then I'd have to tell him we either start down now or we'll need vectors for
another shot at it. Why can't he clear me now?
Then he gets busy. Controllers get busy sometimes, don't they?
At GRB? Rarely.
Two minutes later you are at five thousand and five miles from DEPRE, and
No I'm not. I'm either being vectored for another shot at the approach or
I've been cleared for it and have started down on the GS.
Old October 7th 05, 10:47 PM
Jose
Ok, I'll buy that. (I know... generous of me.
I don't know why he can't clear you now. Perhaps there's a departure, a
traffic conflict, a handoff issue, a staffing shortage, or the
controller's pencil rolled behind the console. Whatever it is, it's not
something I'd be questioning him about on the radio.
And despite the relative calmness at GRB, there are places where one
can't get a word in edgewise. I fly in the Northeast, and it is not at
all uncommon, especially at a handoff.
No I'm not [at five thousand and five miles from DEPRE, when you
get the approach clearance]. I'm either being vectored for another shot at
the approach or I've been cleared for it and have started down on the GS.
Suppose, for whatever reason, the controller does not respond when you
tell him "we either start down now or we'll need vectors for another
shot at it". For example, the airplane behind you has a
misunderstanding and goes the wrong way, and needs to be coddled back
into place, and a third aircraft comes into the picture. It's well and
good that you can change the scenario on Usenet, but you can't change it
in the air. It is whatever it is.
In any case, I would conclude (synthesize) from what you have said so
far, that in this case, when you are given the approach clearance at
five thousand feet, five miles from DEPRE, you would refuse the
clearance and request vectors (or perhaps a hold at DEPRE to lose altitude).
But, upon lost com (which could be a problem with ground transmitters,
as well as a hardware issue with the volume control or PTT, I expect
you'd want to get down most expiditiously. (you've been cleared for the
approach)
What I would do is probably enter a descending hold at DEPRE and proceed
inbound from there. One turn ought to get me down to approach altitude.
I suspect you'd do something similar.
Am I right?
Jose
Old October 7th 05, 11:26 PM
Steven P. McNicoll
There may very well be, but they don't point the departures at the arrivals.
a traffic conflict,
That would mean he let somebody cross the FAC just outside the LOM. Why did
he do that?
a handoff issue,
There's nobody to handoff to, only one approach controller between the
Center and the tower.
How can that be? Again, there's only one approach controller between the
Center and the tower and he's already working me.
or the controller's pencil rolled behind the console.
Why does he need a pencil to speak the clearance?
Whatever it is, it's not something I'd be questioning him about on the
radio.
I'm not questioning him, I'm questioning you. It's your scenario.
And despite the relative calmness at GRB, there are places where one can't
get a word in edgewise. I fly in the Northeast, and it is not at all
Yeah, but we're not in the northeast, we're at GRB.
tell him "we either start down now or we'll need vectors for another shot
at it". For example, the airplane behind you has a misunderstanding and
goes the wrong way, and needs to be coddled back into place, and a third
aircraft comes into the picture. It's well and good that you can change
the scenario on Usenet, but you can't change it in the air. It is
whatever it is.
You don't work a stream of traffic from the rear forward, you have to take
care of the guys in front first. If you screw something up in front it's
transmitted and magnified throughout the string.
In any case, I would conclude (synthesize) from what you have said so far,
that in this case, when you are given the approach clearance at five
thousand feet, five miles from DEPRE, you would refuse the clearance and
But, upon lost com (which could be a problem with ground transmitters, as
well as a hardware issue with the volume control or PTT, I expect you'd
approach)
inbound from there. One turn ought to get me down to approach altitude. I
Am I right?
No. There's traffic following me. I'm not turning around.
Old October 7th 05, 11:58 PM
Jose
Ok. He's a new controller and he's nervous. He dropped his pencil
behind the console after wondering if he accidentally may have let
somebody cross the FAC outside the LOM, and he won't issue the clearance
until he knows it's ok. As he reaches down to pick up the pencil he hit
his head just as his boss came in. He really wants to be a lot less
polite to you, but he limits himself to telling you to wait a moment
(while he gets his **** together).
It's my scenario, you can't say "it wouldn't happen" as a response.
In any case, it doesn't matter -why- it happens this way this time - as
the pilot you deal with it or get sent to the back of the line (which
may be the smartest thing to do at this point).
There's always traffic following you. In this case EGF456 is also
cleared for the approach, but he may well be at 2500 feet coming from
the west, or 9000 feet coming from the North. You don't know. He may
well not be "following" you.
Jose
Old October 8th 05, 04:34 PM
Steven P. McNicoll
What's he nervous about?
He dropped his pencil behind the console after wondering if he
accidentally
may have let somebody cross the FAC outside the LOM, and he won't issue
the clearance until he knows it's ok.
Wouldn't a quick look at the radar scope tell him if it's ok?
As he reaches down to pick up the pencil he hit his head just as
his boss came in.
Why didn't he just take another pencil? Why did he hit his head? What does
his boss have to do with any of this?
He really wants to be a lot less polite to you, but he
limits himself to telling you to wait a moment (while he gets his ****
together).
Why does he want to be less polite to me? Is he just antisocial by nature?
Okay, but then my response can be just as unrealistic as your scenario.
the pilot you deal with it or get sent to the back of the line (which may
There's always traffic following you. In this case EGF456 is also cleared
for the approach, but he may well be at 2500 feet coming from the west, or
9000 feet coming from the North. You don't know. He may well not be
"following" you.
But he's been following me all the way from ORD. How can he now be coming
from the west or the north if we departed ORD just three minutes apart? If
he's now coming from the west, how was the GRB controller able to descend
him below the 4000' traffic that's keeping me up at 5,000? If he's coming
from the north, how was the GRB tower controller able to launch that
departure?
Old October 7th 05, 10:34 PM
rps
You'll have to remind the controller if it looks like he or she is so
busy so that you're going to get a slam dunk approach. I think you can
descend in a hold, south of DEPRE, left turns (see earlier posts in
this thread from me) until you intercept the GS. However, I wouldn't
try this if the frequency is busy and you can't tell the controller
what you're up to. If the frequency is so busy, I'd descend no lower
than MSA, follow the LOC and then declare missed above the airport.
Old October 7th 05, 10:44 PM
Steven P. McNicoll
"rps" wrote in message
With EGF456 three minutes behind me? No freakin' way!
Old October 7th 05, 11:49 PM
Jose
EGF456 got the clearance three minutes after you, but you don't know
where he is.
Jose
GPT (Gulfport MS) ILS 14 question A Lieberman Instrument Flight Rules 18 January 30th 05 04:51 PM
Required hold? Nicholas Kliewer Instrument Flight Rules 22 November 14th 04 01:38 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
IFR in the 1930's Rich S. Home Built 43 September 21st 03 01:03 AM
