Cessna nose oleo seals
Old October 8th 05, 01:20 AM
If there is a newer technonogy o-ring that would fix the problem, i
would use it. I've never seen an o-ring policeman.
But is the problem with the oring or the shaft making the o-ring twist?
Quite a few people clean and lube their strut tubes on a regular basis.
It helps the seal keep sealing.
nrp wrote:
I have not experienced or heard of that problem, however in ordinary
industrial hydraulics, I've found that smearing STP on a piston rod
will cut the cyclic operating seal friction in half for several minutes
- even if it is only smeared on the low pressure side of things.
Another possible factor is the surface finish on the O-ring groove and
the groove faces. Too smooth and this might happen.
I'm sure it is not approved, but maybe just assembling the strut with
STP as a prelubricant might help. The "ancient" type rubber is
probably neoprene - which is widely used in industrial applications
today. I doubt the O-ring compound is at fault here.
slow roll in a super decathlon Nobody Aerobatics 4 August 24th 05 02:36 AM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
VW-1 C-121J landing with unlocked nose wheel Mel Davidow LT USNR Ret Military Aviation 1 January 19th 04 05:22 AM
