Yea. it was late when I wrote the email so Amsoil is correct. Ya liked
the way I spelled Valvoline too ?? ha. I agree with you, I was surprised that they admitted to the fact it couldn't carry the break in load of a lightly loaded gear. I fact Crane Cam, MSD, Mallory and other suppliers require one to 'NOT' use synthentic oil during any break in of their parts either..... |
stol wrote:
Yea. it was late when I wrote the email so Amsoil is correct. Ya liked the way I spelled Valvoline too ?? ha. I agree with you, I was surprised that they admitted to the fact it couldn't carry the break in load of a lightly loaded gear. I fact Crane Cam, MSD, Mallory and other suppliers require one to 'NOT' use synthentic oil during any break in of their parts either..... Yes, but typically the reason that synthetics aren't recommended during engine break-in is because they protect the parts too much, not because they protect too little. The parts need to wear in against each other and often synthetics prevent this "normal" wearing in process and thus cause problems later, generally with rings that don't seal well. I'd never use synthetic during initial break-in, but I can't believe it caused the problem you experienced, although, I'll admit to using only Mobil 1. I've never been an AMSOIL fan, but that is based admittedly on the fact that I find their marketing so "over the top" that it causes me to also mistrust anything else they claim. Matt |
A friend works in a refinery and they love synthetic oils in their
units. They used to get 4 years on turbine bearings and are almost upto seven years and still running well. They are hoping to get upto eight years like some of the other area refineries. They swear by synthitic oils. Another thing they do to increase the life of bearing is to prefilter the oils before adding them to gear boxes. |
On 8 Oct 2005 19:59:11 -0700, "Clay"
wrote: A friend works in a refinery and they love synthetic oils in their units. They used to get 4 years on turbine bearings and are almost upto seven years and still running well. They are hoping to get upto eight years like some of the other area refineries. They swear by synthitic oils. Another thing they do to increase the life of bearing is to prefilter the oils before adding them to gear boxes. All turbine oils are synthetics. They are not suitable however to put in a recip. |
There are differences in the synthetics which are used for turbine,
gearbox, recip. engines (2-stroke or 4-stroke) and other mechanical devices. There are differnces in conventional lubricants as well. The proper weight of lubricants should be used in the proper application. One advantage of a synthetic is water does not readily mix with it as it does with conventional oils and is also more heat tollorant. Are you aware there is no cleanliness standard for oil? Ever look at the bottom of an empty oil bottle? Sometimes there is sediment. This is why many industrial plants are using filter carts as part of their preventive maintenance (PM) program. |
Good point Don.
The Purple Heart Registry | Otis Willie | Military Aviation | 1 | March 22nd 04 03:51 AM |
[eBay] 1941 edition Ships of the Royal Navy and more | Ozvortex | Naval Aviation | 0 | November 2nd 03 06:29 AM |
Inspector general backs Purple Heart for pilot's eye damage | Otis Willie | Military Aviation | 0 | October 24th 03 12:58 AM |
The Purple Heart Registry | Otis Willie | Military Aviation | 0 | September 26th 03 04:53 AM |
British Royal Naval Air Service | Mike Yared | Naval Aviation | 3 | September 13th 03 04:50 AM |
