I absolutely HATE electrical issues, and we seem to have another one. My
partner flew from Indianapolis to Dallas (via Oklahoma City) and back over the weekend. Everything was fine on the way there. On the way back he started having avionics probems. It started with the VOR needles twitching and then the 430, fuel totalizer and finally the comms went inop. He noticed that the landing light would not stay on, like there was a short somewhere. We had an issue with the landing light wire shorting out before causing the breaker to not reset. This was fixed last year. He was able to make it back to Indianapolis with no issues as long as he went 2600 rpm and 25 MP. This power MP setting is seems did not cause the issue to occur. When he throttled back to say 2400 squared the problem manifested itself again. So I guess my questions are these: Could a short circuit in the Landing Light circuit cause anything that I described? Has anyone here had an issue like this before? And last but certainly not least do you have any suggestions? Thanks!! Jon Kraus '79 Mooney 201 4443H @ TYQ |
Jon Kraus wrote:
I absolutely HATE electrical issues, and we seem to have another one. My partner flew from Indianapolis to Dallas (via Oklahoma City) and back over the weekend. Everything was fine on the way there. On the way back he started having avionics probems. It started with the VOR needles twitching and then the 430, fuel totalizer and finally the comms went inop. He noticed that the landing light would not stay on, like there was a short somewhere. We had an issue with the landing light wire shorting out before causing the breaker to not reset. This was fixed last year. He was able to make it back to Indianapolis with no issues as long as he went 2600 rpm and 25 MP. This power MP setting is seems did not cause the issue to occur. When he throttled back to say 2400 squared the problem manifested itself again. So I guess my questions are these: Could a short circuit in the Landing Light circuit cause anything that I described? Has anyone here had an issue like this before? And last but certainly not least do you have any suggestions? Maybe a combination of problems. Heavy electrical load, + Alternator not producing enough power. (slipping belt, stuffed alternator, stuffed regulator), + Reduced battery capacity. (age) My $0.02 is that the problem is somewhere in the alternator/belt region. |
MC wrote:
: Maybe a combination of problems. : Heavy electrical load, : + : Alternator not producing enough power. (slipping belt, stuffed : alternator, stuffed regulator), : + : Reduced battery capacity. (age) : My $0.02 is that the problem is somewhere in the alternator/belt region. If the alternator/belt stopped producing power, things wouldn't go out until the battery was dead. From what you describe, the multisystem failure would tend to indicate something in common. Possibly a shared breaker (avionics avionics master), but most likely a single-point, shared ground that's flakey. Most GA aircraft are a multi-layered hodge-podge of crappy electrical wiring. In particular, grounds tend to be wherever the last boob to install it had a pre-cut wire long enough to reach. Having a single-point where everything grounds is a good thing to eliminate ground loops. Gotta make sure that one point is solid, though. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() wrote: From what you describe, the multisystem failure would tend to indicate something in common. Possibly a shared breaker (avionics avionics master), but most likely a single-point, shared ground that's flakey. Most GA aircraft are a multi-layered hodge-podge of crappy electrical wiring. In particular, grounds tend to be wherever the last boob to install it had a pre-cut wire long enough to reach. Having a single-point where everything grounds is a good thing to eliminate ground loops. Gotta make sure that one point is solid, though. Concur. Most likely it's not a short, which would pop a breaker. An intermittent open or high resistance connection would fit the symptoms, and the ground connections are the places to start looking. -- Dan C172RG at BFM |
Try a Bad Circuit breaker or a vibration sensitive contact wire to airframe.
Any where wires go through the airframe check the grommets and wiring for chafing. Michelle Jon Kraus wrote: I absolutely HATE electrical issues, and we seem to have another one. My partner flew from Indianapolis to Dallas (via Oklahoma City) and back over the weekend. Everything was fine on the way there. On the way back he started having avionics probems. It started with the VOR needles twitching and then the 430, fuel totalizer and finally the comms went inop. He noticed that the landing light would not stay on, like there was a short somewhere. We had an issue with the landing light wire shorting out before causing the breaker to not reset. This was fixed last year. He was able to make it back to Indianapolis with no issues as long as he went 2600 rpm and 25 MP. This power MP setting is seems did not cause the issue to occur. When he throttled back to say 2400 squared the problem manifested itself again. So I guess my questions are these: Could a short circuit in the Landing Light circuit cause anything that I described? Has anyone here had an issue like this before? And last but certainly not least do you have any suggestions? Thanks!! Jon Kraus '79 Mooney 201 4443H @ TYQ |
The alternator and battery are working correctly. This seems to be a
short or a ground issue somewhere. Thanks!! JK MC wrote: Jon Kraus wrote: I absolutely HATE electrical issues, and we seem to have another one. My partner flew from Indianapolis to Dallas (via Oklahoma City) and back over the weekend. Everything was fine on the way there. On the way back he started having avionics probems. It started with the VOR needles twitching and then the 430, fuel totalizer and finally the comms went inop. He noticed that the landing light would not stay on, like there was a short somewhere. We had an issue with the landing light wire shorting out before causing the breaker to not reset. This was fixed last year. He was able to make it back to Indianapolis with no issues as long as he went 2600 rpm and 25 MP. This power MP setting is seems did not cause the issue to occur. When he throttled back to say 2400 squared the problem manifested itself again. So I guess my questions are these: Could a short circuit in the Landing Light circuit cause anything that I described? Has anyone here had an issue like this before? And last but certainly not least do you have any suggestions? Maybe a combination of problems. Heavy electrical load, + Alternator not producing enough power. (slipping belt, stuffed alternator, stuffed regulator), + Reduced battery capacity. (age) My $0.02 is that the problem is somewhere in the alternator/belt region. |
The breaker for the landing light is tripping. In a Mooney it is built
in to the switch and the switch will not stay on. I'm thinking that there is a short somewhere but I don't know why that would cause the whole avionics bus to go flakey... Jon Kraus '79 Mooney 201 4443H @ TYQ Dan Luke wrote: wrote: From what you describe, the multisystem failure would tend to indicate something in common. Possibly a shared breaker (avionics avionics master), but most likely a single-point, shared ground that's flakey. Most GA aircraft are a multi-layered hodge-podge of crappy electrical wiring. In particular, grounds tend to be wherever the last boob to install it had a pre-cut wire long enough to reach. Having a single-point where everything grounds is a good thing to eliminate ground loops. Gotta make sure that one point is solid, though. Concur. Most likely it's not a short, which would pop a breaker. An intermittent open or high resistance connection would fit the symptoms, and the ground connections are the places to start looking. |
![]() "Jon Kraus" wrote: The breaker for the landing light is tripping. In a Mooney it is built in to the switch and the switch will not stay on. I'm thinking that there is a short somewhere but I don't know why that would cause the whole avionics bus to go flakey... Ah, that's different. That might account for some crazy symptoms if it's an intermittent, high resistence short to ground. It could be pulling the voltage down enough to make the avionics act up if *they* have a power or ground connection problem. Perhaps a wire is being pinched somewhere, so that changing the rpm causes the airframe to flex enough to affect the short. At least the LL breaker gives you a clue where to start looking. I'd go back to where the bus feeds the LL circuit and disconnect it, then see what happens. I'd also still check all the ground and power bus connections, master switch, etc. for high resistance, as you might have one of those delightful two-headed gremlins. Good luck and keep us posted. -- Dan C-172RG at BFM |
Jon Kraus wrote:
The alternator and battery are working correctly. This seems to be a short or a ground issue somewhere. Thanks!! JK MC wrote: Jon Kraus wrote: I absolutely HATE electrical issues, and we seem to have another one. My partner flew from Indianapolis to Dallas (via Oklahoma City) and back over the weekend. Everything was fine on the way there. On the way back he started having avionics probems. It started with the VOR needles twitching and then the 430, fuel totalizer and finally the comms went inop. He noticed that the landing light would not stay on, like there was a short somewhere. We had an issue with the landing light wire shorting out before causing the breaker to not reset. This was fixed last year. He was able to make it back to Indianapolis with no issues as long as he went 2600 rpm and 25 MP. This power MP setting is seems did not cause the issue to occur. When he throttled back to say 2400 squared the problem manifested itself again. So I guess my questions are these: Could a short circuit in the Landing Light circuit cause anything that I described? Has anyone here had an issue like this before? And last but certainly not least do you have any suggestions? Maybe a combination of problems. Heavy electrical load, + Alternator not producing enough power. (slipping belt, stuffed alternator, stuffed regulator), + Reduced battery capacity. (age) My $0.02 is that the problem is somewhere in the alternator/belt region. The post stated that the problem went away when high engine RPM was used, meaning that the alternator/regulator/battery combination was not producing enough energy to satisfy the load at the lower RPMs. I'm not yet convinced that a ground problem would be overcome by higher RPMs. (unless it's some wierd resonance effect g) Hmm, another though has just occured to me.., what if the battery has a shorted cell ? That scenario would cause low voltage at the battery and the regulator will try to send a *lot* of current into the battery in an effort to get it back to nominal. |
The landing light had a wire shorting to ground causing the breaker to
trip. The avionics issue looks like it was a loose wire to the avionics bus. At least we'll see anyway. Nothing glaringly obvious like the landing light. Jon Kraus '79 Mooney 201 4443H @ TYQ Dan Luke wrote: "Jon Kraus" wrote: The breaker for the landing light is tripping. In a Mooney it is built in to the switch and the switch will not stay on. I'm thinking that there is a short somewhere but I don't know why that would cause the whole avionics bus to go flakey... Ah, that's different. That might account for some crazy symptoms if it's an intermittent, high resistence short to ground. It could be pulling the voltage down enough to make the avionics act up if *they* have a power or ground connection problem. Perhaps a wire is being pinched somewhere, so that changing the rpm causes the airframe to flex enough to affect the short. At least the LL breaker gives you a clue where to start looking. I'd go back to where the bus feeds the LL circuit and disconnect it, then see what happens. I'd also still check all the ground and power bus connections, master switch, etc. for high resistance, as you might have one of those delightful two-headed gremlins. Good luck and keep us posted. |
Tankers and strike packages (Was: EA-18G vs ES-3) | [email protected] | Naval Aviation | 0 | December 9th 04 11:11 AM |
Good Electrical shop in NorCal | Robert M. Gary | Piloting | 3 | May 6th 04 05:21 PM |
Hamas Leader Rantisi Killed by Israeli Strike on Car | Dav1936531 | Military Aviation | 13 | April 21st 04 07:04 PM |
Joint Strike Fighter focus sparks concern | Otis Willie | Military Aviation | 0 | March 19th 04 09:19 PM |
Electrical system for Champ 7DC? | Jimmy Cash | Restoration | 3 | October 25th 03 08:28 PM |
