![]() "Marty" wrote in message ... "SteveT" wrote in message oups.com... Hello All, Perhaps someone hereabouts can settle a discussion I had with a fellow passenger on an airliner the other day: Suppose there's a 747 parked at a gate and they need to taxi it over to a maintenance area. Does it require a licensed pilot to taxi a plane that large (or any plane, for that matter) on the ground? We are stipulating that the plane is not going to take off -- merely drive from one part of the airport to another. Also, if pilots do NOT usually perform this task, then who usually does? Thanks for any info to settle this! No "license" needed to taxi, but when I worked at a small airport, we never started a plane to move it. We used a tug or towbar. Many GA airports use tugs to move the small ones around or simply use a tow bar.As a service, employees of the airport/FBO regularly retrive aircraft from hangers for pilots. They will often refuel and park the aircraft for the pilots upon their return. My guess with airliners it comes down to economics. Just can't see any reason to spool up an airliner just to taxi when there is plenty of tugs and wing walkers around. Starting engines just to taxi an aircraft seems like opening a liability can-o-worms. I have never seen them start up and taxi around seen a few at KPDX moved from place to place with a TUG Steven Rhine CP-ASEL-IA |
![]() NW_PILOT wrote: I have never seen them start up and taxi around seen a few at KPDX moved from place to place with a TUG Depends on the layout of the airport. An airline based here at BIL has the mechanics start one engine of their Beech 1900's to taxi from the gate to the hangar. We would never let them do that amount of repositioning on a taxiway with a tug. |
Touch and Goes versus Full Stop Taxi Backs | Kevin Dunlevy | Piloting | 81 | September 18th 05 09:26 PM |
Sport Pilot license | keepitrunning | Home Built | 48 | July 25th 05 05:21 PM |
Should the USA have a soaring license, not a glider license? | Mark James Boyd | Soaring | 0 | August 6th 04 07:16 PM |
Get your glider license and you can fly the Wright Flyer | Mark James Boyd | Soaring | 0 | December 17th 03 04:46 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
