![]() wrote: From what you describe, the multisystem failure would tend to indicate something in common. Possibly a shared breaker (avionics avionics master), but most likely a single-point, shared ground that's flakey. Most GA aircraft are a multi-layered hodge-podge of crappy electrical wiring. In particular, grounds tend to be wherever the last boob to install it had a pre-cut wire long enough to reach. Having a single-point where everything grounds is a good thing to eliminate ground loops. Gotta make sure that one point is solid, though. Concur. Most likely it's not a short, which would pop a breaker. An intermittent open or high resistance connection would fit the symptoms, and the ground connections are the places to start looking. -- Dan C172RG at BFM |
The breaker for the landing light is tripping. In a Mooney it is built
in to the switch and the switch will not stay on. I'm thinking that there is a short somewhere but I don't know why that would cause the whole avionics bus to go flakey... Jon Kraus '79 Mooney 201 4443H @ TYQ Dan Luke wrote: wrote: From what you describe, the multisystem failure would tend to indicate something in common. Possibly a shared breaker (avionics avionics master), but most likely a single-point, shared ground that's flakey. Most GA aircraft are a multi-layered hodge-podge of crappy electrical wiring. In particular, grounds tend to be wherever the last boob to install it had a pre-cut wire long enough to reach. Having a single-point where everything grounds is a good thing to eliminate ground loops. Gotta make sure that one point is solid, though. Concur. Most likely it's not a short, which would pop a breaker. An intermittent open or high resistance connection would fit the symptoms, and the ground connections are the places to start looking. |
![]() "Jon Kraus" wrote: The breaker for the landing light is tripping. In a Mooney it is built in to the switch and the switch will not stay on. I'm thinking that there is a short somewhere but I don't know why that would cause the whole avionics bus to go flakey... Ah, that's different. That might account for some crazy symptoms if it's an intermittent, high resistence short to ground. It could be pulling the voltage down enough to make the avionics act up if *they* have a power or ground connection problem. Perhaps a wire is being pinched somewhere, so that changing the rpm causes the airframe to flex enough to affect the short. At least the LL breaker gives you a clue where to start looking. I'd go back to where the bus feeds the LL circuit and disconnect it, then see what happens. I'd also still check all the ground and power bus connections, master switch, etc. for high resistance, as you might have one of those delightful two-headed gremlins. Good luck and keep us posted. -- Dan C-172RG at BFM |
The landing light had a wire shorting to ground causing the breaker to
trip. The avionics issue looks like it was a loose wire to the avionics bus. At least we'll see anyway. Nothing glaringly obvious like the landing light. Jon Kraus '79 Mooney 201 4443H @ TYQ Dan Luke wrote: "Jon Kraus" wrote: The breaker for the landing light is tripping. In a Mooney it is built in to the switch and the switch will not stay on. I'm thinking that there is a short somewhere but I don't know why that would cause the whole avionics bus to go flakey... Ah, that's different. That might account for some crazy symptoms if it's an intermittent, high resistence short to ground. It could be pulling the voltage down enough to make the avionics act up if *they* have a power or ground connection problem. Perhaps a wire is being pinched somewhere, so that changing the rpm causes the airframe to flex enough to affect the short. At least the LL breaker gives you a clue where to start looking. I'd go back to where the bus feeds the LL circuit and disconnect it, then see what happens. I'd also still check all the ground and power bus connections, master switch, etc. for high resistance, as you might have one of those delightful two-headed gremlins. Good luck and keep us posted. |
Tankers and strike packages (Was: EA-18G vs ES-3) | [email protected] | Naval Aviation | 0 | December 9th 04 11:11 AM |
Good Electrical shop in NorCal | Robert M. Gary | Piloting | 3 | May 6th 04 05:21 PM |
Hamas Leader Rantisi Killed by Israeli Strike on Car | Dav1936531 | Military Aviation | 13 | April 21st 04 07:04 PM |
Joint Strike Fighter focus sparks concern | Otis Willie | Military Aviation | 0 | March 19th 04 09:19 PM |
Electrical system for Champ 7DC? | Jimmy Cash | Restoration | 3 | October 25th 03 08:28 PM |
