Gas Prices -- Help at last?
Old October 14th 05, 02:37 AM
Matt Barrow
"Mike Rapoport" wrote in message
k.net...
Well, if # of refineries had slipped 55% and total capacity has slipped
10%, that trend is no longer in place.
If the trend continues, in 100 years we will have one refinery. Just how
much can you expand production?
I don't buy the story that capacity has slipped 10%.
Then site some CAPACITY numbers, not OUTPUT numbers.
Do you comprehend the manufacturing process?
Do you comprehend percentage of CAPACITY?
Do you comprehend TRENDLINES?
Geeezz
  #252
Old October 14th 05, 04:14 AM
Roger
On Wed, 12 Oct 2005 17:48:13 -0700, "Matt Barrow"
"Matt Whiting" wrote in message
Sylvain wrote:
Matt Whiting wrote:
anyway. Lines will appear in the very near future, just as rolling
blackouts and brownouts began to appear a few years ago. We are running
out of energy generating capacity,
actually we weren't running out of energy generating capacity,
but the analogy is good since this is another example of
price gouging...
Sorry, but we are running out of electrical generating capacity and
gasoline refining capacity. You don't have to believe it now, but you
will in the not too distant future.
We won't run out and are not RUNNING out; the capacity can't keep up with
demand, and expansion is just about as heavily regulated as the initial
construction.
Ahhh... You just described exactly what he said. We are running out
of generating capacity and refining capacity. He did not say we are
running out of gas or crude.
However, increasing our refining capacity is only going to increase
out dependence on foreign crude. Nothing magical is going to happen
to reduce the average American's use of gas unless forced to do so. So
I don't see alternative energy sources happening, or becoming viably
economical until gas prices are high enough to make them so. So in 20
years we will just be using more gas unless the price gets high enough
to force a change.
I do agree that *rebuilding*, or replacing current refineries with
more efficient ones would be a good way to go, but a buddy of mine who
retired from a refinery told me they basically rebuild them every ten
years through incremental maintenance.
www.rogerhalstead.com
Matt
The other Matt
  #253
Old October 14th 05, 09:04 AM
Matt Barrow
"Roger" wrote in message
construction.
"Running out" to me infers having ZERO capacity; "running short" means not
being able to keep up with demand. That, to me, is a significant difference.
My take on the other Matt is that he means we're losing _all our capacity_.
Correct -- producing enough crude or other supplies is another issue.
Yes, there will; PRICES.No maginc involved, just reality. Prices are the
balance point between supply and demand. There's no thuggery of force
involved. If the utility you get from $4 or $5 a gallon is significant to
you, you use it; if not, you don't. There's always options.
In running my business, fuel for my airplane is worth it, even at $4.00 or
more a gallon. In my case, fuel costs are a tiny portion of running the
business. OTOH, for my private use in my car or PU truck, $2.70 a gallon
gas means I don't make frivolous trips to the store to buy a handful of
goods.
So
to force a change.
Well, I wouldn't use the word "force", but I know what you mean.
Yes, there is much to encourage keeping them as technically "state of the
art" as feasible. As for "rebuilding them every ten years", that sounds
rather hyperbolic.
The issue I'm addressing is that with shale, tar sands and other options
hopefully coming along, we'd not be able to produce what we need. Running
refineries at 95+% of capacity is an invitation to a boondoggle, both
economically and strategically.
About two years ago, the pipeline that supplies Phoenix with gasoline was
broken for about five days. My in-laws described it as "reminiscent of the
1970's waiting in line for gas".
Katrina was another example, but as Mike Rappoport said, it was a 50 year
incidence. And he's right. It should, though, give a clue as to our
vulnerabilities. What if Rita has gone a bit further south and took out
Houston/Galveston? Most of our remaining refineries are in very tenuous
locations.
Hurricane intensities are cyclical, and I don't buy the BS that they have
anything to do with "Global Warming", but more than half (?) of our refining
capacity is in "hurricane alley". It hasn't been a disaster yet, but why
tempt "fate"?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
  #254
Old October 14th 05, 02:34 PM
On Fri, 14 Oct 2005 01:04:37 -0700, "Matt Barrow"
tempt "fate"?
It's true that the number of hurricanes per year appears to vary as a
result of a natural cycle, the reasons for which are not well
understood at this point. There have been years in the past when many
hurricanes developed. However, the intensity of hurricanes is purely
the result of the fuel that feeds them: The warmth of the ocean under
which they develop and travel. Upper level atmospheric pressure also
plays a part, but the biggest factor is the warmth of the ocean. The
warmer the ocean under which the hurricane spawns, the better the
chance it will develop into a strong storm. Katrina is a perfect
example, it reduced in intensity during it's passage over the Florida
penninsula, and then intensified into a category 5 hurricane once it
moved onto the gulf of Mexico where the waters were very warm.
More storms per year are occuring in the last few years and the warmer
oceans are creating storms of high intensity.
That the oceans are warmer than they've ever been in recorded history
is not at question, you only have to look at the temperatures over the
last 100 years or so to see that they've been going up.
Another data point is the melting of most glaciers the world over.
They are melting because the average temperature has increased in the
last several decades. Still another data point is the ocean level is
rising.
That the world is warming is not in question, the numbers are obvious.
What is causing it to warm is still in debate (especially by the Bush
White House), but a great number of scientists feel that man and the
greenhouse gasses he produces is likely the root cause.
Corky Scott
  #255
Old October 14th 05, 03:25 PM
JohnH
Jay Honeck wrote:
Because the price of gas has doubled?
"Everywhere, every day on the radio, television, and in the
newspapers, all I
hear is how the "Record Price of Oil" is killing America.
Yet, strangely, Americans keep driving *more*. And I don't see
anyone flying less."
- you!
Are you being purposefully dense, John, or does it just come
naturally? I'm sure you know that I wrote that in a thread that
pre-dated the incredible run-up in gas prices after Katrina.
Worldwide demand causing a 50% increase in fuel price is met with "stop
whining America", whereas a relatively temporary price spike caused by
hurricanes is solved by quickly building more refineries at any
environmental cost. And you imply I'm dense!
  #257
Old October 14th 05, 05:33 PM
Mike Rapoport
What kind of capacity?
Gasoline? From what type of crude?
Heating Oil/Kerosene/Diesel? from what type of crude?
Cracking capacity?
It is pretty clear that you are totally ignorant of the energy industry and
the whole refining process. The fact that you are even asking the questions
indicates that you don't know where the facts are even located or which
facts are important. You are an employee of a *ucking real estate
developer, what the *uck do you know about petroleum or its refining? How
many oil company CEOs do you talk to in an average month? How long ago did
you see the current commodity price increases coming? How much did you
profit from it? An answer rounded to the nearest $10 million will do.
Mike
MU-2
"Matt Barrow" wrote in message
k.net...
Geeezz
  #258
Old October 14th 05, 05:48 PM
Bob Noel
Newps wrote:
Man couldn't affect the temp of the
globe one way or the other if he set out to do it.
of course global temps can be affected. Pop off a few nukes
and wait.
Bob Noel
no one likes an educated mule
  #259
Old October 14th 05, 05:54 PM
Mike Rapoport
The world is not as simply as you and Barrow want to think it is there are
two issues with changing the rules (any rules) or suspending them.
Everytime you change the rules you advantage or disadvantage those one side
of the time when the rules were changed. If you relax emmissions standards
on Jan 1, you disadvantage the refiner who invested prior to Jan1 and give
his competitors who invest after Jan 1 an advantage. However the real
problem is that pollution is a *real* cost, it isn't something made up by
Democrats. As an example, when coal fired powerplants emit sulpher it forms
sulphuric acit which forms acid rain and this damages everything down wind
both natural and man made. If the powerplant emits more sulpher, then all
metal downwind corrodes faster. It drives up medical costs as more people
have respiratory problems. This is over a huge area, affecting many
thousands or millions of people. Basically allowing that powerplant to
emit more sulpher just transfers cost from the owner of the powerplant to
others downwind. This understates the cost of power and distorts the
market.
Mike
MU-2
"Jay Honeck" wrote in message
news:Bpv3f.435576$_o.30020@attbi_s71...
When you take all the facts together, it seems that refining capacity
over the past 25yrs has been driven by economics not regulation. The
"lack of refining capacity" hysteria is simply the latest thing for
pundits to talk about. The conservatives want to blame the
enviornmentalists and the liberals want to blame the greedy oil
companies. Hopefully the rules will remain unchanged and economics will
continue to drive decision making. Refiners are flush with cash and don't
need taxpayer handouts either directly or indirectly through relaxed
regulation.
I never thought I'd live long enough to hear a free-marketer like Mike
refer to "relaxed regulations" as a "taxpayer handout."
What a bizarre world this has become.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #260
Old October 14th 05, 05:57 PM
On Fri, 14 Oct 2005 10:21:36 -0600, Newps wrote:
Which shows the arrogance of man. I just finsihed reading a book about
the Viking explorers. They settled Iceland and Greenland around the
years 750-1050 AD. The "scientists" say that they were able to stay
there at all is because about the time they got there corresponded to a
global warming cycle that made the glaciers recede, the winters easier
and the summers warmer and longer. About the time they left corresponds
to the "Little Ice Age". The simple fact of the matter is that the
earth cools and warms on its own. Man couldn't affect the temp of the
As far as the global warming trend goes, it doesn't matter whether the
cause is manmade or natural. The point is it's happening.
Greenhouse gasses can be emitted by nature as well as by industry and
auto pollution.
Gas Prices Coming Down Jay Honeck Piloting 15 September 10th 05 03:07 PM
Our local fuel prices just went up again! Peter R. Piloting 17 May 28th 04 06:08 PM
AIRNAV not publishing fuel prices... Victor Owning 77 February 22nd 04 12:02 AM
AIRNAV not publishing fuel prices... Victor Piloting 81 February 22nd 04 12:02 AM
Web site for fuel prices? Frode Berg Owning 3 July 11th 03 02:38 PM
