![]() "Lakeview Bill" wrote No... The magnetic heading of Runway 5 can be any heading between 046 and 054. Actually, it could be 045 to 055. There is a choice of rounding up or down, with a heading ending in "5". -- Jim in NC |
No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and
055 becomes 'runway 6'. "Morgans" wrote in message ... "Lakeview Bill" wrote No... The magnetic heading of Runway 5 can be any heading between 046 and 054. Actually, it could be 045 to 055. There is a choice of rounding up or down, with a heading ending in "5". -- Jim in NC |
![]() "Mike W." wrote No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and 055 becomes 'runway 6'. I'm sure I read a reg quoted earlier in this thread, that you got to choose going up or down, when it was --5. Who posted that? -- Jim in NC |
![]() "Morgans" wrote I'm sure I read a reg quoted earlier in this thread, that you got to choose going up or down, when it was --5. I found it. Quoted in earlier post by Bob Moo ____________________________________ 4-3-6. Use of Runways/Declared Distances a. Runways are identified by numbers which indicate the nearest 10-degree increment of the azimuth of the runway centerline. For example, where the magnetic azimuth is 183 degrees, the runway designation would be 18; for a magnetic azimuth of 87 degrees, the runway designation would be 9. For a magnetic azimuth ending in the number 5, such as 185, the runway designation could be either 18 or 19. Wind direction issued by the tower is also magnetic and wind velocity is in knots. ____________________________________ So if this was a valid quote that Bob pulled up, it would seem to put *that* to rest. As far as the zero in the runway, I know it is not "correct" in the US, but I think it is a shame that we do not follow more of the IACO conventions. Just my opinion, of course. -- Jim in NC |
![]() "Morgans" wrote in message ... I found it. Quoted in earlier post by Bob Moo ____________________________________ 4-3-6. Use of Runways/Declared Distances a. Runways are identified by numbers which indicate the nearest 10-degree increment of the azimuth of the runway centerline. For example, where the magnetic azimuth is 183 degrees, the runway designation would be 18; for a magnetic azimuth of 87 degrees, the runway designation would be 9. For a magnetic azimuth ending in the number 5, such as 185, the runway designation could be either 18 or 19. Wind direction issued by the tower is also magnetic and wind velocity is in knots. ____________________________________ So if this was a valid quote that Bob pulled up, it would seem to put *that* to rest. As far as the zero in the runway, I know it is not "correct" in the US, but I think it is a shame that we do not follow more of the IACO conventions. Just my opinion, of course. Advisory Circular 150/5340-1J STANDARDS FOR AIRPORT MARKINGS MARKINGS FOR PAVED RUNWAYS AND TAXIWAYS. Section 2. Runway Markings. 7. RUNWAY DESIGNATION MARKING. a. Purpose. A runway designation marking identifies a runway by its magnetic azimuth. b. Location. Runway designation markings, as shown in Figures 1 and 2, are located on each end of a runway. c. Color. Runway designation markings are white. It is particularly helpful to pilots if these markings are outlined in black on light colored pavements (see paragraph 4(a)(1)). d. Characteristics. A runway designation marking consists of a number and, on parallel runways, is supplemented with a letter. A single-digit runway designation number is not preceded by a zero. On a single runway, dual parallel runways and triple parallel runways, the designation number is the whole number nearest one-tenth of the magnetic azimuth when viewed from the direction of approach. For example, where the magnetic azimuth is 183 degrees, the runway designation marking would be 18; and for a magnetic azimuth of 87 degrees, the runway designation marking would be 9. For a magnetic azimuth ending in the number "5," such as 185 degrees, the runway designation marking can be either 18 or 19. On four or more parallel runways, one set of adjacent runways is numbered to the nearest one-tenth of the magnetic azimuth and the other set of adjacent runways is numbered to the next nearest one-tenth of the magnetic azimuth. (1) Parallel Runways. In the case of parallel runways, each runway designation number is supplemented by a letter, in the order shown from left to right when viewed from the direction of approach, as shown in the following examples: (i) For two parallel runways having a magnetic azimuth of 182 degrees, the runways would be designated "18L," "18R." (ii) For three parallel runways having a magnetic azimuth of 87 degrees, the runways would be designated "9L," "9C," "9R." (iii) For four parallel runways having a magnetic azimuth of 324 degrees, the runways would be designated "32L," "32R," "33L," "33R." (iv) For five parallel runways having a magnetic azimuth of 138 degrees, the runways would be designated "13L," "13R," "14L," "14C," "14R." (v) For six parallel runways having a magnetic azimuth of 83 degrees, the runways would be designated "8L," "8C," "8R," "9L," "9C," "9R." (vi) For seven parallel runways having a magnetic azimuth of 85 degrees, the runways would be designated "8L," "8C," "8R," "9L," "9C," "9R," "10." (2) There are some cases where parallel runway designation may not be appropriate because of possible pilot confusion with the runway surface or the distance between landing thresholds. For example a turf runway or a visual runway, which is parallel to a higher precedence runway and has a distance between the landing thresholds may have a different runway designation, especially if the paved runway has a paved parallel taxiway. Another example where a parallel runway designation may not be appropriate is a situation where the parallel runways are separated by a large distance with a terminal between them. (3) The size and spacing of the numbers and letters are reduced only when necessary due to space limitations on narrow runways, and should be no closer than 2 feet from the runway edge or side strips if present. The numbers and letters are in the form and proportion shown in Figure 4. |
![]() Morgans wrote: "Mike W." wrote No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and 055 becomes 'runway 6'. I'm sure I read a reg quoted earlier in this thread, that you got to choose going up or down, when it was --5. You would choose the number to which the magnetic variation is taking the runway. For example around the western US you would choose the higher number as if you don't you'll have to renumber the runway that much sooner. |
![]() "Newps" wrote You would choose the number to which the magnetic variation is taking the runway. For example around the western US you would choose the higher number as if you don't you'll have to renumber the runway that much sooner. What??? You don't rename a runway after it has been named. The reg has been quoted. Show me where it says you have to take the movement of magnetic variation into account. -- Jim in NC |
I have seen many runways get renumbered after enough years of slow
change in the mag heading. Daytona Beach is an example that I can quickly remember. Runway 7 used to be runway 6 about 20 years ago. On Sun, 16 Oct 2005 17:11:12 -0400, "Morgans" wrote: "Newps" wrote You would choose the number to which the magnetic variation is taking the runway. For example around the western US you would choose the higher number as if you don't you'll have to renumber the runway that much sooner. What??? You don't rename a runway after it has been named. The reg has been quoted. Show me where it says you have to take the movement of magnetic variation into account. |
![]() "Morgans" wrote in message ... What??? You don't rename a runway after it has been named. The reg has been quoted. Show me where it says you have to take the movement of magnetic variation into account. "On a single runway, dual parallel runways and triple parallel runways, the designation number is the whole number nearest one-tenth of the magnetic azimuth when viewed from the direction of approach." |
Crystal airport (MIC) in Minneapolis area went from runways 4/22 to
6/24 a few years ago. I don't know why so much change though....... |
Pilots | Slick | Piloting | 4 | November 20th 04 11:21 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
