![]() "Steven P. McNicoll" wrote "On a single runway, dual parallel runways and triple parallel runways, the designation number is the whole number nearest one-tenth of the magnetic azimuth when viewed from the direction of approach." Roger that. What was being discussed, was -renaming- a runway, due to the -changing- magnetic variation. -- Jim in NC |
![]() Morgans wrote: "Newps" wrote You would choose the number to which the magnetic variation is taking the runway. For example around the western US you would choose the higher number as if you don't you'll have to renumber the runway that much sooner. What??? You don't rename a runway after it has been named. You most certainly do. Our parallel runways here at BIL were renumbered from 27 R+L to 28 R+L several years ago. They did this at the same time they rotated the VOR for the same reason. Another example is MSP. The parallel runways there were 11/29 until a few years ago when they were renumbered to 12/30 |
On Sun, 16 Oct 2005 15:56:35 -0600, Newps wrote:
Another example is MSP and another one is PHX, IIRC. #m -- Repeat an assertion four times and it becomes a fact. Repeat an assertion four times and it becomes a fact. Repeat an assertion four times and it becomes a fact. Repeat an assertion four times and it becomes a fact. |
![]() "Newps" wrote You most certainly do. Our parallel runways here at BIL were renumbered from 27 R+L to 28 R+L several years ago. They did this at the same time they rotated the VOR for the same reason. Another example is MSP. The parallel runways there were 11/29 until a few years ago when they were renumbered to 12/30 I have never heard of that, before now. I'm sure they must do that to make people keep buying new, up to date charts. g -- Jim in NC |
The thing that causes runways to get renumbered is the fact that the
magnetic variation itself, shifts. It may shift six minutes ( a tenth of a degree ) per year. So after ten years, the local mag. variation may change from 6° W to 7° W . So every few years, runways get assigned new numbers. This gradual shift varies by locality on the globe. Areas that are volcanically active can have huge shifts of 30 minutes or more per year. "Newps" wrote in message news ![]() You would choose the number to which the magnetic variation is taking the runway. For example around the western US you would choose the higher number as if you don't you'll have to renumber the runway that much sooner. |
![]() "Mike W." wrote in message ... No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and 055 becomes 'runway 6'. So why is it correct to round 045 down to 'runway 4' and 055 up to 'runway 6'? |
On Sun, 16 Oct 2005 04:27:48 GMT, "Steven P. McNicoll"
wrote: "Mike W." wrote in message ... No, Bill has this right. If rounded correctly, 045 becomes 'runway 4' and 055 becomes 'runway 6'. So why is it correct to round 045 down to 'runway 4' and 055 up to 'runway 6'? Ah, because the REAL rounding rule, designed so that averages will not become distorted high from rounding 1/2 up, is to round 1/2 to the EVEN number. I know of almost no teacher nor textbook that remembers this, much less why it is so. |
become distorted high from rounding 1/2 up, is to round 1/2 to the EVEN number. I know of almost no teacher nor textbook that remembers this, much less why it is so. That's because it's not so. The standard rounding rule is 5 goes up. The catch is that you ONLY round from the digit after the one you're rounding to. For example, .2447 rounds to .245 or to .24 or to .2 although a common error is to round (to the hundredths) as .25, because the "rounded to the thousanths" version would end in a five. When rounding, always round from the source, not an already adulterated version. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . .. Ah, because the REAL rounding rule, designed so that averages will not become distorted high from rounding 1/2 up, is to round 1/2 to the EVEN number. I know of almost no teacher nor textbook that remembers this, much less why it is so. That's because it's not so. The standard rounding rule is 5 goes up. If you have 0.245, it is 0.24 rounded to hundreths. How is that '5 goes up?' The rounding rules I am talking about are for preventing rounding bias in data. If you took a big pile of numbers, rounded them all up, added them, you would have a value that was way off of the true value of the sum. 0.247 0.25 0.2550.26 is that what you mean? That's exactly what I stated. The catch is that you ONLY round from the digit after the one you're rounding to. For example, .2447 rounds to .245 or to .24 or to .2 although a common error is to round (to the hundredths) as .25, because the "rounded to the thousanths" version would end in a five. When rounding, always round from the source, not an already adulterated version. Jose Yes, you don't round a number, then round it again. "GeorgeB" wrote in message ... If these runways were at the same field, your method would have runway designators that differ by twenty degrees for runways that have a difference in azimuth of only ten degrees. I think I'd round both in the direction that local magnetic variation was moving. Yes, that would be logical. |
If you actually have 0.245, it is 0.25 rounded to hundredths. However, if you actually have 0.2445, you do NOT have .0245 but a hair less than that. In that case, you don't =have= a five to "go up". If you took a big pile of numbers, rounded them all up, added them, you would have a value that was way off of the true value of the sum. True. But you don't round them all =up=. You round them all (to the nearest). Only the ones that are ...5 and up get rounded up. The others get truncated. Including ...0 which gets its zero truncated (leaving the number unchanged). 0.247 - 0.25 0.255 - 0.26 is that what you mean? That's exactly what I stated. This is correct rounding, but it is it what George stated. He stated "round 1/2 to the EVEN number.", which would imply .245 - .26 which is not true. What =is= true is ..245 - .25 ..255 - .26 ..265 - .27 This is not "rounding 1/2 to the even number". Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Pilots | Slick | Piloting | 4 | November 20th 04 11:21 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
