Looking down the road a ways, I would think that you would get more $$ out
of your Baron, should you decide to sell, if it has the factory new engine rather than the rebuild or the repaired case, possibly even more than enough to cover the difference in cost. You've got an expensive airplane and nothing speaks louder to buyers of complex high performance airplanes than logbooks showing that "no expense was spared". I don't think going "factory new" would be a bad move, remember, you also get the full factory warrantee if you do. Jim "f" wrote in message . .. The case is repairable and should be acceptable to Continental. The core deposit is $10,000 on top of the $30K for the engine so you are correct if it is not accepted their will be an additional charge, but I believe that the case charge is $2,500 if the total case is unserviceable. In this case I think they will accept the core. Any thought on new engines? Paul "Jim Burns" wrote in message ... While replacing a cylinder I found a crack (confirmed with Dye Pent) off the #5 cylinder leading up towards the case halves.... The case is repairable, but it seems like a waste to not do the overhaul. So, you're saying the case itself is cracked? If so, the question you must have answered is how much you will get for your core. If "$0.00" is the answer, then you will probably need to look deeper into your checking account or consider the repair more closely. Jim |
My experience and what others tell me is factory new engines last
longer until overhaul. After all, they are NEW. It makes a difference. Ideally it shouldn't, but it does. |
![]() Doug wrote: My experience and what others tell me is factory new engines last longer until overhaul. After all, they are NEW. It makes a difference. Ideally it shouldn't, but it does. Perhaps with Lycoming. I wouldn't want a factory new Continental because that means Continental cylinders. |
![]() "Newps" wrote in message ... Doug wrote: My experience and what others tell me is factory new engines last longer until overhaul. After all, they are NEW. It makes a difference. Ideally it shouldn't, but it does. Perhaps with Lycoming. I wouldn't want a factory new Continental because that means Continental cylinders. Nor Lycoming crankshafts. I'll take an old Conti with ECI or Superior cylinders any day. |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
