Transponder
Old October 17th 05, 04:58 AM
Jimmy
Default Transponder
My King KT-76A transponder has a stuck "Ident" button.
It stuck when activated for ATC on the last flight and the button appears
to
have colapsed sideways underneath the cover panel. It is no longer visible
in the opening now. ATC says the unit indicates an "Indent" signal
presently.
Does this require an avionics shop to repair or could it be a simple
matter
such as removing the unit, then remove the cover plate and look for a
colapsed return spring?
Thanks,
Tom
If you have any skills with a phillips head screw driver, yank it out and
try to fix it yourself.
Old October 17th 05, 10:47 AM
Dale Scroggins
Default Transponder
to
presently.
matter
Thanks,
Tom
Opening the case (by removing the faceplate) generally can only be done
legally by an appropriately rated repair station. From the OP's
description, he may have some damaged parts. Taking the front end of
some transponders apart can be pretty involved.
But, what the heck. The OP may not get caught. And he may not break
anything. And he may find the part he needs from some scrap
transponder. Rules and regulations only need be followed if it's not
too much expense or trouble, right?
Old October 17th 05, 01:20 PM
Michelle P
Default Transponder
Anybody can legally disassemble anything aviation that they like. It is
the assembly that requires a license or certification.
Michelle (A&P, ATP)
appears
to
visible
presently.
matter
Thanks,
Tom
and
done legally by an appropriately rated repair station. From the OP's
Old October 17th 05, 02:28 PM
Default Transponder
Michelle (A&P, ATP)
I presume that is tongue-in-cheek. If I were to tear down an engine without
you being around wouldn't your certification of the reassembly require a
whole lot more work to do it correctly?
Old October 18th 05, 12:10 AM
Michelle P
Default Transponder
Tim,
I was serious. I did not say it made any sense. It is just reality. Yes
it would take longer but It would cost you more in the long run.
Michelle
Michelle (A&P, ATP)
Old October 17th 05, 02:26 PM
Default Transponder
That seems to sum it up. Scrimp/cheat on the maintenance so you can affor $4.00
fuel.
Old October 17th 05, 06:11 PM
Victor J. Osborne, Jr.
Default Transponder
$4.00 w/b a blessing. $5 is the norm around TN
Victor J. (Jim) Osborne, Jr.
wrote
Scrimp/cheat on the maintenance so you can afford $4.00 fuel.
Old October 17th 05, 08:26 PM
Default Transponder
I stand corrected. Seems like light aircraft flying is becoming a rich
person's hobby, like so many things in this country.
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
Transponder petition Ian Cant Soaring 11 February 28th 04 06:38 AM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
