So, Sunday morning I got back to the airport, hung that remaining hose,
flew the plane (cool day) and so far no oil leak (jury still out at this point)... But at least the engine compartment looks good with all the scrubbing and the flashy new hoses.. Great story, Denny. Hope it works out for you. I've had a minor oil drip for months, and it's been driving me NUTS. Nothing seems to be leaking, everything is tight, yet after a couple of flights the bottom of the engine is oily. It's been impossible to locate the source, since the airflow just blows it all over the friggin' place, evenly coating the underside of the engine with an oily sheen. (At least we know we'll never have to worry about corrosion...) Even though we all know that a little oil looks like a LOT Of oil, it's still the kind of thing that bugs you when you open the hangar door and find a drip on the floor. The greybeards at the airport think I'm just stupidly anal ("Hell, if ain't drippin', it ain't an airplane!") -- but I believe in finding the root cause BEFORE it becomes a problem. -- Jay Honeck Iowa City, IA Pathfinder N56993 www. AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
I've had a minor oil drip for months, and it's been driving me NUTS. Back in the stone age, auto mechanics used to have a flourescent oil that could be added to the engine oil. Then a blacklight was used to pinpoint the leak. If it's really driving you nuts, you might run this by your A&P. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
Ummm, yup... Your local NAPA store has it on the shelf, it's called
engine dye... Got, it, put it in, fired up the UV light and discovered everything on the engine glows in UV, especially gaskets... Then I wandered over to the starboard engine and discovered that dip stick glows also... Turns out theAv oil I'm using is fluorescent without the dye... Back to square one... denny |
Which Avoil are you useing? I'd be interested in trying the UV trick after
washing down the engine and running it up. Jim "Denny" wrote in message oups.com... Ummm, yup... Your local NAPA store has it on the shelf, it's called engine dye... Got, it, put it in, fired up the UV light and discovered everything on the engine glows in UV, especially gaskets... Then I wandered over to the starboard engine and discovered that dip stick glows also... Turns out theAv oil I'm using is fluorescent without the dye... Back to square one... denny |
On 17 Oct 2005 10:21:28 -0700, "Denny" wrote:
Ummm, yup... Your local NAPA store has it on the shelf, it's called engine dye... Got, it, put it in, fired up the UV light and discovered everything on the engine glows in UV, especially gaskets... Then I wandered over to the starboard engine and discovered that dip stick glows also... Turns out theAv oil I'm using is fluorescent without the dye... Back to square one... When the oil fluoresces (sp?) without the dye you need to do a good high-flash solvent wash job on the engine when it's hot, then grab a fire extinguisher, drag the thing outside and dump a gallon of anhydrous isopropyl into your solvent sprayer and repeat. I'm sure I'm not telling you anything you don't know-but Apache cowls SUCK r/r-wise. Mr. Burns just doesn't have enuff practice with his Aztec cowls yet. Had a 450 Pratt giving me fits year ago. Dug out the Zyglo light and dumped in the dye. Idle to operating oil temp (if the oil ain't hot, the oil in the tank doesn't circulate), high power for 15 minutes, 5 minute cool down-no joy-zip, zilch, nada. High power for 30 minutes, 5 minute cool down-zip, zilch, nada. Grabbed a pilot that was handy (still have never mastered a twin-engine w/conventional gear) went around the patch ONCE. Grabbed the light, stuck it in the cowl-the entire engine was glowing. Don't remember what was found to be the culprit, but the dye sure wasn't the answer on that one. Only nagging leak that I ever found with dye was on a P-baron. Oil was "going away", nothing evident but what looked like normal minor leaks. Repeated the procedure listed above, found nothing. Let them fly it on a trip, drug out the light found visible dye on the trailing edge of the flap. Compressions were perfect. Hmm. Yanked three jugs and had 'em re-worked w/new rings, oil consumption cut by one half, yanked the other three, oil consumption back to normal. The oil film on the flap was not visible with out the black light. Would never had believed it was blowing by without the dye. Was one of my first experiences with operation at altitude causing heavier breathing out the breather. Have found most of my nagging oil leaks by using solvent/alcohol spray and generic aerosol foot powder. Just make sure you solvent spray the foot powder off after you find the leak, for all I know the stuff is corrosive. BTW, just how old were those oil lines? TC |
SUCK r/r-wise. Mr. Burns just doesn't have enuff practice with his Aztec cowls yet. TC, are you telling me that the Apache cowls are worse than the Aztecs? You're right, we don't have much practice with ours yet (knock on wood). We've only had the bottoms off once so far, but it was quite and experience. I know enough to be the "screw driver/feed it into place man" and not the "flat on my back holding it up with two arms, one knee and the opposite foot/can't do crap from down here man"! ![]() Denny, more like 40 minutes off and an hour on for EACH of them, but it was our first time and we definitely learned how they fit up into the fairings! sheesh! Jim |
On Mon, 17 Oct 2005 19:37:55 -0700, "Jim Burns"
wrote: I'm sure I'm not telling you anything you don't know-but Apache cowls SUCK r/r-wise. Mr. Burns just doesn't have enuff practice with his Aztec cowls yet. TC, are you telling me that the Apache cowls are worse than the Aztecs? You're right, we don't have much practice with ours yet (knock on wood). We've only had the bottoms off once so far, but it was quite and experience. I know enough to be the "screw driver/feed it into place man" and not the "flat on my back holding it up with two arms, one knee and the opposite foot/can't do crap from down here man"! ![]() Denny, more like 40 minutes off and an hour on for EACH of them, but it was our first time and we definitely learned how they fit up into the fairings! sheesh! Yes, they are worse. Oldest Aztruck I ever worked on was late 60's, not entirely sure if it is identical to yours. Figured out a long time ago to inspect all nutplates-especially the little #6 nutplates on the bottom cowl-EVERY TIME the cowls are off, spray a dab of LPS2 (or equivalent) into 'em, plus use brand new structural stainless screws (and a screwdriver that fits properly) to put the inside-the-wheelwell crap back together. You are talking about maybe two bucks worth of screws to save a crapload of aggravation. Stick a body inboard and somebody outboard, feed the side channels onto the stub mounting brackets sticking out of the firewall-making sure that the bottom angles at the 'well are outside of the 'well tin. Use a short tapered punch in the aft hole, stick a screw in the front hole, snug it up, poke the screws into the aft holes-the cowl will stay in place now while you line everything else up. Grab a creeper, stick a screw into each "tail" sticking out aft on the bottom, work your way up the sides of the firewall-using your foot to apply a mild correction as needed. Screws inside the 'well are next. Depending how clapped-out your cowls are, sometimes you need to leave everything snug (as opposed to tight) until all the puzzle pieces are in place (less the fillet fairings) until the cheeks are snapped on before tightening everything completely. Just remember to pop the cheeks back off to tighten the flush-heads under them FWD top & bottom. Nose bowls are next. Two layers of 2 inch masking tape flush with the leading edge of the bottom cowl on the outside. Bowl halves together with the bottom OUTSIDE of the bottom cowl. Top wire in, bowl will stay in place. Baby vise grips on the bottom wire, line up the halves, use the grips to slide the bottom #!!$$!! wire in. Carefully tip the bowl aft at the top, fwd at the bottom 'til it slips fwd & inside of the bottom cowl. The rest is pretty straight forward-but again, you do not want to get the thing 75% assembled before you realize that you've got a missing or boogered-up nutplate. Random Aztruck thought-if you've got cowl flap stops that are long screws threaded through a funky lock nut/L bracket riveted to the firewall look and see if someone has threaded a plain nut up under the locknut. If you put a plain nut on as a jam nut, it helps keep the funky lock nut from shaking loose where it's squeezed into the little L bracket. Can't help you with the springie-thingie on the exhaust. TC |
I'm glad I only have a 172M. Cowl is off and back on in 10 minutes
total. |
![]() wrote in message ... On Mon, 17 Oct 2005 19:37:55 -0700, "Jim Burns" wrote: I'm sure I'm not telling you anything you don't know-but Apache cowls SUCK r/r-wise. Mr. Burns just doesn't have enuff practice with his Aztec cowls yet. TC, are you telling me that the Apache cowls are worse than the Aztecs? You're right, we don't have much practice with ours yet (knock on wood). We've only had the bottoms off once so far, but it was quite and experience. I know enough to be the "screw driver/feed it into place man" and not the "flat on my back holding it up with two arms, one knee and the opposite foot/can't do crap from down here man"! ![]() Denny, more like 40 minutes off and an hour on for EACH of them, but it was our first time and we definitely learned how they fit up into the fairings! sheesh! Yes, they are worse. Oldest Aztruck I ever worked on was late 60's, not entirely sure if it is identical to yours. Figured out a long time ago to inspect all nutplates-especially the little #6 nutplates on the bottom cowl-EVERY TIME the cowls are off, spray a dab of LPS2 (or equivalent) into 'em, plus use brand new structural stainless screws (and a screwdriver that fits properly) to put the inside-the-wheelwell crap back together. You are talking about maybe two bucks worth of screws to save a crapload of aggravation. Stick a body inboard and somebody outboard, feed the side channels onto the stub mounting brackets sticking out of the firewall-making sure that the bottom angles at the 'well are outside of the 'well tin. Use a short tapered punch in the aft hole, stick a screw in the front hole, snug it up, poke the screws into the aft holes-the cowl will stay in place now while you line everything else up. Grab a creeper, stick a screw into each "tail" sticking out aft on the bottom, work your way up the sides of the firewall-using your foot to apply a mild correction as needed. Screws inside the 'well are next. Depending how clapped-out your cowls are, sometimes you need to leave everything snug (as opposed to tight) until all the puzzle pieces are in place (less the fillet fairings) until the cheeks are snapped on before tightening everything completely. Just remember to pop the cheeks back off to tighten the flush-heads under them FWD top & bottom. Nose bowls are next. Two layers of 2 inch masking tape flush with the leading edge of the bottom cowl on the outside. Bowl halves together with the bottom OUTSIDE of the bottom cowl. Top wire in, bowl will stay in place. Baby vise grips on the bottom wire, line up the halves, use the grips to slide the bottom #!!$$!! wire in. Carefully tip the bowl aft at the top, fwd at the bottom 'til it slips fwd & inside of the bottom cowl. The rest is pretty straight forward-but again, you do not want to get the thing 75% assembled before you realize that you've got a missing or boogered-up nutplate. Random Aztruck thought-if you've got cowl flap stops that are long screws threaded through a funky lock nut/L bracket riveted to the firewall look and see if someone has threaded a plain nut up under the locknut. If you put a plain nut on as a jam nut, it helps keep the funky lock nut from shaking loose where it's squeezed into the little L bracket. Can't help you with the springie-thingie on the exhaust. TC An annual on my lil old Cessna is less complicated. |
Thanks again TC!
Oldest Aztruck I ever worked on was late 60's, not entirely sure if it is identical to yours. Yep, C's and D's are the same. They cover the last 1/2 of the 60's. Figured out a long time ago to inspect all nutplates-especially the little #6 nutplates on the bottom cowl-EVERY TIME the cowls are off, spray a dab of LPS2 (or equivalent) into 'em, Then just run a tap through them with your finger tips plus use brand new structural stainless screws (and a screwdriver that fits properly) to put the inside-the-wheelwell crap back together. You are talking about maybe two bucks worth of screws to save a crapload of aggravation. Bingo. In fact, I need to order another SS screw kit. Any screw I take out that has the slightest ding or shaved thread goes right in the garbage. (Great step by step directions snipped.... excellent archive material and copied and saved... basically the way we've done it and just about the only way I can imagine doing it.) Nose bowls I've become a pro at and can do them by myself in only a few minutes. Two layers of 2 inch masking tape flush with the leading edge of the bottom cowl on the outside. ??? masking tape? Bowl halves together with the bottom OUTSIDE of the bottom cowl. (or you'll get the bowl "trapped" on the inside of the cowl and won't be able to get the bottom wire in) Hint: coat wire and dab piano hinge with a little Dow DC4, especially the bottom wire because it has complex curves to follow. Also, sharpen the end of the wire to a point, it will you feed it though the piano hinge. Be sure you get the end of the wire past the "hook" and engaged so it won't back out. Top wire in, bowl will stay in place. Baby vise grips on the bottom wire, line up the halves, use the grips to slide the bottom #!!$$!! wire in. Again, coat the wire with DC 4. Clamp the vise grips on the wire so they lay horizontally, rather than vertically because when you get the wire almost all the way in, the space between the bowl and the bottom cowl becomes very narrow. Use your free hand to massage the two halves together while you "screw and push" the wire in with the vise grips. Carefully tip the bowl aft at the top, fwd at the bottom 'til it slips fwd & inside of the bottom cowl. The rest is pretty straight forward-but again, you do not want to get the thing 75% assembled before you realize that you've got a missing or boogered-up nutplate. Random Aztruck thought-if you've got cowl flap stops that are long screws threaded through a funky lock nut/L bracket riveted to the firewall look and see if someone has threaded a plain nut up under the locknut. If you put a plain nut on as a jam nut, it helps keep the funky lock nut from shaking loose where it's squeezed into the little L bracket. Thanks I'll check that. Can't help you with the springie-thingie on the exhaust. $485 new. OR... get 2 pieces of 1/4" x 1/2" aluminum, drill 20 or so holes through them, thread new SS cable through the holes, punch down the edge of the aluminum so the cable can't slip inside the aluminum bars, swage the ends of the cable. 2 hours labor and about $10 in material. Jim |
GPS_LOG WinCE update (version 1.2.2.1) | Henryk Birecki | Soaring | 0 | January 14th 05 05:27 PM |
AD: December 2004 update for London Control now available | ShelleyM | Simulators | 0 | December 15th 04 01:12 PM |
8th Anniversary : Kiwi Aircraft Images Update | Phillip Treweek | Military Aviation | 0 | August 13th 04 01:45 AM |
Anyone know how to update an old Loran database? | Tom Jackson | Owning | 12 | December 5th 03 06:03 PM |
Anyone know how to update an old Loran database? | Tom Jackson | Piloting | 6 | December 3rd 03 02:15 AM |
