![]() "Julian Scarfe" wrote in message ... The "maneuvering speed" placarded in the cockpit is not Va. It is Vo. It is defined by 23.1507 and the placard is mandated by 23.1563. "Vs is a selected speed that is not *greater* than Vsvn". My *s. At or below Vo, the criteria that are generally (and erroneously) thought to apply below Va, do apply, i.e. the wing will stall before the positive limit maneuvering load factor is exceeded. Indeed. Vo was discussed in the thread in rec.aviation.piloting that I referred to earlier. As I understand it, Vo is a more recent certification requirement. Not sure then it came in, but 23.1507 is dated 1993. My 1966 182 doesn't come with a Vo. Certainly, terminology caused a lot of confusion the last time this was discussed, and I expect it will again if the thread continues! -- Dr. Tony Cox Citrus Controls Inc. e-mail: http://CitrusControls.com/ |
... The "maneuvering speed" placarded in the cockpit is not Va. It is Vo. It is defined by 23.1507 and the placard is mandated by 23.1563. "Vs is a selected speed that is not *greater* than Vsvn". My *s. At or below Vo, the criteria that are generally (and erroneously) thought to apply below Va, do apply, i.e. the wing will stall before the positive limit maneuvering load factor is exceeded. "Tony Cox" wrote in message news ![]() Indeed. Vo was discussed in the thread in rec.aviation.piloting that I referred to earlier. As I understand it, Vo is a more recent certification requirement. Not sure then it came in, but 23.1507 is dated 1993. My 1966 182 doesn't come with a Vo. FWIW, here's the extract from AC23-19 (which is entirely consistent with what you've said) --- (c) The design maneuvering speed is a value chosen by the applicant. It may not be less than Vs*sqrt(n) and need not be greater than Vc, but could be greater if the applicant chose the higher value. The loads resulting from full control surface deflections at Va are used to design the empennage and ailerons in 14 CFR part 23, §§ 23.423, 23.441, and 23.455. Va should not be interpreted as a speed that would permit the pilot unrestricted flightcontrol movement without exceeding airplane structural limits nor should it be interpreted as a gust penetration speed. Only if Va = Vs*sqrt(n), will the airplane stall in a nose-up pitching maneuver at, or near, limit load factor. For maneuvers where VaVs*sqrt(n), the pilot would have to check the maneuver; otherwise the airplane would exceed the limit load factor. Amendment 23-45 added the operating maneuvering speed, Vo in § 23.1507. Vo is established not greater than Vs*sqrt(n), and is a speed where the airplane will stall in a nose-up pitching maneuver before exceeding the airplane structural limits. --- Julian Scarfe |
Druine Turbulent | Stealth Pilot | Home Built | 0 | August 30th 04 05:05 PM |
