Aerial photography differs from other types of photography in significant
ways. Without even getting into the question of atmospheric conditions, and the uses of infrared imaging materials, we can say that, generally speaking, aerial photography has a very high information-gathering value. If you're doing pictorial photography on the ground, you may not need or even want very high pixel counts, as this only produces gigantic files, that you then have to reduce to publish on the web, or send as e-mail. In aerial photography though, even if you're doing oblique, pictorial work, you very often want to crop your subject to get to the essential matter. Sometimes, in a plane or helicopter, you cannot get as close as you'd like to your subject, so you end up cropping, sometimes drastically, which of course digital photos cannot support. Now, look at technical applications, such as wildlife, geological and environmental surveys, and it becomes obvious that almost no amount of information could be "too much". For such uses, film is a great medium, because it is fast, and very high resolution. The digital vs film "shootouts" being published today generally concern high-end 6-10MP cameras, compared to 24x36mm film. But most aerial photographers don't use 24x36mm much. The 6x7cm frames that the ultra-famous Arthus-Bertrand (and, I suspect, the contributor of these fantastic London shots) uses have 5X the resolution of "standard" 35mm shots. So, something like 30-50MP equivalent. The 5"x5" format of the K20 camera (the Linhof 45EL being the most recent, and most beautiful iteration of this format) have 17X standard 35mm resolution (100-170MP) and the 9"x9" format still standard for vertical photogrammetry (used by geological survey for map-making) is 60X 35mm resolution, which is getting into the GigaPixel order of magnitude! As an example of file size, when I take 4X5-inch transparencies or negatives to the drum scanner, a 20MB file is considered a low-resolution, "dirty" scan, just to get an idea of what the thing looks like, and is not even scratching the surface of the information available in the 4X5. G Faris |
Greg Farris wrote:
The digital vs film "shootouts" being published today generally concern high-end 6-10MP cameras, compared to 24x36mm film. But most aerial photographers don't use 24x36mm much. The cameras to which I referred are upwards of 12 MP. And, yes, they're being compared to 35mm film. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
Ok, ok, she runs head held under hands away from the weight of
photographic knowledge bearing down...... That is obviously no longer the case, I stand well and truly corrected. Regards |
FAA PPL night flight requirement - does it have to be DUAL? | Peter Clark | Piloting | 21 | January 6th 05 12:38 AM |
Aerial PHotography Flights 'Required' to File Flight Plans | C J Campbell | Piloting | 15 | December 6th 04 02:17 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Night of the bombers - the most daring special mission of Finnishbombers in WW2 | Jukka O. Kauppinen | Military Aviation | 4 | March 22nd 04 11:19 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
