Oil Pressure Gauge Troubleshooting
Old October 18th 05, 12:36 PM
Kyle Boatright
Default Oil Pressure Gauge Troubleshooting
"Kyle Boatright" wrote in message
"Jim Carriere" wrote in message
Kyle Boatright wrote:
I was out flying this evening (Beautiful evening in North Georgia. We
don't get better flying weather than today...) and noticed that my oil
pressure was "stuck" at 100 PSI. I reduced throttle and RPM, no change,
I increased throttle and RPM, again no change. I tapped the face of the
gauge. No change.
Eventually, I shut down the radios and transponder and turned off the
master switch. The OP gauge fell to zero. Back on with the master and
it's 100 PSI again. By the time I returned to my home field, the
pressure gauge seemed to be acting normal again, so I presume it is
going to be an intermittant problem - the absolute worst kind to
diagnose.
Anyway, the gauge and sender are both Rochester brand. Probably 6 years
old (4.5 years flying)with 350 or so tach hours on 'em.
How do I diagnose the problem when it recurrs?
This is a gauge with a remote sender mounted on the engine, right? I ask
that because what you are describing sounds like a wetline gauge with
some air in the line and cold oil.
This is an electronic gauge with a sender mounted on the engine accessory
case.
Correction, this gauge is mounted on the firewall, and has a 12" or so hose
connecting it back to the oil pressure pick-up port on the engine.
KB
Old October 18th 05, 12:37 PM
Kyle Boatright
change, I increased throttle and RPM, again no change. I tapped the
face of the gauge. No change.
diagnose.
ask that because what you are describing sounds like a wetline gauge
with some air in the line and cold oil.
case.
hose connecting it back to the oil pressure pick-up port on the engine.
KB
Man, I can't get things straight this morning. The sender is on the
firewall, fed by the 12" hose.
Sheesh. No wonder I rarely post in the AM.
KB
Old October 18th 05, 04:48 PM
RST Engineering
Yeah, it looks like your snippit button fails at midnight also.
KB
Old October 19th 05, 02:52 AM
Cy Galley
Is the hose clear? Sounds almost like you have a check valve in the line.
Did you make up the hose by putting on ends? If you made the hose or had it
made to length, there is a possibility that a "donut" has been cut out of
the hose side wall making a flapper valve. Happens when someone doesn't use
a mandrel.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
diagnose.
years old (4.5 years flying)with 350 or so tach hours on 'em.
accessory case.
KB
KB
Old October 19th 05, 03:05 AM
Kyle Boatright
"Cy Galley" wrote in message
news:lFh5f.442882$x96.137443@attbi_s72...
it made to length, there is a possibility that a "donut" has been cut out
of the hose side wall making a flapper valve. Happens when someone
doesn't use a mandrel.
Cy Galley - Chair,
EAA Sport Pilot
The hose was from a mail-order racing parts supplier (Summit Racing, IIRC)..
It is one of their stock lengths. No idea if they use mandrels or not.
KB
Old October 19th 05, 04:04 AM
Cy Galley
Remove the hose and see if you can look thru it.
out of the hose side wall making a flapper valve. Happens when someone
Cy Galley - Chair,
EAA Sport Pilot
IIRC).. It is one of their stock lengths. No idea if they use mandrels or
not.
KB
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Manifold pressure gauge problem Dave Russell Aerobatics 3 January 29th 04 03:46 AM
Vaccuum Pressure Gauge Al Owning 4 January 16th 04 05:26 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
