On Tue, 18 Oct 2005 23:29:51 GMT, "Mortimer Schnerd, RN"
wrote: If you look at a performance chart, you'll see that the highest true airspeed for a normally aspirated aircraft is more likely to be around 6000 feet or so. Not at full power. If I look at charts that show a full throttle curve, what I see is that TAS increases up to the maximum altitude that any particular power setting can be achieved; after that it falls. Full power can only be achieved at sea level. At least for a Mooney Ovation 2, for which I happen to have available that type of curve, it is very clear that maximum TAS is achieved at maximum power at SL (about 193KTAS) For 75% power, maximum TAS is achieved at 8000', which is the maximum altitude that one can obtain 75% power (about 190KTAS). Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Ron Rosenfeld wrote:
Full power can only be achieved at sea level. But you can do better than that at places that are below sea level. As long as they aren't actually under water, that is. :-) George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
"George Patterson" wrote in message
news:Pyh5f.2738$fC3.2250@trndny01... Ron Rosenfeld wrote: Full power can only be achieved at sea level. But you can do better than that at places that are below sea level. As long as they aren't actually under water, that is. :-) George Patterson Been there George.... Death Valley in the cold of winter.. BT |
On Wed, 19 Oct 2005 01:45:19 GMT, George Patterson
wrote: Ron Rosenfeld wrote: Full power can only be achieved at sea level. But you can do better than that at places that are below sea level. As long as they aren't actually under water, that is. :-) George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. Well sure, depending on the temperature. You can also achieve the same result at or above sea level with colder than standard temperature conditions. But in my response, I did not consider that a very detailed discussion of the effects of temperature, humidity and altitude on engine performance was going to add much, given the original question. Do you know if the OP's supposition that the highest TAS of a turbo'd a/c is at the critical altitude is correct? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Do you know if the OP's supposition that the highest TAS of a turbo'd a/c is at the critical altitude is correct? The highest TAS of a propeller driven aircraft will occur at the highest altitude at which the power being developed can occur. In other words, if you want to fly at 65% power, fly at the highest altitude at which 65% power can be developed. -- Marc J. Zeitlin http://www.cozybuilders.org/ Copyright (c) 2005 |
On Wed, 19 Oct 2005 03:03:30 GMT, "Marc J. Zeitlin"
wrote: The highest TAS of a propeller driven aircraft will occur at the highest altitude at which the power being developed can occur. In other words, if you want to fly at 65% power, fly at the highest altitude at which 65% power can be developed. That does make intuitive sense. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
altitude at which the power being developed can occur. In other words, if you want to fly at 65% power, fly at the highest altitude at which 65% power can be developed. That makes sense. I actually found an article I'd forgotten about, about turbonormalization at the website I'd linked to earlier which shows it with power curves and other charts. http://www.nar-associates.com/techni...urbo/turbo.pdf |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
