George,
I ran the standard lamp as a taxi on the left and a Quartz for landing in the right aimed further out. Works great. Michelle George Patterson wrote: tony roberts wrote: I recall reading about a landing light bulb that is a lot brighter than the usual ones. They may be talking about the quartz bulb. It's brighter, but it also has a narrower beam. That means you can see things further away, but it doesn't illuminate well to the sides. I had two in my Maule. I would never use them in a tailwheel aircraft again. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
Michelle P wrote:
George, I ran the standard lamp as a taxi on the left and a Quartz for landing in the right aimed further out. Yeah, I ran that way for a while. Put the spare quartz bulb in when the other standard burned out. Big mistake. I'd still stay with the standard on both sides if I had it to do again. I need the light taxiing more than I do on final. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
![]() "George Patterson" wrote in message news:0Hh5f.11384$f02.8291@trndny02... Michelle P wrote: George, I ran the standard lamp as a taxi on the left and a Quartz for landing in the right aimed further out. Yeah, I ran that way for a while. Put the spare quartz bulb in when the other standard burned out. Big mistake. I'd still stay with the standard on both sides if I had it to do again. I need the light taxiing more than I do on final. Why was it a mistake? |
John Clonts wrote:
Why was it a mistake? As is the case with most aircraft, the landing lights are lined up to give good illumination in the direction of flight. When a tailwheel aircraft is on the ground that leaves the lights pointing at the sky. Maule solves this problem by having aluminum mirrors over the lights. These reflect light down onto the taxiway pretty well with the standard bulbs. The narrower beam of the quartz bulbs doesn't hit the mirror. It's almost as bad as not having the lights on at all. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
Wider beam. I do not need to see one spot when taxing I need to see the
taxiway or more. Michelle tony roberts wrote: Hi Michelle Why not Quartz on both? Is incandescent better for taxiing? I would have thought that landing with the taxi and landing light on - both quartz, would have given the most light. Thanks Tony |
Skycraft Landing Light Pix, Part II | Jay Honeck | Owning | 6 | February 6th 05 08:38 PM |
Skycraft Landing Light Installation Pix | Jay Honeck | Owning | 5 | February 6th 05 02:05 PM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
Skycraft Landing Light? | Jay Honeck | Piloting | 8 | May 28th 04 07:23 PM |
Effect of Light Sport on General Aviation | Gilan | Home Built | 17 | September 24th 03 06:11 AM |
