OK not to hijack this thread, but what you and Peter are saying about ELT's
has me confused. I assume the OP is talking about the standard, been-around-for-twenty-years, 121.5 MHz ELT. How in the world would a satellite orbiting thousands of miles above the earth pick up this signal, let along get a fix on it? This is something I have never heard of. "Ron Natalie" wrote in message m... wendy wrote: Pretty much. There are multiple flavors of ELT, but the one most aircraft has is pretty lousy. False activiations and failure to activate are common. These old ELT's take two satellite passes to get any indication and even those position reports are pretty coarse. In fact, the support for satellite detection of these old elt's is scheduled to be pulled in 2009. |
been-around-for-twenty-years, 121.5 MHz ELT. How in the world would a satellite orbiting thousands of miles above the earth pick up this signal, let along get a fix on it? This is something I have never heard of. Not by accident. There are satellites that are designed to (in part) look for such signals. I don't think those satellites are thousands of miles above the earth, only a few hundred miles is needed to get into space. In any case, their receivers are =very= good, and there isn't anything in the way to block the signal. You'd be surprised how far signals (including ordinary acoustic signals like conversation) carry under ideal conditions. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Jose wrote:
I assume the OP is talking about the standard, been-around-for-twenty-years, 121.5 MHz ELT. How in the world would a satellite orbiting thousands of miles above the earth pick up this signal, let along get a fix on it? This is something I have never heard of. Not by accident. There are satellites that are designed to (in part) look for such signals. I don't think those satellites are thousands of miles above the earth, only a few hundred miles is needed to get into space. In any case, their receivers are =very= good, and there isn't anything in the way to block the signal. You'd be surprised how far signals (including ordinary acoustic signals like conversation) carry under ideal conditions. I believe the sats that scan for ELT signals are operated by the Russians. They notify the FAA or somebody in the US when they pick up a signal. I've heard that most ELT signals come from boats rather than airplanes. |
Mike W. wrote:
OK not to hijack this thread, but what you and Peter are saying about ELT's has me confused. I assume the OP is talking about the standard, been-around-for-twenty-years, 121.5 MHz ELT. How in the world would a satellite orbiting thousands of miles above the earth pick up this signal, let along get a fix on it? This is something I have never heard of. dopler effect; the thing goes biiiiip biiiip biip bip then back to biip biiip biiiip again :-) when it is at bip, you mark a line on the map perpendicular to your path; repeat from a few different directions -- these satelites have polar orbits -- and you got a fix. --Sylvain |
I just wrote a little bit hastily:
the thing goes biiiiip biiiip biip bip then back to biip ok, it's a lousy explanation; but Doppler effect it is (with two ps); --Sylvain |
"Sylvain" wrote in message
... I just wrote a little bit hastily: the thing goes biiiiip biiiip biip bip then back to biip ok, it's a lousy explanation; but Doppler effect it is (with two ps); So, it's really that it goes "biiiiipp biiiipp biipp bipp then back to biipp"? Just trying to make sure we've got it straight here. ![]() |
writer needs help | wendy | Piloting | 8 | October 24th 05 01:33 AM |
Col. testifies in air academy rape case, By Jon Sarche, Associated Press Writer | | Otis Willie | Military Aviation | 0 | April 16th 04 11:56 PM |
Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 10:13 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
Jessie cashes in | Cub Driver | Military Aviation | 68 | September 12th 03 04:13 PM |
