How would water sparators work with an 'enormous' quantity of water in
the fuel? Try adding alcohol to absorb the water. |
![]() john smith wrote: How would water sparators work with an 'enormous' quantity of water in the fuel? Try adding alcohol to absorb the water. I wouldn't fly with you. |
the fuel? Try adding alcohol to absorb the water. I wouldn't fly with you. Drain it or ground run it. |
![]() john smith wrote: How would water sparators work with an 'enormous' quantity of water in the fuel? Try adding alcohol to absorb the water. I wouldn't fly with you. Drain it or ground run it. That would be the prudent way of doing it. What works for water-in-fuel in a car is fine for cars.. the engine stops, you roll to the side of the road and call the tow truck. I don't know how the alcohol would affect the seals and whatnot in the tanks/lines/pumps/carb so I'd be hesitant to put anything not specifically approved for use in the plane into the tanks. |
Robert Chambers wrote:
john smith wrote: How would water sparators work with an 'enormous' quantity of water in the fuel? Try adding alcohol to absorb the water. I wouldn't fly with you. Drain it or ground run it. That would be the prudent way of doing it. What works for water-in-fuel in a car is fine for cars.. the engine stops, you roll to the side of the road and call the tow truck. I don't know how the alcohol would affect the seals and whatnot in the tanks/lines/pumps/carb so I'd be hesitant to put anything not specifically approved for use in the plane into the tanks. Right. The FAA limits the percent of alcohol in gasohol which can be used in airplanes. I don't believe any of the auto products are low enough. Draining it is the only way to go and I remember one cold day when I had to drain out about a pint of water (?) from one tank. Even taxiing around isn't good -- how long do you go before you conclude there's no water in the tanks? Do you really want to walk back in the cold from your plane? |
"Stubby" wrote in message ...
.... Draining it is the only way to go and I remember one cold day when I had to drain out about a pint of water (?) from one tank. Even taxiing around isn't good -- how long do you go before you conclude there's no water in the tanks? Do you really want to walk back in the cold from your plane? What I *really* hate is when the quick-drain won't budge, because there's water frozen above it in the sump. |
John R. Copeland wrote:
"Stubby" wrote in message ... .... Draining it is the only way to go and I remember one cold day when I had to drain out about a pint of water (?) from one tank. Even taxiing around isn't good -- how long do you go before you conclude there's no water in the tanks? Do you really want to walk back in the cold from your plane? What I *really* hate is when the quick-drain won't budge, because there's water frozen above it in the sump. It's worse when a little piece of dirt or ice won't let the quick drain to close fully. |
: Right. The FAA limits the percent of alcohol in gasohol which can be
: used in airplanes. Yeah.... 0.0% I don't believe any of the auto products are low : enough. Alcohol can eat rubber seals and such in the Lycontosaurus engines in planes. Also, it can attack the rubber in bladders, or even the aluminum in wet-wing or structural in-wing tanks. The alcohol avgas like EG85 (IIRC) requires new seals all around, and has additives to prevent corrosion. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Is Your Airplane Susceptible To Mis Fu eling? A Simple Test For Fuel Contamination. | Nathan Young | Piloting | 4 | June 14th 04 06:13 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 09:47 PM |
