no way to head south ? it's looking a bit clearer down on the CT
coastline, perhaps you can make a great circle out of it and wind up sneaking back into Rochester from somewhere else. Sucks to have to drive, but better to be on the ground wishing you were up there than vice versa. good luck Robert Paul Tomblin wrote: I'm parked at Barnes Muni (BAF) and I want to be home in ROC. But there is a AIRMET ZULU for ice in the clouds and precipitation above the freezing level, and there are low clouds layered up to the flight levels, and the MEA is above the freezing level. So it looks like we're going to be driving the rental car home, and I'll come back to get the plane in a couple of days when the weather is clear. |
In a previous article, Robert Chambers said:
no way to head south ? it's looking a bit clearer down on the CT coastline, perhaps you can make a great circle out of it and wind up sneaking back into Rochester from somewhere else. The CIP icing models show some high probability over Rochester itself. Being downwind of the lake is nothing but heartache in the cold weather. -- Paul Tomblin http://xcski.com/blogs/pt/ And on the seventh day, He exited from append mode. |
Yeah I was thinking if you could get to Utica or somewhere a bit closer
than BAF. The drive would be shorter if you have to leave the plane there and the drive back to retrieve the bird would be shorter as well. I've been in icing myself exactly twice and that was 2 times more than I needed. Each time it happened we got lower altitude and either a 180 out of it or vectors to an airport. Taking the safest course of action is never a dumb move. Robert Paul Tomblin wrote: In a previous article, Robert Chambers said: no way to head south ? it's looking a bit clearer down on the CT coastline, perhaps you can make a great circle out of it and wind up sneaking back into Rochester from somewhere else. The CIP icing models show some high probability over Rochester itself. Being downwind of the lake is nothing but heartache in the cold weather. |
Yeah I was thinking if you could get to Utica or somewhere a bit closer than BAF. The drive would be shorter if you have to leave the plane there and the drive back to retrieve the bird would be shorter as well. As I was driving out of the parking lot at Barnes, there was a fair chunk of blue sky to the west. I was really tempted to fly west and see how far I could get VFR with maybe a popup IFR clearance for an approach somewhere and rent a car there, and that's what I would have done if I were alone. But my wife doesn't like the uncertainty of not knowing whether we're going to find a rental car or a motel room. On the drive home, we drove through some high hills with low clouds down below the peaks and cold rain, and figured that being in the car was probably the best decision. I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. I might go down on Wednesday and give it a try to see how far I get. -- Paul Tomblin http://xcski.com/blogs/pt/ "Legacy (adj): an uncomplimentary computer-industry epithet that means 'it works'." -- Anthony DeBoer |
On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul
Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Seriously, if the club is second guessing your decision, there's something very wrong with the safety culture there. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
In a previous article, Ron Rosenfeld said:
On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Well, the guy who had it booked for Monday and Tuesday wrote to me that he'd been thinking of cancelling anyway because of the weather, so I feel better about that. This morning I look at the airmets, and there are two of them for icing, with a narrow little corridor between them straight between BAF and ROC. Not sure if I trust that narrow corridor to stay open, though. How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? -- Paul Tomblin http://xcski.com/blogs/pt/ Programmer (n): One who makes the lies the salesman told come true. |
"Paul Tomblin" wrote in message
... How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? Icing is hardly ever as predictable as we'd like but my personal experience is that I've found that the boundaries are usually broader than actual icing conditions, but the accumulation rates can be both more and or less severe than indicated in the airmet because it is also unpredictable and is highly dependent on your speed and time spent in the conditions. I also fly around the great lakes, and downwind from the lake is a great place to find ice building faster than predicted and faster than you can get out of it. Usually when the windward side is CAVU, the lake effect layer on the leeward side isn't very thick, but you sure as hell don't want to be stuck in it very long. If the windward side is IFR and tops into the teens or higher, the lake effect moisture is just added to those conditions on the leeward side, and you've probably lost all your "outs". Stay away... stay far away. I've found that the ADDS forecast has been pretty accurate. If I can get above a potential icing layer that isn't too thick, fly towards warmer conditions and then do a slam dunk down through it into warmer and clear conditions near my destination, I'll give it some serious consideration. If I don't have at least 3 "outs", (altitude, distance, improving weather, higher temps, between layers, ect.) I won't consider it. This weekend in WI was a perfect case of airmets galore, but good planning wouldn't have prevented flying due to ice. Overcast at 2700, clear above 3000.(4000 MSL) light to moderate rime ICIP airmet blanketing the entire state. VFR both south and north of us, surface temps between 40 and 45F. Freezing level 4000 MSL north sloping to 6000 MSL south. ADDS was predicting a 80-90% chance of icing at 6000, nothing at 3000, and nothing at 9000. The "go" decision could be made because the clouds at 2700-3000 AGL were below the freezing level and it was clear above, so the airmet didn't have any weather that it applied to. Be careful when using ADDS that you remember ceilings are AGL, icing predictions are MSL. So, we could have taken off, climbed through the ceiling into clear air. What if we come upon a layer at 6000 where ADDS said 80-90% chance of ice? What are our outs? 1) Climb above it, ADDS predicted 0% at 9000, climb is always my first choice. you can climb before you accumulate ice, you can always go down. 2) descend below it and continue, MEA is 3000 MSL 3) descend through it and land 4) turn around and fly back into clear weather 5) turn 90 degrees to the system and fly around it, this requires knowledge of the area of coverage and conditions surrounding it, plus additional fuel. I hate airmet zulu as well, it always throws the unknown at you. All we can do is explore all our options, set minimal standards, do extra planning, and be willing to stay on the ground. Fly safe. Jim |
On Mon, 24 Oct 2005 11:28:22 +0000 (UTC), (Paul
Tomblin) wrote: In a previous article, Ron Rosenfeld said: On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Well, the guy who had it booked for Monday and Tuesday wrote to me that he'd been thinking of cancelling anyway because of the weather, so I feel better about that. This morning I look at the airmets, and there are two of them for icing, with a narrow little corridor between them straight between BAF and ROC. Not sure if I trust that narrow corridor to stay open, though. How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? I have not looked in detail at weather in the NY area today. However, given the general picture these past few days, I would not fly in a non-deice'd a/c in the clouds higher than the freezing level. There's a lot of moisture in these clouds. An FIP map that I downloaded last night valid at 0900Z showed significant icing probability along your route at 6,000', although it did look doable at 3,000'. I flew today from Eastport to Bangor and back in my non-deiced Mooney. But I stayed at 3,000' and had no ice -- occasional light rain that sure would have been ice had I been above the FL (about 4,000'). Here, with little traffic, there were still scattered reports of icing. One thing that's real important in flying, is to not weigh factors like "so and so has the plane booked for whenever so I should try harder to get it back to home base". That's just another form of "get-home-itis". Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Paul Tomblin wrote:
In a previous article, Ron Rosenfeld said: On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Well, the guy who had it booked for Monday and Tuesday wrote to me that he'd been thinking of cancelling anyway because of the weather, so I feel better about that. This morning I look at the airmets, and there are two of them for icing, with a narrow little corridor between them straight between BAF and ROC. Not sure if I trust that narrow corridor to stay open, though. How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? I find the FAA weather guys to be pretty conservative about almost everything, but even the best weather folks are wrong as often as they are right. The FAA is especially conservative when calling for icing and this is a real pain with the ever stricter FAA and NTSB interpretations of "known icing." Now that forecast = known, it makes flying in the northeast illegal for about 5 months of the year. I tend to fly if there isn't rain at ground level and the freezing level is at or above the MEA or I can fly VFR. However, I've flown a lot in the winter and am reasonably comfortable taking on reasoned risk. Everyone's risk assessment and tolerance is different and only you know what you are comfortable with. If you are significantly concerned about making the flight, then I'd say that alone probably says it isn't worth it. Flying is supposed to be fun (unless you are getting paid for it) so why make a flight that will give you white knuckles on the yoke? MAtt |
Paul Tomblin wrote:
In a previous article, Robert Chambers said: Yeah I was thinking if you could get to Utica or somewhere a bit closer than BAF. The drive would be shorter if you have to leave the plane there and the drive back to retrieve the bird would be shorter as well. As I was driving out of the parking lot at Barnes, there was a fair chunk of blue sky to the west. I was really tempted to fly west and see how far I could get VFR with maybe a popup IFR clearance for an approach somewhere and rent a car there, and that's what I would have done if I were alone. But my wife doesn't like the uncertainty of not knowing whether we're going to find a rental car or a motel room. On the drive home, we drove through some high hills with low clouds down below the peaks and cold rain, and figured that being in the car was probably the best decision. I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. I might go down on Wednesday and give it a try to see how far I get. I flew from ELM to LEB on Friday for the weekend. Woke up at the hotel in Montpelier, VT Sunday morning to 3" of snow! Luckily, as we drove back south to the airport we ran out of snow and into light mist. I was iffy on attempting the flight home given the low clouds and freezing level, but a twin had departed shortly ahead of me for PA and reported on top at 10,000 with no icing problems. So, I decided to take a look and see how far I could get. Got a little rime at 6,000, but was soon between layers and had a pretty uneventful fight home. I did have to climb to 8,000 to stay between layers near Albany and eventually up to 10,000 to get on top prior to Binghamton, but the descent into ELM was through a thin layer with no problems. One just never knows in this part of the country this time of the year. You certainly can't fault any decision to cancel a flight this time of year in such conditions. I've flown a fair bit in this area and decided the risk was acceptable, but I did have the ILS 18 back into Lebanon on my approach clip as I was climbing out. :-) Matt |
