Runway Numbering - Radio Procedure
Old October 23rd 05, 10:35 PM
Steven P. McNicoll
Default Runway Numbering - Radio Procedure
"Jose" wrote in message
"Podunk traffic, Waco niner eight zero one victor, entering downwind
runway two ZERO, stop-and-go, Podunk."
He's actually coming the other way, head on to you who hears "runway two,
stop and go..."
Nope, there wasn't enough room between "runway" and "stop" for "two zero".
He definitely said "downwind runway two, stop-and-go". There was no zero.
I suppose you don't, and that's the argument for omitting the leading
zero. Further, you could hear it correctly and transpose it in your own
mind.
Which one trumps the other? I don't think either is trump. Do what other
pilots expect to hear, whether by local practice or AIM.
Non-use of the leading zero trumps the use of it, no question about it.
Note that all of the scenarios used to support the use of the leading zero
rely on improper phraseology. If proper phraseology is used the leading
zero provides nothing positive, but if it is used it creates the possibility
for confusion as it can be transposed with the other digit. That
possibility is not limited to runway 2/20 either, as the field may have an
intersecting runway it could be confused with, such as runways 1/19 an
10/28.
Bottom line, the leading zero should not be used.
Old October 24th 05, 03:20 AM
Jose
Yes, but =she= (the next week) spoke slower, and with a more varied cadence.
Well, the discussion here shows that there =is= some question about it,
just not in your mind. I tend to agree with you that non-use is
probably better. However, it is not without benefit.
As for being nonstandard, that's just a matter of changing the standard.
Elsewhere they use a different standard, but the laws of physics are
the same.
That
10/28.
Good point.
Jose
Money: what you need when you run out of brains.
Old October 24th 05, 05:03 AM
Gerald Sylvester
the same.
correct. Since the US does allow non-US registered airplanes to land
in the US, does it make sense to follow international standards. Since
the AIM is not regulatory, it makes sense to conform to international
standards. Instead the FAA has decided to do as they see fit and
not give a damn about international standard. For this, I don't see
anything wrong with following international standard as international
aircraft can misunderstand the US phraseology. BTW, I've heard many
complaints from non-US pilot saying US pilots use way too much
non-international standard phraseology making it hard to understand
and dangerous for when US pilots fly abroad.
Gerald Sylvester
Old October 24th 05, 05:09 AM
George Patterson
As have the aviation boards of every other country, as far as they can. It's the
only way they can keep their turf.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 24th 05, 10:39 AM
Stefan
The main problem with US pilots is that they often speak some
undefinable mumblejumble instead of English...
Stefan
Old October 25th 05, 01:33 AM
Andrew Sarangan
Since when did US prevent foreign-registered aircrafy from landing in
the US?
Can you cite specific examples of US pilots phrasology causing dangerous
conditions?
Gerald Sylvester wrote in
Since the AIM is not regulatory, it makes sense to conform to
international standards. Instead the FAA has decided to do as they
see fit and not give a damn about international standard. For this, I
don't see anything wrong with following international standard as
international aircraft can misunderstand the US phraseology. BTW,
I've heard many complaints from non-US pilot saying US pilots use way
too much non-international standard phraseology making it hard to
understand and dangerous for when US pilots fly abroad.
Gerald Sylvester
Andrew Sarangan
CFII
http://www.sarangan.org/aviation/
Old October 25th 05, 02:25 AM
Gerald Sylvester
conditions?
no as often it is ignored. Can you imagine if every time non-standard
phraseology is used other pilots are requesting clarification?
One instance where English was not used was when my friend
flying for a major was going into Mexico City. He was the PNF.
The PF on the approach made a sharp turn. My friend asked
what the turn was for. The PF said the controller told the preceding
a/c about a severe windshear alert but the call was in spanish. The
other a/c cancelled their approach. If the
PF didn't understand spanish, it very well could have
been dangerous.
Another instance was living in Germany. I was half way through
my PPL and went flying with a friend of a friend. Looking back,
the guy was a moron. He barely understood English and couldn't
copy the clearance nor follow the clearance out of Salzburg and
then busted the Class B (I think it is B) MUC airspace due to
his lack of English. Although no near miss happened but if
the airspace was more dangerous, it certainly could have been
bad.
Although this is non-US pilots not being fluent in English ATC
phraseology, the same happens the other way for sure.
Gerald Sylvester
Old October 30th 05, 11:17 PM
Steven P. McNicoll
"Gerald Sylvester" wrote in message
How long had you gone without sleep when you wrote that?
Old October 31st 05, 06:41 AM
Roger
On Sun, 30 Oct 2005 23:17:42 GMT, "Steven P. McNicoll"
Hmmm... Living in Michigan, I see a lot of planes coming in that have
something different than N numbers. I wonder who let them land.
www.rogerhalstead.com
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 06:23 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
F15E's trounced by Eurofighters John Cook Military Aviation 193 April 11th 04 03:33 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
