carb ice experience
Old October 24th 05, 05:03 AM
Robert M. Gary
Default carb ice experience
I got carb ice almost every time I flew the cub. On cold 6am flights,
the Cub just loved to suck up the ice. I learned to leave the carb heat
in during touch-n-go operations until climbing out because I lost the
engine once after shutting off the carb ice as I was moving the
throttle forward. The engine ran far enough to get me 300 feet up then
started to die. Luckily, turning around at 300 feet is very easy in a
Cub, not so easy in a Mooney. I kept a timer for cruise and ran 15
minutes heat off then 15 minutes heat on. I would also often get ice in
the time it takes to taxi to runup. I learned to clear out with heat
first. For some reason, the cub got ice much more than the Aeronca with
the same engine, I think it has something to do with how heat moves
around in the cowl.
-Robert
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 01:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 07:26 PM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Carb Temperature Gauge fly_the_skies Home Built 6 January 14th 04 03:32 PM
