On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul
Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Seriously, if the club is second guessing your decision, there's something very wrong with the safety culture there. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
In a previous article, Ron Rosenfeld said:
On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Well, the guy who had it booked for Monday and Tuesday wrote to me that he'd been thinking of cancelling anyway because of the weather, so I feel better about that. This morning I look at the airmets, and there are two of them for icing, with a narrow little corridor between them straight between BAF and ROC. Not sure if I trust that narrow corridor to stay open, though. How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? -- Paul Tomblin http://xcski.com/blogs/pt/ Programmer (n): One who makes the lies the salesman told come true. |
"Paul Tomblin" wrote in message
... How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? Icing is hardly ever as predictable as we'd like but my personal experience is that I've found that the boundaries are usually broader than actual icing conditions, but the accumulation rates can be both more and or less severe than indicated in the airmet because it is also unpredictable and is highly dependent on your speed and time spent in the conditions. I also fly around the great lakes, and downwind from the lake is a great place to find ice building faster than predicted and faster than you can get out of it. Usually when the windward side is CAVU, the lake effect layer on the leeward side isn't very thick, but you sure as hell don't want to be stuck in it very long. If the windward side is IFR and tops into the teens or higher, the lake effect moisture is just added to those conditions on the leeward side, and you've probably lost all your "outs". Stay away... stay far away. I've found that the ADDS forecast has been pretty accurate. If I can get above a potential icing layer that isn't too thick, fly towards warmer conditions and then do a slam dunk down through it into warmer and clear conditions near my destination, I'll give it some serious consideration. If I don't have at least 3 "outs", (altitude, distance, improving weather, higher temps, between layers, ect.) I won't consider it. This weekend in WI was a perfect case of airmets galore, but good planning wouldn't have prevented flying due to ice. Overcast at 2700, clear above 3000.(4000 MSL) light to moderate rime ICIP airmet blanketing the entire state. VFR both south and north of us, surface temps between 40 and 45F. Freezing level 4000 MSL north sloping to 6000 MSL south. ADDS was predicting a 80-90% chance of icing at 6000, nothing at 3000, and nothing at 9000. The "go" decision could be made because the clouds at 2700-3000 AGL were below the freezing level and it was clear above, so the airmet didn't have any weather that it applied to. Be careful when using ADDS that you remember ceilings are AGL, icing predictions are MSL. So, we could have taken off, climbed through the ceiling into clear air. What if we come upon a layer at 6000 where ADDS said 80-90% chance of ice? What are our outs? 1) Climb above it, ADDS predicted 0% at 9000, climb is always my first choice. you can climb before you accumulate ice, you can always go down. 2) descend below it and continue, MEA is 3000 MSL 3) descend through it and land 4) turn around and fly back into clear weather 5) turn 90 degrees to the system and fly around it, this requires knowledge of the area of coverage and conditions surrounding it, plus additional fuel. I hate airmet zulu as well, it always throws the unknown at you. All we can do is explore all our options, set minimal standards, do extra planning, and be willing to stay on the ground. Fly safe. Jim |
: This weekend in WI was a perfect case of airmets galore, but good planning
: wouldn't have prevented flying due to ice. Overcast at 2700, clear above : 3000.(4000 MSL) light to moderate rime ICIP airmet blanketing the entire : state. VFR both south and north of us, surface temps between 40 and 45F. : Freezing level 4000 MSL north sloping to 6000 MSL south. ADDS was : predicting a 80-90% chance of icing at 6000, nothing at 3000, and nothing at : 9000. The "go" decision could be made because the clouds at 2700-3000 AGL : were below the freezing level and it was clear above, so the airmet didn't : have any weather that it applied to. Be careful when using ADDS that you : remember ceilings are AGL, icing predictions are MSL. So, we could have : taken off, climbed through the ceiling into clear air. : What if we come upon a layer at 6000 where ADDS said 80-90% chance of ice? : What are our outs? : 1) Climb above it, ADDS predicted 0% at 9000, climb is always my first : choice. you can climb before you accumulate ice, you can always go down. : 2) descend below it and continue, MEA is 3000 MSL : 3) descend through it and land : 4) turn around and fly back into clear weather : 5) turn 90 degrees to the system and fly around it, this requires knowledge : of the area of coverage and conditions surrounding it, plus additional fuel. 6) Stay VFR at 2500 AGL? If it's overcast at 2700, staying out of the iced-up soup altogether seems like a good plan as well. I'd rather be at 1500 AGL in VMC than slogging through the soup waiting for ice to start accumulating and have to choose an "out" -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Matt Whiting wrote:
: slogging through the soup waiting for ice to start accumulating and have to choose an : "out" : Except 200' below the clouds doesn't meet the VFR minimums in most : classes of airspace. So fly at 2200'. The east/west rules aren't required if below 5000 AGL IIRC. If you want to call it MVFR, great. I'm just saying I'll take MVFR to icy soup in my spamcan. Once you're IMC you're "committed" and things like altitude and heading deviations take (possibly lots of) time, unless you declare an emergency. -Cory ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
3000 AGL in the US. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
On Mon, 24 Oct 2005 11:28:22 +0000 (UTC), (Paul
Tomblin) wrote: In a previous article, Ron Rosenfeld said: On Mon, 24 Oct 2005 01:37:41 +0000 (UTC), (Paul Tomblin) wrote: I'm just not sure when the conditions are going to be conducive to bringing the plane home, and the club is NOT going to be happy about that. Yes, they would have been much happier had you become an icing accident. Well, the guy who had it booked for Monday and Tuesday wrote to me that he'd been thinking of cancelling anyway because of the weather, so I feel better about that. This morning I look at the airmets, and there are two of them for icing, with a narrow little corridor between them straight between BAF and ROC. Not sure if I trust that narrow corridor to stay open, though. How good are the boundaries of airmets? Are you ever going to encounter the conditions outside the boundaries, or are they pretty conservative about them? I have not looked in detail at weather in the NY area today. However, given the general picture these past few days, I would not fly in a non-deice'd a/c in the clouds higher than the freezing level. There's a lot of moisture in these clouds. An FIP map that I downloaded last night valid at 0900Z showed significant icing probability along your route at 6,000', although it did look doable at 3,000'. I flew today from Eastport to Bangor and back in my non-deiced Mooney. But I stayed at 3,000' and had no ice -- occasional light rain that sure would have been ice had I been above the FL (about 4,000'). Here, with little traffic, there were still scattered reports of icing. One thing that's real important in flying, is to not weigh factors like "so and so has the plane booked for whenever so I should try harder to get it back to home base". That's just another form of "get-home-itis". Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
An FIP map that I downloaded last night valid at 0900Z showed significant icing probability along your route at 6,000', although it did look doable at 3,000'. The MEA between CTR and ALB is 6,000 though. I'm looking at the possibility of going VFR to the Hudson Valley and then the Mohawk Valley. But there are still those hills to the south of Rochester. Thanks for you advice and everybody else's on this thread. I feel like I've made the right decision, but it's easy to second guess yourself. -- Paul Tomblin http://xcski.com/blogs/pt/ "Man in the tower, this is the man in the bird, I'm ready to go, so give me the word." "Man in the bird, this is the man in the tower, you sound funny, delay's an hour." - Rod Machado |
