Cub Driver wrote:
(Must be more to carb heat than that. Bypassing the filter ought to increase performance in every instance, or at least never decrease it. Yes. But pulling carb heat on, in the Cub, does definitely cause a decrease in power. The heat normally creates a rich mixture, which causes a decrease in power. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
In article jy67f.6582$%A1.1101@trndny01,
George Patterson wrote: But pulling carb heat on, in the Cub, does definitely cause a decrease in power. The heat normally creates a rich mixture, which causes a decrease in power. The reduction in power caused by the application of carb heat is mostly due to the decrease in air mass flow through the engine, i.e. a reduction in volumetric efficiency. JKG |
George Patterson wrote: Cub Driver wrote: (Must be more to carb heat than that. Bypassing the filter ought to increase performance in every instance, or at least never decrease it. Yes. But pulling carb heat on, in the Cub, does definitely cause a decrease in power. The heat normally creates a rich mixture, which causes a decrease in power. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. If the carburetor attach flange nuts are loose, the mixture will be very lean, due to air leaks around the base. Applying heat will enrich the mixture, possibly correcting a too-lean condition. I have seen a few planes with loose carburetor attach nuts. |
Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 01:48 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Use of Carb Heat | John Kirksey | Piloting | 4 | November 30th 04 07:26 PM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 03:32 PM |
