In article jy67f.6582$%A1.1101@trndny01,
George Patterson wrote: But pulling carb heat on, in the Cub, does definitely cause a decrease in power. The heat normally creates a rich mixture, which causes a decrease in power. The reduction in power caused by the application of carb heat is mostly due to the decrease in air mass flow through the engine, i.e. a reduction in volumetric efficiency. JKG |
Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 01:48 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Use of Carb Heat | John Kirksey | Piloting | 4 | November 30th 04 07:26 PM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 03:32 PM |
