Peter R. wrote:
My fuel-injected, turbo-normalized Bonanza had a newly rebuilt engine installed last February. Upon completion of the work, I took the aircraft up for the proper first flight break-in. When I landed, the engine quit just as I touched down (low idle) on the runway. I was able to restart and taxied back to talk to the mechanic. He adjusted the low-idle mixture so I took the aircraft up for the second flight break-in. Again, upon landing the engine quit. Suspecting something else now, the mechanic ran the aircraft on the ground and was able to duplicate the problem. He then suspected the fuel pump so he took it off and sent it back to the company who supplied it to the engine rebuilder for inspection. The fuel pump inspectors discovered metal shavings inside the fuel pump that were cutting off fuel flow at low idle. That opened up an entire finger pointing session. Nice... The source of the shavings was never identified but it was concluded that somehow they were introduced when the engine was on the test cell. I had a similar situation with a carburetor on the club's Archer. It had been at the maintenance shop for some carb work. After ground testing and a short flight around the patch, everything seemed be working fine. So I took off and flew home. On final my descent rate was a little fast, so I went to tweak the throttle and nothing happened. Since I was less than a half a mile from the threshold with plenty of altitude, it was no big deal to dead stick it in. I actually had enough speed left on landing that had I been going the other way I probably could have made it off the runway. (The runway at our airport has a slight grade and I was landing uphill.) Instead I rolled to a stop almost exactly mid-way down the runway and had to call for a tow because the engine wouldn't restart. It was discovered afterward that the shop that had worked on the carb had gotten a washer stuck between the top half and bottom half of the carb that prevented the float from properly shutting off the fuel flow. The result was a flooded engine on final. -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "And so it was only with the advent of pocket computers that the startling truth became finally apparent, and it was this: Numbers written on restaurant checks within the confines of restaurants do not follow the same mathematical laws as numbers written on any other pieces of paper in any other parts of the Universe." -- Life, the Universe, and Everything, Douglas Adams |
Here it is: a graph I was hoping to find on the 'net that shows the
temperature ranges and dewpoint/humidites at which icing can occur. Note that the range extends from well below freezing to over 100 degrees F. This graph will apply to avgas; mogas has a higher volatility (evaporation rate) and can cause icing outside these parameters. http://www.wsaa.net/icing.htm Icing can also occur in very cold temps if carb heat IS used: ice crystals in the air can melt as the incoming air is heated, collect on the throttle plate and other parts, and freeze due to the pressure drop and evaporative cooling. Dan |
An A&P and/or IA made a mistake working on a engine? To hear them tell, they
are the "experts" and you should never work on your own plane nor should you be anywhere within 100 miles of the shop when they work on them. Tom "Mark T. Dame" wrote in message ... Peter R. wrote: My fuel-injected, turbo-normalized Bonanza had a newly rebuilt engine installed last February. Upon completion of the work, I took the aircraft up for the proper first flight break-in. When I landed, the engine quit just as I touched down (low idle) on the runway. I was able to restart and taxied back to talk to the mechanic. He adjusted the low-idle mixture so I took the aircraft up for the second flight break-in. Again, upon landing the engine quit. Suspecting something else now, the mechanic ran the aircraft on the ground and was able to duplicate the problem. He then suspected the fuel pump so he took it off and sent it back to the company who supplied it to the engine rebuilder for inspection. The fuel pump inspectors discovered metal shavings inside the fuel pump that were cutting off fuel flow at low idle. That opened up an entire finger pointing session. Nice... The source of the shavings was never identified but it was concluded that somehow they were introduced when the engine was on the test cell. I had a similar situation with a carburetor on the club's Archer. It had been at the maintenance shop for some carb work. After ground testing and a short flight around the patch, everything seemed be working fine. So I took off and flew home. On final my descent rate was a little fast, so I went to tweak the throttle and nothing happened. Since I was less than a half a mile from the threshold with plenty of altitude, it was no big deal to dead stick it in. I actually had enough speed left on landing that had I been going the other way I probably could have made it off the runway. (The runway at our airport has a slight grade and I was landing uphill.) Instead I rolled to a stop almost exactly mid-way down the runway and had to call for a tow because the engine wouldn't restart. It was discovered afterward that the shop that had worked on the carb had gotten a washer stuck between the top half and bottom half of the carb that prevented the float from properly shutting off the fuel flow. The result was a flooded engine on final. -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "And so it was only with the advent of pocket computers that the startling truth became finally apparent, and it was this: Numbers written on restaurant checks within the confines of restaurants do not follow the same mathematical laws as numbers written on any other pieces of paper in any other parts of the Universe." -- Life, the Universe, and Everything, Douglas Adams |
"Tom" wrote in message
... An A&P and/or IA made a mistake working on a engine? To hear them tell, they are the "experts" and you should never work on your own plane nor should you be anywhere within 100 miles of the shop when they work on them. AMEs think anything accessible to a pilot is controlled by an idiot. Pilots think that AMEs are trying to kill them. A schizophrenic is a pilot who is also an AME Happy landings, |
Sigh.
Jim Comm'l. Inst. CFI Airplane & Glider A&P IA Roses are red Violets are blue I'm schizophrenic And so am I. "Private" wrote in message news:40R8f.336700$oW2.18373@pd7tw1no... AMEs think anything accessible to a pilot is controlled by an idiot. Pilots think that AMEs are trying to kill them. A schizophrenic is a pilot who is also an AME |
cheers, ROTFL
"RST Engineering" wrote in message ... Sigh. Jim Comm'l. Inst. CFI Airplane & Glider A&P IA Roses are red Violets are blue I'm schizophrenic And so am I. "Private" wrote in message news:40R8f.336700$oW2.18373@pd7tw1no... AMEs think anything accessible to a pilot is controlled by an idiot. Pilots think that AMEs are trying to kill them. A schizophrenic is a pilot who is also an AME |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Engine failure on takeoff | Greg Copeland | Piloting | 0 | May 11th 04 04:59 PM |
In-Flight Engine Failure | O. Sami Saydjari | Owning | 59 | April 30th 04 08:40 AM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Engine failure rates poll | Captain Wubba | Piloting | 3 | December 8th 03 02:44 PM |
