I used the E-word today. At 08:30 EDT this morning over the Springfield
Mixing bowl just south of Washington DC, I declared and emergency. We had just finished our Potomac River crossing south of National airport and headed south to Woodbridge and back to Springfield, VA. Northbound I was just turning the corner to pick up the beltway and head for Tyson's Corners and the engine instantly started running rough, very rough. I thought we were going to loose it all together at 1000 feet AGL over a densely populated area. I immediately turned south again towards the last airport we had passed and called the tower. "Davison tower, Fetter Three is coming in". Fetter Three what is the nature of your trouble? "Engine running rough", How many souls (I hate that question but the need to know to know how many Ambulances to roll), "2." How much fuel? "40 gallons". Are you declaring and emergency? "Yes" ,Would you like Fire rescue? "Yes". I have pushed the button. I tried the Carb heat no results. Mixture full in, and I used our excess airspeed to climb. This added about 200 feet to our altitude. Oil pressure was reading ok as was oil Temp. I tried different power settings no luck. Here we were at 70 KIAS "full" power and holding altitude. I called on the Company air to air to report I was going down. Our other Fixed wing immediately turned towards our position. I was not sure how long this would last so both my observer and I were looking for a place to land short of the field. I am usually looking for places to land as we are cruising around the beltway. Never hurts. Interstate 95S was lightly loaded and was a real possibility. We also had a couple of "large" fields on our way. The engine held and we were cleared to land, wind calm. As we rolled out we we met by the entire fire crew. Since the event was sudden I had no Idea how bad the damage was and weather we would have a fire upon landing. It turns out we were not leaking any oil or fuel. We pushed the airplane off the runway, they have no tow bars for Small GA airplanes. It was parked with the other fixed wing aircraft on the field. THe airfield manager came out and greeted us. Offered us the use of the DV (Distinguished Visitors) lounge. I called my boss and Maintenance. They were on their way. Our other plane landed about 10 minutes behind me. While I was Cleaning out the plane, My observer climbed in our other plane and went back to home base. While I was waiting for my Boss and the Mechanic to arrived I sat in the DV lounge watching Satellite TV and filling out the mound of paper work from an un-authorized landing. Being made Authorized. I stayed with the plane in hopes we could fix it and fly it out today. The plane turned out to be broken harder than I thought. I originally thought the Mags (Dual Drive) had slipped a gear since the entire engine was running badly. It became very obvious when we removed the cowling that we had a problem with the #3 cylinder. The intake push rod was bent. This seemed strange until we removed the rocker cover. The stud for the exhaust valve had come loose in the head and the rocker was cocked to one side. THe push rod was not even contacting the rocker arm. This trapped the high pressure combustion results in the cylinder. When the intake valve tried to open it couldn't. Too much pressure. The push rod bent. Not only did we have a dead cylinder, we had the rest of the engine pushing against a full Combustion charge that could not escape. The mechanic and I removed the offending cylinder and return to home base. I and my morning observer went out and flew the afternoon Survey run. Everything went smoothly and it usually does. The airplane looks like it will be there until Monday when some of the parts under the cowling were broken by the shaking. Michelle (Two engine failures in 15 years and counting) |
Wow, great story Michelle, glad to hear everything turned out well.
Just curious - how close do they let you get to DCA these days, now that GA is "allowed" back into the field? -- Guy |
Thanks,
We fly a Waiver so We are allowed within 7 NM of DCA VOR at all times. I have one of my Class B charts with a beg red dot in the center. The do not go there dot. We have nothing to do with GA into DCA. Michelle Guy Elden Jr wrote: Wow, great story Michelle, glad to hear everything turned out well. Just curious - how close do they let you get to DCA these days, now that GA is "allowed" back into the field? -- Guy |
As the Brits say, Jolly good show gal.
On Fri, 28 Oct 2005 01:12:34 GMT, Michelle P wrote: I used the E-word today. At 08:30 EDT this morning over the Springfield Mixing bowl just south of Washington DC, I declared and emergency. We had just finished our Potomac River crossing south of National airport and headed south to Woodbridge and back to Springfield, VA. Northbound I was just turning the corner to pick up the beltway and head for Tyson's Corners and the engine instantly started running rough, very rough. I thought we were going to loose it all together at 1000 feet AGL over a densely populated area. I immediately turned south again towards the last airport we had passed and called the tower. "Davison tower, Fetter Three is coming in". Fetter Three what is the nature of your trouble? "Engine running rough", How many souls (I hate that question but the need to know to know how many Ambulances to roll), "2." How much fuel? "40 gallons". Are you declaring and emergency? "Yes" ,Would you like Fire rescue? "Yes". I have pushed the button. I tried the Carb heat no results. Mixture full in, and I used our excess airspeed to climb. This added about 200 feet to our altitude. Oil pressure was reading ok as was oil Temp. I tried different power settings no luck. Here we were at 70 KIAS "full" power and holding altitude. I called on the Company air to air to report I was going down. Our other Fixed wing immediately turned towards our position. I was not sure how long this would last so both my observer and I were looking for a place to land short of the field. I am usually looking for places to land as we are cruising around the beltway. Never hurts. Interstate 95S was lightly loaded and was a real possibility. We also had a couple of "large" fields on our way. The engine held and we were cleared to land, wind calm. As we rolled out we we met by the entire fire crew. Since the event was sudden I had no Idea how bad the damage was and weather we would have a fire upon landing. It turns out we were not leaking any oil or fuel. We pushed the airplane off the runway, they have no tow bars for Small GA airplanes. It was parked with the other fixed wing aircraft on the field. THe airfield manager came out and greeted us. Offered us the use of the DV (Distinguished Visitors) lounge. I called my boss and Maintenance. They were on their way. Our other plane landed about 10 minutes behind me. While I was Cleaning out the plane, My observer climbed in our other plane and went back to home base. While I was waiting for my Boss and the Mechanic to arrived I sat in the DV lounge watching Satellite TV and filling out the mound of paper work from an un-authorized landing. Being made Authorized. I stayed with the plane in hopes we could fix it and fly it out today. The plane turned out to be broken harder than I thought. I originally thought the Mags (Dual Drive) had slipped a gear since the entire engine was running badly. It became very obvious when we removed the cowling that we had a problem with the #3 cylinder. The intake push rod was bent. This seemed strange until we removed the rocker cover. The stud for the exhaust valve had come loose in the head and the rocker was cocked to one side. THe push rod was not even contacting the rocker arm. This trapped the high pressure combustion results in the cylinder. When the intake valve tried to open it couldn't. Too much pressure. The push rod bent. Not only did we have a dead cylinder, we had the rest of the engine pushing against a full Combustion charge that could not escape. The mechanic and I removed the offending cylinder and return to home base. I and my morning observer went out and flew the afternoon Survey run. Everything went smoothly and it usually does. The airplane looks like it will be there until Monday when some of the parts under the cowling were broken by the shaking. Michelle (Two engine failures in 15 years and counting) |
wrote: Michelle (Two engine failures in 15 years and counting) Glad it held together long enough for you to get to a field and I hope you can stop counting at 2. z |
Michelle P wrote:
I used the E-word today. At 08:30 EDT this morning over the Springfield Mixing bowl just south of Washington DC, I declared and emergency. Glad it worked out so well. George Patterson Drink is the curse of the land. It makes you quarrel with your neighbor. It makes you shoot at your landlord. And it makes you miss him. |
Michelle P wrote:
While I was Cleaning out the plane, My observer climbed in our other plane and went back to home base. OK, I just have to ask about "cleaning out the plane"... :-D Seriously, good job on handling the situation. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
Well my underwear is till clean, but it was close. I was shaking pretty
badly when I got out of the plane. I would like to get a copy of the "tape". It was just our personal stuff I cleaned out of the plane..... Michelle John T wrote: Michelle P wrote: While I was Cleaning out the plane, My observer climbed in our other plane and went back to home base. OK, I just have to ask about "cleaning out the plane"... :-D Seriously, good job on handling the situation. |
Good decision making, Michelle... May it be at least 7.5 years to the
next engine failure they do do that, don't they... cheers ... denny - 1 engine lunched, and counting... |
Great job and an excellent account! I'm forwarding your post to my wife.
-- -- =----- Good Flights! Cecil E. Chapman CP-ASEL-IA Student - C.F.I. Check out my personal flying adventures from my first flight to the checkride AND the continuing adventures beyond! Complete with pictures and text at: www.bayareapilot.com "I fly because it releases my mind from the tyranny of petty things." - Antoine de Saint-Exupery - "We who fly, do so for the love of flying. We are alive in the air with this miracle that lies in our hands and beneath our feet" - Cecil Day Lewis - |
New Word 'SOARING' | Ray Lovinggood | Soaring | 29 | February 5th 05 12:45 AM |
Read This Carefully please; word for word | Dudley Henriques | Military Aviation | 16 | September 6th 04 02:40 PM |
Area bombing is not a dirty word. | ArtKramr | Military Aviation | 82 | February 11th 04 02:10 PM |
Hiroshima. The final word. | ArtKramr | Military Aviation | 10 | January 12th 04 12:20 PM |
so what is the latest word on Sport Pilot ??? | Gilan | Piloting | 10 | September 5th 03 02:44 AM |
