Carb ice is funny sometimes. Was doing a bunch of T&Gs in a 152. As
you, Carb Heat on downwind, push it off after pushing the throttle in on takeoff. On my 7th or 8th "GO" the engine lost power and ran rough at about 300' and quit as I made a right 270 back to the intersecting runway. Made the runway, got a restart after a few moments, it ran real rough for a bit then smoothed out. Shop checked it and found nothing wrong, we assume it was carb ice. More likely the engine had loaded up with raw fuel. With carb heat on, the mixture gets pretty rich, and with the throttle closed there is very little airflow through the engine. Fuel can puddle in the intake manifold, and upon opening the throttle all that gasoline is sucked into the cylinders and floods them. It's worse if you shut the carb heat off first, as the cold air reduces the vaporization of the fuel. Don't make long power-off glides when it's cold and with carb heat on. Clear the engine often, and make sure it's ready to run if you need it. Dan |
![]() wrote Don't make long power-off glides when it's cold and with carb heat on. Clear the engine often, and make sure it's ready to run if you need it. That sure is different than the normal advice, isn't it? -- Jim in NC |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Engine failure on takeoff | Greg Copeland | Piloting | 0 | May 11th 04 04:59 PM |
In-Flight Engine Failure | O. Sami Saydjari | Owning | 59 | April 30th 04 08:40 AM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
Engine failure rates poll | Captain Wubba | Piloting | 3 | December 8th 03 02:44 PM |
