"John Doe" wrote:
So you were overtaking the 172? Did you not see him prior to descending? I assume that you see every aircraft near you. I wish I were that good. Even when given aircraft advisories I often never see the aircraft. Ron Lee |
Boy, isn't that true. With the TIS showing the distance at a mile or
so, I sometimes still can't see the plane. Big planes easy, but small ones, not so. In this case I did not have a visual on the 172. He was under me. |
No, but I clear my flight path religiously. Most people I've flown with are
lucky to clear during turns, descents are the worst. Folks just assume there's no one below them. I learned long ago to do a 'belly check' in low wing aircraft to make sure I don't hit exactly the issue below. "Ron Lee" wrote in message ... "John Doe" wrote: So you were overtaking the 172? Did you not see him prior to descending? I assume that you see every aircraft near you. I wish I were that good. Even when given aircraft advisories I often never see the aircraft. Ron Lee |
