Yes, have the gov adjusted. You should be able to get 2700+-25Rpm. The
extra 85 RPM translates to much higher takeoff engine power. |
You can check the accuracy of your tach at 1800 rpm by doing a runup at
night with a street light in back of you. Due to the strobe effect, the prop should appear to stop at 1800 rpm (for a two blade prop). For a 3 blade prop, it should appear to stop at 1200 and 2400 rpm. Good inexpensive accurate double check on tach accuracy. |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
New Film: The Need For Speed - Going to war on drugs | Phil Carpenter | Military Aviation | 0 | July 23rd 03 07:43 AM |
