Repost from Dec. 2004 for those who missed it back then.
Forget about the airplane, concentrate on saving lives. Slowest possible foreward speed at touch down, no matter what the surface is. Maintain control and do not stall the aircraft! Falling out of the sky 30 feet above the ground will kill passengers faster than a controlled crash straight ahead. If you have a choice land into the wind and or uphill if possible. Reduce sources of ignition. Turn off fuel and electrical as much as possible. Prepare your passengers for impact after touchdown. Seatbelts tight, knees up, wrap your arms around your knees, face down into your thighs. Your objective is to keep your passengers and yourself: 1)alive 2)conscious and 3)mobil, in that order. Land "with" the rows, furrows, ditch, traffic etc. Do what ever it takes to reduce your chances of rolling or tumbling the aircraft. Keep the centerline of the aircraft pointed in the direction that you are traveling. Look for power poles, not lines. You're able to see poles a lot sooner than you'll ever see the lines. Do not forget about guy wires. Land "behind" the house rather than in front. The odds are better that the power lines enter from the front. If you try to land on a road and there is a house or building nearby, odds are 50/50 that there will be power lines crossing the road. Open a door prior to touchdown. A bent airframe, deep snow, or mud, may prevent you from opening it after you stop moving. Realize that freshly plowed fields not only have furrows but tend to be soft. A gear up landing (if possible) may prevent your gear from digging in and cartwheeling your airplane. Think about why a potential landing spot is in the condition that it is. Many times areas of long grass aren't mowed for a reason.... rocks? swamp?. Avoid them unless you are familiar with the area (and if you have a choice). Look beyond your landing spot. You may be proud of the approach and touchdown that you make... right up to the point that you skid into a drainage ditch. There are some great survival books and articles available. Read a couple then buy a survival kit to keep in the plane. Remember the name of the game is survival, not luxury, carry things that will keep you warm and dry. Don't forget to carry water on every flight. Keep in mind what happens to your landing surface through out the year and with weather changes. A field that you may repeatedly fly over and think that would make a great emergency landing spot may turn into an unseen swamp after even a light rain. In much of the Midwest those perfectly flat farm fields make great options to consider, but maybe not after periods of rain. Dark soil will retain more water than sandy soil. Those same fields that are soft and smooth in the summer may turn rock hard and rough as hell if there isn't any snow cover. Watch out for farm fields that were disked and chisel plowed in the fall but no snow cover to make them smooth. Perfect for ripping your gear off no matter what direction you land. In this situation I look for short grass without rocks because I know it hasn't changed. Here the rocks are in the ridges and the land that happens to be farmed isn't irrigated or farmed. Perfect landing spot this time of year would be a field with a cover crop of rye or wheat with an irrigation system. I know it will be smooth and rock free. The same idea can be transferred to about lakes. The lake that you fly by all summer long may turn into your best option once winter comes and it is frozen over. Watch for ice fishermen... if the lake can support their cars, chances are it will support your airplane. Avoid lakes without ice fisherman, this can mean the ice isn't thick enough or that it is a spring fed lake and doesn't freeze completely. Watch for snow drifts and touch down as softly as possible, remember braking action will be nill. Oh, and if you successfully land on a road, make the fire trucks and other vehicles move before you try to take off. Jim |
IIRC the problem with the Louisiana C-210 incident.. was the subsequent
departure from said narrow roadway... not the landing BT "Jim Burns" wrote in message ... Repost from Dec. 2004 for those who missed it back then. Forget about the airplane, concentrate on saving lives. Slowest possible foreward speed at touch down, no matter what the surface is. Maintain control and do not stall the aircraft! Falling out of the sky 30 feet above the ground will kill passengers faster than a controlled crash straight ahead. If you have a choice land into the wind and or uphill if possible. Reduce sources of ignition. Turn off fuel and electrical as much as possible. Prepare your passengers for impact after touchdown. Seatbelts tight, knees up, wrap your arms around your knees, face down into your thighs. Your objective is to keep your passengers and yourself: 1)alive 2)conscious and 3)mobil, in that order. Land "with" the rows, furrows, ditch, traffic etc. Do what ever it takes to reduce your chances of rolling or tumbling the aircraft. Keep the centerline of the aircraft pointed in the direction that you are traveling. Look for power poles, not lines. You're able to see poles a lot sooner than you'll ever see the lines. Do not forget about guy wires. Land "behind" the house rather than in front. The odds are better that the power lines enter from the front. If you try to land on a road and there is a house or building nearby, odds are 50/50 that there will be power lines crossing the road. Open a door prior to touchdown. A bent airframe, deep snow, or mud, may prevent you from opening it after you stop moving. Realize that freshly plowed fields not only have furrows but tend to be soft. A gear up landing (if possible) may prevent your gear from digging in and cartwheeling your airplane. Think about why a potential landing spot is in the condition that it is. Many times areas of long grass aren't mowed for a reason.... rocks? swamp?. Avoid them unless you are familiar with the area (and if you have a choice). Look beyond your landing spot. You may be proud of the approach and touchdown that you make... right up to the point that you skid into a drainage ditch. There are some great survival books and articles available. Read a couple then buy a survival kit to keep in the plane. Remember the name of the game is survival, not luxury, carry things that will keep you warm and dry. Don't forget to carry water on every flight. Keep in mind what happens to your landing surface through out the year and with weather changes. A field that you may repeatedly fly over and think that would make a great emergency landing spot may turn into an unseen swamp after even a light rain. In much of the Midwest those perfectly flat farm fields make great options to consider, but maybe not after periods of rain. Dark soil will retain more water than sandy soil. Those same fields that are soft and smooth in the summer may turn rock hard and rough as hell if there isn't any snow cover. Watch out for farm fields that were disked and chisel plowed in the fall but no snow cover to make them smooth. Perfect for ripping your gear off no matter what direction you land. In this situation I look for short grass without rocks because I know it hasn't changed. Here the rocks are in the ridges and the land that happens to be farmed isn't irrigated or farmed. Perfect landing spot this time of year would be a field with a cover crop of rye or wheat with an irrigation system. I know it will be smooth and rock free. The same idea can be transferred to about lakes. The lake that you fly by all summer long may turn into your best option once winter comes and it is frozen over. Watch for ice fishermen... if the lake can support their cars, chances are it will support your airplane. Avoid lakes without ice fisherman, this can mean the ice isn't thick enough or that it is a spring fed lake and doesn't freeze completely. Watch for snow drifts and touch down as softly as possible, remember braking action will be nill. Oh, and if you successfully land on a road, make the fire trucks and other vehicles move before you try to take off. Jim |
Yep. See the end of my post.
Oh, and if you successfully land on a road, make the fire trucks and other vehicles move before you try to take off. Jim "BTIZ" wrote in message news:c1X9f.311$zu6.186@fed1read04... IIRC the problem with the Louisiana C-210 incident.. was the subsequent departure from said narrow roadway... not the landing BT "Jim Burns" wrote in message ... Repost from Dec. 2004 for those who missed it back then. Forget about the airplane, concentrate on saving lives. Slowest possible foreward speed at touch down, no matter what the surface is. Maintain control and do not stall the aircraft! Falling out of the sky 30 feet above the ground will kill passengers faster than a controlled crash straight ahead. If you have a choice land into the wind and or uphill if possible. Reduce sources of ignition. Turn off fuel and electrical as much as possible. Prepare your passengers for impact after touchdown. Seatbelts tight, knees up, wrap your arms around your knees, face down into your thighs. Your objective is to keep your passengers and yourself: 1)alive 2)conscious and 3)mobil, in that order. Land "with" the rows, furrows, ditch, traffic etc. Do what ever it takes to reduce your chances of rolling or tumbling the aircraft. Keep the centerline of the aircraft pointed in the direction that you are traveling. Look for power poles, not lines. You're able to see poles a lot sooner than you'll ever see the lines. Do not forget about guy wires. Land "behind" the house rather than in front. The odds are better that the power lines enter from the front. If you try to land on a road and there is a house or building nearby, odds are 50/50 that there will be power lines crossing the road. Open a door prior to touchdown. A bent airframe, deep snow, or mud, may prevent you from opening it after you stop moving. Realize that freshly plowed fields not only have furrows but tend to be soft. A gear up landing (if possible) may prevent your gear from digging in and cartwheeling your airplane. Think about why a potential landing spot is in the condition that it is. Many times areas of long grass aren't mowed for a reason.... rocks? swamp?. Avoid them unless you are familiar with the area (and if you have a choice). Look beyond your landing spot. You may be proud of the approach and touchdown that you make... right up to the point that you skid into a drainage ditch. There are some great survival books and articles available. Read a couple then buy a survival kit to keep in the plane. Remember the name of the game is survival, not luxury, carry things that will keep you warm and dry. Don't forget to carry water on every flight. Keep in mind what happens to your landing surface through out the year and with weather changes. A field that you may repeatedly fly over and think that would make a great emergency landing spot may turn into an unseen swamp after even a light rain. In much of the Midwest those perfectly flat farm fields make great options to consider, but maybe not after periods of rain. Dark soil will retain more water than sandy soil. Those same fields that are soft and smooth in the summer may turn rock hard and rough as hell if there isn't any snow cover. Watch out for farm fields that were disked and chisel plowed in the fall but no snow cover to make them smooth. Perfect for ripping your gear off no matter what direction you land. In this situation I look for short grass without rocks because I know it hasn't changed. Here the rocks are in the ridges and the land that happens to be farmed isn't irrigated or farmed. Perfect landing spot this time of year would be a field with a cover crop of rye or wheat with an irrigation system. I know it will be smooth and rock free. The same idea can be transferred to about lakes. The lake that you fly by all summer long may turn into your best option once winter comes and it is frozen over. Watch for ice fishermen... if the lake can support their cars, chances are it will support your airplane. Avoid lakes without ice fisherman, this can mean the ice isn't thick enough or that it is a spring fed lake and doesn't freeze completely. Watch for snow drifts and touch down as softly as possible, remember braking action will be nill. Oh, and if you successfully land on a road, make the fire trucks and other vehicles move before you try to take off. Jim |
Here we go again | Roger | Piloting | 39 | April 7th 05 07:20 AM |
Iowa City Airport in the News | Dave S | Piloting | 0 | April 6th 05 10:24 PM |
WI airport closure | Mike Spera | Owning | 0 | March 9th 05 01:53 PM |
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! | Jay Honeck | Piloting | 16 | January 20th 04 04:02 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
