Dan, either we are miscommunicating or there is confusion...
At full throttle you cut in an extra X% of fuel flow, beyond 'max rich'... It is for cooling the exhaust valves at take-off power... Pull the throttle back, even a small amount, from full forward and you lose that extra X% of cooling... It is the same for carburetor and injected engines... The RPM at which you can run full throttle continuously is in the POH... Reduce power in climb by reducing the prop to that RPM and leave the throttle full forward and your engine will be a happy camper with cool valves... My API / CFI buddy still hasn't figured it out... On my Super Viking Take-Off RPM was limited to 5 minutes... But you can pull the RPM back to Max-Continuous power, still at full throttle, and run it all day and have the benefits of the valve cooling - hard on the fuel supply though... It is a separate metering circuit on the injector body for full throttle cooling... Pull the throttle back as little as a quarter inch and the valve cooling metering circuit shuts off... Leave the throttle retarded slightly in a long hot climb and you will likely have valve damage... Same thing applies to fixed pitch propellprs... Leave the throttle firewalled in climb for the cooling - assuming the POH allows it... As soon as you pull the throttle you lose the cooling... Now, be aware that as you climb at full throttle you are losing manifold pressure with each thousand feet gained, which is automatically reducing the engines output power, reducing the strain, and improving the cooling by allowing the mixture to go even richer than it was a thousand feet lower... Airplanes, at lower altitudes, are best climbed at full throttle... Funny how those dumb engineers at the tractor engine factory figured that out all on their own without any help from us god like pilots... cheers .../ denny |
Denny wrote:
: soon as you pull the throttle you lose the cooling... Now, be aware : that as you climb at full throttle you are losing manifold pressure : with each thousand feet gained, which is automatically reducing the : engines output power, reducing the strain, and improving the cooling by : allowing the mixture to go even richer than it was a thousand feet : lower... ... so leaning to a constant EGT in a climb is a great way to keep the *same* overrich mixture without going too rich. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() "Denny" wrote: Dan, either we are miscommunicating or there is confusion... At full throttle you cut in an extra X% of fuel flow, beyond 'max rich'... It is for cooling the exhaust valves at take-off power... Pull the throttle back, even a small amount, from full forward and you lose that extra X% of cooling... It is the same for carburetor and injected engines... The RPM at which you can run full throttle continuously is in the POH... Reduce power in climb by reducing the prop to that RPM and leave the throttle full forward and your engine will be a happy camper with cool valves... That's what I'm saying. It really has nothing to do with the RPM setting. In fact, the higher the RPM, the higher the horsepower and the higher the CHT. -- Dan C-172RG at BFM |
![]() "Denny" wrote in message oups.com... At full throttle you cut in an extra X% of fuel flow, beyond 'max rich'... It is for cooling the exhaust valves at take-off power... Pull the throttle back, even a small amount, from full forward and you lose that extra X% of cooling... It is the same for carburetor and injected engines... On our Turbo Saratoga's TIO540S1AD, the throttle is nowhere near full forward at takeoff when we set max manifold pressure. Full forward will significantly overboost. The throttle has to be continually moved forward as altitude increases, reaching full forward at critical altitude. Throttle-linked wastegate, no turbocharger governor. Stan |
That's true and it is because the cheap sob's who built your plane
refused to spend the money for proper boost control... That's a business decision unrelated to proper engine management... Assuming tha tthe fuel engineer knew his business you should have adequate fuel flow for valve cooling built into the fuel controller at part throttle... However, my experience is that turbo airplanes are hard on exhaust valve... denny |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 08:35 PM |
New Film: The Need For Speed - Going to war on drugs | Phil Carpenter | Military Aviation | 0 | July 23rd 03 07:43 AM |
