Mike Rapoport wrote:
"C J Campbell" wrote in message ... "Dave" wrote in message hlink.net... | I'd like to know how you get in icing when the temperature is +5. I have | never seen ice until the the gauge reads 0 or below. Icing occurs when liquid water freezes on an airplane surface that is below freezing. The aircraft may have been cooled earlier when it flew through a layer. Almost. Icing occurs when a below freezing aircraft encounters supercooled water. Supercooled water does not exist above 0C. True, but only partially correct. Above-freezing water will still freeze and cling to your below-freezing airframe. In fact, the preferred migration of liquid and of not-condensed water vapour is "from warm to cold". So moisture will migrate to the below-freezing airframe.... you can even get a thin sheet of ice forming in absolutely clear air, simply from the condensation of the water vapour. (similar to your glasses fogging when you come inside from the cold) Until such time as the airframe finally warms up to ambient and sheds the ice. |
Agreed , but my below freezing airframe's oat gauge will also read below 0.
"Icebound" wrote in message ble.rogers.com... Mike Rapoport wrote: "C J Campbell" wrote in message ... "Dave" wrote in message hlink.net... | I'd like to know how you get in icing when the temperature is +5. I have | never seen ice until the the gauge reads 0 or below. Icing occurs when liquid water freezes on an airplane surface that is below freezing. The aircraft may have been cooled earlier when it flew through a layer. Almost. Icing occurs when a below freezing aircraft encounters supercooled water. Supercooled water does not exist above 0C. True, but only partially correct. Above-freezing water will still freeze and cling to your below-freezing airframe. In fact, the preferred migration of liquid and of not-condensed water vapour is "from warm to cold". So moisture will migrate to the below-freezing airframe.... you can even get a thin sheet of ice forming in absolutely clear air, simply from the condensation of the water vapour. (similar to your glasses fogging when you come inside from the cold) Until such time as the airframe finally warms up to ambient and sheds the ice. |
![]() "Icebound" wrote in message ble.rogers.com... Mike Rapoport wrote: "C J Campbell" wrote in message ... "Dave" wrote in message hlink.net... | I'd like to know how you get in icing when the temperature is +5. I have | never seen ice until the the gauge reads 0 or below. Icing occurs when liquid water freezes on an airplane surface that is below freezing. The aircraft may have been cooled earlier when it flew through a layer. Almost. Icing occurs when a below freezing aircraft encounters supercooled water. Supercooled water does not exist above 0C. True, but only partially correct. Above-freezing water will still freeze and cling to your below-freezing airframe. In fact, the preferred migration of liquid and of not-condensed water vapour is "from warm to cold". So moisture will migrate to the below-freezing airframe.... you can even get a thin sheet of ice forming in absolutely clear air, simply from the condensation of the water vapour. (similar to your glasses fogging when you come inside from the cold) Until such time as the airframe finally warms up to ambient and sheds the ice. Which will happen before any of the theorized freezing takes place at least at the leading edges. Mike MU-2 |
Icebound wrote
Almost. Icing occurs when a below freezing aircraft encounters supercooled water. Supercooled water does not exist above 0C. True, but only partially correct. Above-freezing water will still freeze and cling to your below-freezing airframe. Not at any significant rate. The issue is heat transfer. If the water is not already at or below the freezing point, then it must shed excess heat and be cooled to the freezing point, or it will not freeze. Even if a droplet comes into contact with a subfreezing surface, most of it will be long gone before it can cool sufficiently. In fact, the preferred migration of liquid and of not-condensed water vapour is "from warm to cold". So moisture will migrate to the below-freezing airframe.... This makes no sense. you can even get a thin sheet of ice forming in absolutely clear air, simply from the condensation of the water vapour. (similar to your glasses fogging when you come inside from the cold) This is true, but wholly irrelevant. The accretion rate involved is so low as not to matter. Michael |
Descending through a thin icing layer | Wyatt Emmerich | Instrument Flight Rules | 70 | December 31st 03 05:17 AM |
FAA letter on flight into known icing | C J Campbell | Instrument Flight Rules | 78 | December 22nd 03 07:44 PM |
Supercooled Water - More on Icing | O. Sami Saydjari | Instrument Flight Rules | 50 | December 11th 03 01:20 PM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
snow and icing | Teacherjh | Instrument Flight Rules | 10 | December 10th 03 04:00 AM |
