Departing IFR at SMO w/ Tower Closed
Old November 8th 05, 02:47 PM
Tim
Default Departing IFR at SMO w/ Tower Closed
In most instances, ATC will NOT specify a DP. Executing the DP procedure,
at least for Part 91 flights, is pilot option. There is no requirement to
notify ATC.
SMO lies in critical airspace. There is no way SoCal is going to launch
an IFR departure without very specific instructions.
It is so critical that a few years ago a Kingair elected to
circle-to-land Runway 3 after the tower was closed and they ended up
with a loss of separation with an air carrier departure out of LAX that
had been turned northwest over the ocean but too close to SMO.
Old November 9th 05, 03:49 AM
Ron Rosenfeld
notify ATC.
You've mentioned this a few times.
What are those specific instructions when departing IFR from SMO with the
tower closed?
That was one of the questions the OP posed.
If the TRACON is issuing radar vectors off the ground, then, as I quoted
from the AIM, that would supersede any ODP. But ATC is then responsible
for obstacle clearance, of course.
What was the KingAir's clearance?
Whether it was a problem (i.e. who buys the 'deal') for the KingAir pilot
would depend on his specific clearance.
Old November 9th 05, 04:01 AM
Roy Smith
How can they issue radar vectors before you're in radar contact?
Old November 9th 05, 11:47 AM
Tim
They know they will have radar contact within a "reasonable" period of
time after takeoff. KMRY is the same way with the radar site several
miles from the airport.
It's all a matter of how the region and the facility determine what will
work for their radar coverage and airspace.
Old November 9th 05, 11:56 AM
Ron Rosenfeld
This has come up before. If SMO is Class E surface area when the tower is
closed (and it probably is), then the heading to fly after takeoff can be
specified by ATC. Maybe there is a DVA. "After takeoff", of course,
refers to leaving 400' AGL on runway heading.
In previous discussions, there has been some confusion as to how the pilot
knows that the vector should be considered a "radar vector" and I don't
think there's been a real clear-cut answer. Certainly happens at big city
airports; and it wouldn't surprise me if that was in effect at SMO in the
shadow of LAX.
Old November 9th 05, 03:33 PM
Tim
SMO is Class E at 700 feet agl when the tower is closed.
So far as I know there are no DVAs other than at some USAF facilities.
SMO would be "de facto" DVA to the west because of the ocean. To the
east, there are tall buildings and some mountains although the mountains
are easily avoided with a vector.
Old November 10th 05, 11:53 PM
Steven P. McNicoll
"Roy Smith" wrote in message
Why not? The aircraft's position is known to a high degree of accuracy.
Old November 9th 05, 11:44 AM
Tim
notify ATC.
tower closed?
I don't know. I know the airspace constraints of that location but, as
I said in a previous post, I have not flown IFR out of KSMO.
I know. And, he probably would get better information by giving SoCal
TRACON a call.
Yes, but...there are many worse locations where they vector below the
MVA and do not, in fact, assure any obstacle clearance below MVA. It is
a very obscure area.
Don't recall the specifics other than the tower was closed and ATC
bought the "deal," but in the press release the FAA claimed that 3 miles
or 1,000 was merely a guideline.
Old November 9th 05, 07:39 PM
Ron Rosenfeld
Obscure?
7110.65 5-6-1c and 5-6-3 seem pretty clear on when radar vectors below MVA
are allowed.
At which facilities is ATC issuing vectors and NOT assuring obstacle
clearance?
How are they communicating to the pilot that these vectors do not assure
obstacle clearance?
If, in fact, they are issuing vectors without assuring obstacle clearance,
or without actively soliciting the pilot concurrence with these vectors,
then this seems to me to be a dangerous practice, and not in accord with
ATC published procedures. It should be corrected.
tower closed?
It seems to me that you're just guessing at what might be going on. You
may well be correct, but the information I have gleaned from your posts
does not seem to me to be terribly useful.
Should you tell Tower you're departing IFR John Clonts Instrument Flight Rules 75 October 4th 05 04:56 PM
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
New Oshkosh Tower Jay Honeck Piloting 20 November 25th 03 05:35 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Home Built 4 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Jay Honeck Owning 2 July 24th 03 09:11 PM
