Lost comms after radar vector
Old January 30th 04, 01:16 AM
Ron Garrison
"John R Weiss" wrote in message
news:_biPb.92428$5V2.241427@attbi_s53...
"Gary Drescher" wrote...
Sure, but if the fix in question is your destination airport and your
clearance limit, then you might have equipment that lets you navigate to
that fix by a published approach to the airport (say, via an off-field
NDB
or VOR), but not have any way to identify the fix as a holding fix.
If you can navigate to a place once, you can do it again. If your
navigational
ability is so degraded that you cannot find your position via VOR/DME,
VOR/VOR,
VOR/NDB, or similar means, then you probably should declare an emergency
and
navigate any way you can to any place you can identify.
I disagree that the ability to navigate to a place once means you can do it
again. AIM 1-1-9.b clearly states that localizer goidance is only valid out
to 35 degrees each side of the course, and that the back course is
specifically not to be used for guidance unless a back course procedure
exists.
Assume a 90kt holding speed and an NDB colocated with the localizer antenna
to identify the fix. If there were a 20kt wind blowing across the holding
course and you did not correct for it in the hold, then 3 minutes later when
you begin the inbound segment of the hold you will have been blown about 1
mile to the left or right of where you want to be. At 1.5 miles from the
airport, that is just about 35 degrees off of the inbound course. Any
stronger wind, or unfavorable errors flying the pattern, and the localizer
may be giving incorrect guidance.
[I'm not trying to upset anyone with this admitadly academic exercise, but
as "homework" after passing my last BFR I was given the friendly advise to
go a read a page a day from the AIM. I found the section on localizers
interesting because I had previously had the incorrect idea in my head that
they are a special form of VOR. They use the same frequencies, but operate
on a totally different principal and their behavior outside of that 35
degree window can be quite bizarre.]
Old January 31st 04, 11:39 PM
John R Weiss
"Ron Garrison" wrote...
exists.
All your information after the second sentence is good. However, it does not
bear directly on your first statement.
Holding over an NDB is a standard, practiced procedure even without any backup
NAVAIDs. Hopefully, if you are holding in IMC over an NDB, you have at least
some idea of the wind, and can make an initial correction on your first outbound
leg. If you don't, you must make a larger correction on the inbound course, but
you can still navigate back to the NDB.
If you are using other NAVAIDs as backups or crosschecks, that does not mean you
ignore your primary NAVAID. Assume you are holding over that NDB collocated
with the LOC. If your planned inbound course in the hold is close to the LOC
front course, you can use the LOC as a valid crosscheck, and possibly use it to
fine-tune your inbound heading in the crosswind. However, if your inbound
course in the hole was NOT coincident with the LOC course, you simply would not
choose to use the LOC as a backup. Still, you can use the NDB -- your primary
NAVAID -- and get back to the NDB.
Flying good IFR in IMC in "ideal" conditions (no wind, no turbulence, no
vertigo, no emergencies) requires practice. Flying in less-than-ideal
conditions is more challenging, and takes more practice and experience. As you
build on your experience, you will discover what YOU can do in specific
situations.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Lost comm altitude? Roy Smith Instrument Flight Rules 12 January 11th 04 12:29 AM
Ham sandwich navigation and radar failure David Brooks Instrument Flight Rules 47 December 31st 03 12:15 AM
Marine Radar in a plane? Jay Honeck Home Built 31 August 13th 03 06:56 PM
