![]() "Wizard of Draws" wrote in message news:BF96C057.43EB4%jeffbREMOVE@REMOVEwizardofdraw s.com... So...do I tell a briefer to note that I have a VFR GPS and will the controllers take note, sending me direct, off airways? Will it make any difference to them at all? Given the fact that nearly everyone has one nowadays, will they assume I have a GPS even if I don't indicate it? If you file off airways and if radar monitoring can be provided and if specific routing is not required for your departure/destination airport then you'll get direct routing. Indicating you have a VFR GPS makes no difference. |
![]() "Steven P. McNicoll" wrote in message news ![]() "Wizard of Draws" wrote in message news:BF96C057.43EB4%jeffbREMOVE@REMOVEwizardofdraw s.com... So...do I tell a briefer to note that I have a VFR GPS and will the controllers take note, sending me direct, off airways? Will it make any difference to them at all? Given the fact that nearly everyone has one nowadays, will they assume I have a GPS even if I don't indicate it? If you file off airways and if radar monitoring can be provided and if specific routing is not required for your departure/destination airport then you'll get direct routing. Indicating you have a VFR GPS makes no difference. That seems to be an overly broad statement. I have put "VFR GPS" in Remarks when filing /U for an off-airways (random) route and had controllers specifically refer to using my VFR GPS to proceed direct to an intersection. Whether they should have done so is another issue. But is sure seemed to make a difference. |
"Stan Prevost" wrote:
That seems to be an overly broad statement. I have put "VFR GPS" in Remarks when filing /U for an off-airways (random) route and had controllers specifically refer to using my VFR GPS to proceed direct to an intersection. Whether they should have done so is another issue. But is sure seemed to make a difference. Your non-IFR GPS has intersections in it? What model is it? Ron Lee |
On Thu, 10 Nov 2005 22:36:32 -0500, Wizard of Draws
wrote: My new Airmap 2000c, which was the reason for this thread, has them. Vintage Garmin 195, updated software and database, has them, and approaches as well. |
approaches as well. when was the last time you updated the database? Gerald |
On Fri, 11 Nov 2005 18:25:42 GMT, Gerald Sylvester
wrote: Vintage Garmin 195, updated software and database, has them, and approaches as well. when was the last time you updated the database? Gerald I think I have April or May. I'll probably do another before the year is up. $35 each time. |
Gerald Sylvester wrote:
Vintage Garmin 195, updated software and database, has them, and approaches as well. when was the last time you updated the database? Gerald I updated my 195 this past June. It has everything so far as I can determine. They had to update the firmware a couple, or so, years ago to handle the ever increasing Jeppesen nav databast. |
Ron Lee wrote:
Your non-IFR GPS has intersections in it? What model is it? My Garmin GPSMAP 196 has intersections in it. I sure wish it had airways in there by name too, that would be handy. |
Ron Lee wrote:
"Stan Prevost" wrote: That seems to be an overly broad statement. I have put "VFR GPS" in Remarks when filing /U for an off-airways (random) route and had controllers specifically refer to using my VFR GPS to proceed direct to an intersection. Whether they should have done so is another issue. But is sure seemed to make a difference. Your non-IFR GPS has intersections in it? What model is it? Ron Lee Every Garmin handheld I have owned, 195, 295, and 296, have a complete Americas Jeppesen LNAV database; all intersections, waypoints, airports, runway layout for IFR airports, all communications and nav frequencies, distance to FAA transmitter, and so forth. The approach is abbreviated but all the fixes are in the database to build the complete approach as a flight plan. The terrain database of the 296 is essentially the same as any full-press EGPWS I have used. It just doesn't have the aural warnings. |
