"Steven P. McNicoll" wrote:
"Frank Ch. Eigler" wrote in message ... ... and as with flying in icing with substandard equipment, you will face all the risks in case something goes wrong. What are the risks of flying IFR with a VFR GPS? What happens when these VFR GPS's drop reception of all but one or two satellites? Do they instantly provide a RAIM message? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "Peter R." wrote in message ... What happens when these VFR GPS's drop reception of all but one or two satellites? Do they instantly provide a RAIM message? I don't know? Is it a problem if they don't? |
"Peter R." wrote in message ... What happens when these VFR GPS's drop reception of all but one or two satellites? Do they instantly provide a RAIM message? I don't know? Is it a problem if they don't? If the pilot were using the unit for primary navigation in IMC and the unit did not warn the pilot of too few satellites to be able to calculate position, would that be a problem? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "Peter R." wrote in message ... If the pilot were using the unit for primary navigation in IMC and the unit did not warn the pilot of too few satellites to be able to calculate position, would that be a problem? No. |
"Peter R." wrote in message ... If the pilot were using the unit for primary navigation in IMC and the unit did not warn the pilot of too few satellites to be able to calculate position, would that be a problem? No. Why? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() "Peter R." wrote in message ... Why? Because the properties of a "problem" are not present. Do you disagree? If so, why? |
"Peter R." wrote in message ... Why? Because the properties of a "problem" are not present. snip Primary navigation (the VFR GPS) is no longer reliable, the aircraft is IMC, and the pilot is unaware that the unit is no longer reliable. Those are not properties of a problem? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
"Peter R." wrote:
"Steven P. McNicoll" wrote: "Peter R." wrote in message ... What happens when these VFR GPS's drop reception of all but one or two satellites? Do they instantly provide a RAIM message? I don't know? Is it a problem if they don't? If the pilot were using the unit for primary navigation in IMC and the unit did not warn the pilot of too few satellites to be able to calculate position, would that be a problem? You should note that if you lose lock (too few satellites) then your display will start flashing (or portions of it). That is not RAIM which determines if you have a signal error. Ron Lee |
Ron Lee wrote:
You should note that if you lose lock (too few satellites) then your display will start flashing (or portions of it). That is not RAIM which determines if you have a signal error. Just to clarify, are you saying that a *VFR* GPS's screen flashes when the GPS loses the required number of satellites for position calculation and that error is not a result of built-in RAIM? -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
"Peter R." wrote: Ron Lee wrote: You should note that if you lose lock (too few satellites) then your display will start flashing (or portions of it). That is not RAIM which determines if you have a signal error. Just to clarify, are you saying that a *VFR* GPS's screen flashes when the GPS loses the required number of satellites for position calculation and that error is not a result of built-in RAIM? When my hand held Garmin loses enough sats for position calculation, I receive an alarm on the unit (both visual and audible). I believe that RAIM performs a checksum to verify the integrity of the data received from the sats. Hand held devices are indeed missing this functionality, but it makes no difference for enroute, in my opinion. JKG |
