"Peter R." wrote:
Ron Lee wrote: You should note that if you lose lock (too few satellites) then your display will start flashing (or portions of it). That is not RAIM which determines if you have a signal error. Just to clarify, are you saying that a *VFR* GPS's screen flashes when the GPS loses the required number of satellites for position calculation and that error is not a result of built-in RAIM? Portions do such as position. Take your favorite handheld and look at various displays. Note that some will flash until you get a solid GPS lock. Ron Lee |
Ron Lee wrote:
"Peter R." wrote: Ron Lee wrote: You should note that if you lose lock (too few satellites) then your display will start flashing (or portions of it). That is not RAIM which determines if you have a signal error. Just to clarify, are you saying that a *VFR* GPS's screen flashes when the GPS loses the required number of satellites for position calculation and that error is not a result of built-in RAIM? Portions do such as position. Take your favorite handheld and look at various displays. Note that some will flash until you get a solid GPS lock. my handheld keeps updating and displaying as though I kept going straight ahead at the same exact speed and course as when it lost the lock. So there is NO warning at all. Gerald |
