PDA GPS software Which one??
Old November 10th 05, 08:24 AM
MC
Default PDA GPS software Which one??
Alex Shoemack wrote:
The thing is, I have no licence from
Airservices Australia yet so I hope that works out, if so well all is
good If not my product becomes slightly crippled in that the user has
to put in all the waypoints manually Or I find another data source and I
will likely include NAIPS access
Alex, make sure that you're sitting down when ASA give you a quote
for their electronic data.
Old November 10th 05, 01:28 PM
Coop
The thing is, I have no licence from Airservices Australia yet so I
hope that works out, if so well all is good If not my product
becomes slightly crippled in that the user has to put in all the
waypoints manually Or I find another data source and I will likely
Hey guys! I've come across a new instrument to assist with navigational
challenges- better than GPS or PDA systems by far.
It comes standard with the largest database of Australian waypoints I've
ever encountered.
The display is extremely realistic and rendering in 3-dimensional colour
graphics is available at the greater magnifications.
The range of display magnifications is almost infinite- far beyond what
is required by most Private Pilots, and sufficient for the most
demanding applications (The Space Shuttle had at least one of these
installed for all flights.)
Any visible waypoint can be selected by simply pointing at it on the
display.
The memory requirements are negligible- and power consumption is
extremely low (although it can rise if "open architecture" is used- this
is an option on some models).
There are literally no buttons. The display is set up so that it becomes
active as soon as the aircraft engine is started, and all functions are
engaged by simply examining the display and pointing at the required track.
The display remains perfectly oriented irrespective of the attitude of
the aircraft, although it has a fixed reference which cannot be changed.
You might think with such demanding specifications that this is an
expensive instrument- but they are quite affordable- although some
regular maintenance is required.
I have found that a disadvantage of the available display magnification
range is that at the larger magnifications the scroll rate becomes
unacceptably rapid.
It is, unfortunately, available only in VFR versions. However, if IFR
conditions are encountered the display notifies the pilot immediately.
It is known as the Wide INertial Device for Orientation of Waypoints
Or WINDOW, for short.....:-)
Coop
g,d,r
Old November 10th 05, 02:53 PM
Kevin Black
The last time I tried to buy one of those with attached hardware, it was
out of my price range - sigh..... And the running costs were a little
over the top as well...
Cheers,
Kevin
Flight Planning Software Chris G. Piloting 22 July 4th 05 06:33 PM
[!] Russian Arms software sale Naval Aviation 0 December 18th 04 05:51 PM
Free Flight Planning Software Dean Wilkinson Piloting 20 September 25th 04 03:38 AM
Free Flight Planning Software Dean Wilkinson Products 0 September 18th 04 10:44 PM
Next: Aviation Map software Toks Desalu Piloting 5 May 24th 04 07:55 PM
