I'm no expert (still in training, actually) but it seems to me he wasn't
cleared to a hold. He was cleared to a fix. He was also told to expect to continue as filed afterward. It would seem that he therefore doesn't require an EFC time... Once he reaches the fix, he should be able to continue as filed. Am I missing something? Newps wrote in news:sgTSb.153540$nt4.710088@attbi_s51: Ross wrote: When given a clearance to a point enroute that is not your destination you should also receive an EFC - just in case of lost comms - and ask for one if not provided. You should refuse holding instructions without an EFC. Holding instructions without an EFC constitutes an incomplete clearance. |
Judah wrote:
I'm no expert (still in training, actually) but it seems to me he wasn't cleared to a hold. He was cleared to a fix. And what was he supposed to do when he got to that fix? He was told to EXPECT further clearance, but wasn't yet cleared past the fix. So lacking a Star Trek transporter device or the ability to hover, he would have to hold. He was also told to expect to continue as filed afterward. It would seem that he therefore doesn't require an EFC time... Once he reaches the fix, he should be able to continue as filed. In a lost comm situation, yes, because the lost comm rules say (in part) that you should proceed with the clearance you were told to expect. But under normal circumstances, if he got to the fix before being issued another clearance, he's got to hold. |
![]() Judah wrote: I'm no expert (still in training, actually) but it seems to me he wasn't cleared to a hold. He was cleared to a fix. In a nonradar environment that's how ATC separates airplanes. When you get to the fix you have to know what to do. Do you then enter holding or do you just continue on your route. If you receive no further instructions you must enter holding. But for how long? That's why you always get an EFC time. He was also told to expect to continue as filed afterward. It would seem that he therefore doesn't require an EFC time... Once he reaches the fix, he should be able to continue as filed. Being told there's no delay expected is the same as an EFC time. If you lose comm you don't hold at that fix you just keep going. |
![]() "Judah" wrote in message ... I'm no expert (still in training, actually) but it seems to me he wasn't cleared to a hold. He was cleared to a fix. He was also told to expect to continue as filed afterward. It would seem that he therefore doesn't require an EFC time... Once he reaches the fix, he should be able to continue as filed. Am I missing something? Continue past the clearance limit? Once he reaches the fix he enters a standard hold on the inbound course. |
![]() "Steven P. McNicoll" wrote in message ink.net... Continue past the clearance limit? Once he reaches the fix he enters a standard hold on the inbound course. And holds for how long without an EFC? Chip, ZTL |
![]() "Chip Jones" wrote in message ink.net... And holds for how long without an EFC? As long as he chooses. |
![]() "Steven P. McNicoll" wrote in message ink.net... "Chip Jones" wrote in message ink.net... And holds for how long without an EFC? As long as he chooses. Which begs the question, why hold at all? A supe of mine who has several thousand hours as a pre-strike freight dog told me he'd make one turn in the pattern and then continue on (assuming IMC/ lost comm etc), but he couldn't defend the "why" of it. These non-radar paper-stop rules don't seem to stand on their own very well, IMO. Chip, ZTL |
Judah wrote in message . ..
I'm no expert (still in training, actually) but it seems to me he wasn't cleared to a hold. He was cleared to a fix. He was also told to expect to continue as filed afterward. It would seem that he therefore doesn't require an EFC time... Once he reaches the fix, he should be able to continue as filed. I think you've got it. "no delay expected" is the same as "expect further clearance before you get there" ie, your EFC time is effectively your flight time to the fix. The catch in this case, if I remember my WNY geography correctly, is that Paul filed expecting to head WNW from Batavia to Buffalo. The clearance he got had him heading SE. His filed route had no provision for getting him from his new clearance limit, to his filed route. But I think Paul's interpretation "fly from GEE to BUF" is perfectly reasonable. The airway *is* direct. It would be nice to have this confirmed, but I wouldn't bet a penny that some ATCS who tried a similar procedure said something like "expect further clearance via direct BUF then as filed", only to have the pilot mishear, take off, and fly direct BUF screwing up a bunch of separation in the process. But Paul could make that query in future if he wants to be certain. I think Roy Smith is exactly correct about what Paul got and why he got it -- and it's actually a valuable negotiating technique to ASK for a clearance limit like that (doesn't have to be a VOR, can be an intersection or a VOR deg-dist) if you're below radar coverage and having trouble getting your IFR clearance. Cheers, Sydney |
Seems to me the easiest solution in this case is to carry a handheld and some spare batteries. ![]() Well, maybe. First see a recent post by Roy Smith wrt how useful he and a friend found a handheld to be when they experienced a radio failure in busy NYC airspace (an area with generally very good radio reception, though busy frequencies). At a minimum for a handheld to be useful, you need a headset adaptor and a cable so that the duckie antenna can be situated on a window, preferably a connection to an external antenna. Even with a headset adaptor and an external antenna connection and cable, personally if I were flying single-pilot IFR in rough IMC, digging out the handheld and setting it up would be pretty low on my list of priorities. But perhaps that's just me, and other pilots are more capable of aviating and navigating while digging stuff out and setting it up. Cheers, Sydney |
No SID in clearance, fly it anyway? | Roy Smith | Instrument Flight Rules | 195 | November 28th 05 10:06 PM |
Lost comms after radar vector | Mike Ciholas | Instrument Flight Rules | 119 | January 31st 04 11:39 PM |
Lost comm altitude? | Roy Smith | Instrument Flight Rules | 12 | January 11th 04 12:29 AM |
Picking up a Clearance Airborne | Brad Z | Instrument Flight Rules | 30 | August 29th 03 01:31 AM |
Big John Bites Dicks (Security Clearance) | Badwater Bill | Home Built | 27 | August 21st 03 12:40 AM |
