KLN94 LOC DME Source
Old February 1st 04, 05:14 AM
Doug
I would want to "stop waypoint sequencing", so the unit doesn't
sequence to the next waypoint in the middle of your approach. Make the
"Ixxx" the active waypoint, then put the unit in OBS (or HOLD) mode.
Putting the unit in OBS mode stops waypoint sequencing. Dial in the
localizer track as read off the plate. This will give you a track line
to the localizer and beyond it. It is usually easiest to have the Ixxx
waypoint in the route.
"Richard Kaplan" wrote in message ws.com...
"Greg Esres" wrote in message
Anyone have a tip as to the best way to enter the LOC DME source on
the KLN94?
Set up a flight plan or go direct and treat it just like any other waypoint,
but be sure to start it with an I, i.e. IAFJ.
Old February 1st 04, 05:16 AM
Greg Esres
Good thought, Doug.
4130 sheet source Leon McAtee Home Built 7 May 2nd 04 08:29 PM
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 02:13 AM
Tapered Rod Gear Leg Source Dick Home Built 3 January 13th 04 10:10 PM
Source for copper crush gaskets??? Jim Home Built 2 August 22nd 03 09:44 PM
Online source for POH Jim Instrument Flight Rules 3 July 1st 03 06:56 PM
