Gerald Sylvester wrote:
I can definitely see how a VFR GPS is useful when flying enroute and VMC with loads of VOR's for use as a backup (err, primary navigation). To do it, single pilot, in IMC, just has many single point failures or where you have backups but requires a lot of work to get positively established/stabilized again. How does a handheld GPS have more SPOFs than a panel mount IFR certified GPS? I would submit it has less because with a handheld electric power is no longer a single point of failure like it is with a panel mount (assuming you have a power adapter to plug it in and fresh batteries in case you lose electric power). The only legitimate argument that can be made is that the panel mount GPS has an external antenna and the handheld relies on one mounted on the windscreen or the unit itself. I've been flying with a handheld GPS for almost ten years an have only lost signal once in flight. And that was only for less than a minute. Since I didn't do anything to get the signal back, I don't think it had anything to do with antenna placement. Now, if we're talking about precision GPS approaches, that's a different story. But enroute navigation (and possibly even non-precision GPS approaches) should be just as safe with a handheld as a panel mount. -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "If you have to ask, you won't understand." |
Mark T. Dame wrote:
Now, if we're talking about precision GPS approaches, that's a different story. But enroute navigation (and possibly even non-precision GPS approaches) should be just as safe with a handheld as a panel mount. You will usually have as good of accuracy with a hand-held (with an external antenna, but you lack the interity because you don't have approach RAIM. Would this ever matter? It depends upon the volume of operations. For you personally, the RAIM-hole day may never occur when you're using your hand-held for an RNAV IAP. Since there aren't any precision RNAV IAPs, other than LPV (which requires WAAAS) I fail to see your distinction between precision and non-precision. |
Ron Lee wrote:
wrote: A RAIM hole would not affect position accuracy as long as there is no GPS signal error...which are rare. Ron Lee True, but that isn't the FAA or ICAO certification view of it all. The folks who drive those standards are pretty sharp industry engineers, not just FAA autocrats. |
