#31
On Fri, 04 Nov 2005 11:21:44 GMT, "Ian Donaldson"
wrote: Never wrassle with a pig, You will both get dirty but the pig will like it! Ian You know, I strongly suspect the "pig" that loves to comment on every post, is probably a fat, degenerated wheelchair bound do nothing. With an oxygen canula around his face, at a computer that hasn't been seen for over a decade, most probably equipped with a 2400 baud modem. From that throne, he spats out his drivel, and entertains himself trying to rile anyone he can. And the result is this newsgroup is just about dead. The number of posts are in the single digits on a daily basis. I just wonder if it's even possible to have a decent group like this and keep that trash out of it. |
#32
Jason Grass wrote:
On Fri, 04 Nov 2005 11:21:44 GMT, "Ian Donaldson" wrote: Never wrassle with a pig, You will both get dirty but the pig will like it! Ian You know, I strongly suspect the "pig" that loves to comment on every post, is probably a fat, degenerated wheelchair bound do nothing. With an oxygen canula around his face, at a computer that hasn't been seen for over a decade, most probably equipped with a 2400 baud modem. From that throne, he spats out his drivel, and entertains himself trying to rile anyone he can. And the result is this newsgroup is just about dead. The number of posts are in the single digits on a daily basis. I just wonder if it's even possible to have a decent group like this and keep that trash out of it. One shouldn't post one's autobiography in a public forum such as this. Matt |
#33
On Mon, 07 Nov 2005 22:39:28 GMT, Matt Whiting
wrote: Jason Grass wrote: On Fri, 04 Nov 2005 11:21:44 GMT, "Ian Donaldson" wrote: Never wrassle with a pig, You will both get dirty but the pig will like it! Ian You know, I strongly suspect the "pig" that loves to comment on every post, is probably a fat, degenerated wheelchair bound do nothing. With an oxygen canula around his face, at a computer that hasn't been seen for over a decade, most probably equipped with a 2400 baud modem. From that throne, he spats out his drivel, and entertains himself trying to rile anyone he can. And the result is this newsgroup is just about dead. The number of posts are in the single digits on a daily basis. I just wonder if it's even possible to have a decent group like this and keep that trash out of it. One shouldn't post one's autobiography in a public forum such as this. Matt F U |
#34
Tom Kudro wrote:
On Mon, 07 Nov 2005 22:39:28 GMT, Matt Whiting wrote: Jason Grass wrote: On Fri, 04 Nov 2005 11:21:44 GMT, "Ian Donaldson" wrote: Never wrassle with a pig, You will both get dirty but the pig will like it! Ian You know, I strongly suspect the "pig" that loves to comment on every post, is probably a fat, degenerated wheelchair bound do nothing. With an oxygen canula around his face, at a computer that hasn't been seen for over a decade, most probably equipped with a 2400 baud modem. From that throne, he spats out his drivel, and entertains himself trying to rile anyone he can. And the result is this newsgroup is just about dead. The number of posts are in the single digits on a daily basis. I just wonder if it's even possible to have a decent group like this and keep that trash out of it. One shouldn't post one's autobiography in a public forum such as this. Matt F U Oh, there are two of you. Matt |
#35
Jason et al
I know a lot about the Harmon Rocket II. I built and am flying one. The cockpit is 31" wide whereas the RV4 is 27" wide. The cockpit has been stretched 4" from the rear spar to the rear seatback. The instrument panel has been moved forward from the 4 - I like it better. You can have the seats built to your specs and sit on the floor if you don't want to see where you're going. You can't see over the nose at the highest seating position anyway. Kinda like I would imagine it would be taxiing a P51. As for the wing - it is still Van's original RV4 wing, tested static to 14 G's. It would be strong enough without shortening it. I don't see it being a problem since I have seen RV8's a lot heavier than my Rocket which is 1174 pounds dry. I have owned and flown both, the 4 on a couple long trips. I wouldn't trade the Rocket for anything but still like the 4 - you don't get in it - it's more like you put it on. As for G loads - there is a pro aerobat pilot flying a Rocket. I'm 6' tall and weigh 225 and am very comfy in it. Hi Jerry. Man this thread deteriorated quickly didn't it. Seems there are a lot of people looking for confirmation. I forget - I haven't posted here for a long time - am I supposed to top post or bottom.......... jim "Jason Grass" wrote in message ... Does anyone here know much about the Harmon Rocket II? I've been looking at it, and it concerns me in the fact that the cockpit demensions look a little snug. It has enough room in width, but the distance between the front and back seat seems too close, as does the distance of the instrument panel from the front seat pilot. Also, in looking at pictures of it, pilots seem to have their heads right up against the top of the canopy. Is John Harmon a short guy? I suspect it was designed by someone not so tall. I guess it would be nice to go sit in one somewhere, but that's not always easy to find. And I wonder if the wing is strong enough. His webiste says he did nothing to the RV-4 wingspar to strengthen it. He only shortened it to to reduce the bending moment on it, and reduced the rib spacing. Then it says he sand bagged the wing to 6 G's. 6 G's isn't all that much for an ultimate load test. So I'm a bit leery of the design. I wanted to build one, but after doing a little research, I'm turned off by what I've found out. |
#36
![]() Jim wrote: ... Man this thread deteriorated quickly didn't it. Seems there are a lot of people looking for confirmation. In that regard, do you care to comment on the earlier assetion that the tail is too short, so that the nose drops precipitously if the engine quits? I forget - I haven't posted here for a long time - am I supposed to top post or bottom.......... Bottom Post. :-) -- FF |
#37
![]() wrote in message oups.com... Jim wrote: ... Man this thread deteriorated quickly didn't it. Seems there are a lot of people looking for confirmation. In that regard, do you care to comment on the earlier assetion that the tail is too short, so that the nose drops precipitously if the engine quits? I forget - I haven't posted here for a long time - am I supposed to top post or bottom.......... Bottom Post. :-) -- FF To begin with by deteriorated I meant went off on a tangent instead of talking about the flying qualities of the HR2. No offense intended to anyone. I guess I got in a little late - I didn't see anything about a short tail or the nose dropping. I haven't experienced either one of those. The tail being short is subjective - it seems fine to me. It's four inches longer from the rear spar back than the -4 and -6 (of which I've owned both). The engine has never quit on me but I have pulled the power and it does glide fairly steep but I believe that is due to an 80" prop out front acting like a piece of plywood face into the wind. I'm not a hotshoe F15 pilot or a multi-thousand hour airline pilot but I have managed to put 65 hours on an HR2 that I built by myself (wife included) without crashing so it must not be too hard to handle. I have only flown a 150, 172, 182, Pacer, Cub, Champ, RV4, and RV6 but my HR2 is the sweetest one yet on takeoff, climb, cruise, aerobatics, and landing. In fact to me the only negative is fuel usage if you want to go fast, and you can feel the heavy nose at extreme forward cg (not a problem to me). If a person wants to find fault with the HR2 without flying one and therefore decides not to build one I feel sorry for them and what they will be missing. Jim 2005 HR2 |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
IF I HAD A ROCKET LAUNCHER | X98 | Military Aviation | 7 | August 13th 04 09:17 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Rocket Launching of Gliders | Jim Culp | Soaring | 0 | September 7th 03 06:52 PM |
