Probably OK. However, if you are really concerned, one option is to put
a Schottky diode (of sufficient current capacity) in line. It will introduce approximately 0.5v of voltage drop over the whole range of supplied voltage. Larry "Bill Daniels" wrote in message : Lithium Ion rechargeables seem to have recently seen a 50% or so price drop. A 4-cell, 14.8V, 8AH with charger and mounting plate can be had for $169.99 (USD). These are basically long endurance laptop batteries. This is still too much for me given that a SLA with the same capacity is around $25 but the downward price trend is hopeful. Someone contemplating a transponder, electric T&B and other juice hungry gadgets in a $100,000+ glider might see Li-Ion as a possibility now. Beyond price, my concern is voltage. 4-cell Li-Ion packs produce 14.8V and a detail in the spec sheet admits that a new, fully charged pack might produce 16.2V into a high resistance load. My avionics manuals say 16V max. Is that 0.2V overvoltage likely to be a problem? Bill Daniels |
I have two NiMh packs in my Nimbus.
One replaces a 7.5 Ah SLA, its 2/3 the size of the SLA, half the weight and its capacity is nominally 9 Ah but it delivers more like 10.5 given my discharge curve. The other is a replacement for the lead brick of an 18 AH SLA in the nose, weighs 1/2 the 18 AH, nominally rated at 13 Ah and delivers about 16. Yes I have a switchable diode to ensure I don't over volatage the panel when the cells are topped right off. I did have a small problem with a Colibri logger that went haywire on 17 volts ( in spite of what the , now corrected, manual said ) Charging also requires a microprocessor controlled specialised charger. The batteries perform extremely well over a wide temperatire range. I have saved about 5 kg of weight right in the nose of the ship. The extra voltage is good for the radio range. The current capacity and voltage of the system spins up my 14v Horizon in about 90 seconds ( 3 turns before going into cloud if left late ) |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
60 years from Battle of Tali-Ihantala June-July 1944 - which decidedthe fate of Finland | Jukka O. Kauppinen | Military Aviation | 1 | June 29th 04 03:00 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
