Problem Best Electronic E6B?
Old November 14th 05, 04:41 AM
Peter Duniho
Default Problem Best Electronic E6B?
"Andrew Sarangan" wrote in message
Now I am curious. What kind of calculations can you do except divide by
60?
Now *I'm* curious, did you not realize how it is an E6B accomplishes "divide
by 60"?
The core of an E6B is simply a circular slide rule. As with a basic linear
slide rule, you have two logarithmic scales that allow you to perform any
multiplication or division you like.
The "60" is highlighted, and the regular logarithmic scale is paralleled by
a conversion from minutes to hours. This makes time-speed-distance
calculations even easier. But they don't restrict your use of the slide
rule.
Pete
Old November 15th 05, 03:31 AM
Andrew Sarangan
You are correct. Thanks for pointing that out.
Avionics (Radio Problem) Narrowed Down... I Think??? three-eight-hotel Owning 40 November 22nd 05 02:19 PM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Future Electronic Attack Aircraft Mike P. Military Aviation 1 April 22nd 04 01:30 AM
Garmin fixes moving waypoint problem -- almost Jon Woellhaf Instrument Flight Rules 6 November 28th 03 05:29 PM
Electronic Ignition Andre Home Built 1 September 5th 03 06:15 PM
