PDA GPS software Which one??
Old November 14th 05, 09:02 PM
Robert M. Gary
Default PDA GPS software Which one??
I've downloaded PocketFMS for my PC (haven't figure out yet how to get
it on my PDA). To be honest, I brought it up and tried to play with it
but found, without actually reading the manuals, I wasn't able to get
it to do anything.
Old November 14th 05, 10:24 PM
MC
it to do anything.
Have you actually loaded the FIRs for where you are ?
Have you set your current lat/lon (or tried to connect a GPS) ?
PocketFMS does flight-plans, airspace info and a heap of other
stuff and even a cursory reading of the help-file will show
you what features are available and how to use them.
Old November 14th 05, 11:21 PM
Robert M. Gary
I"m sure the help file will help, I just haven't gotten there yet. I
set the FIR but didn't recognize the area because it didn't show me
airport names (just airspace). Again, I'm sure if I sit down with the
documentation I can get it to work. I use Flightsoft now for planning
and it works a bit more out-of-the-box, but may or may not be better.
-Robert
Old November 15th 05, 12:18 AM
On 14 Nov 2005 15:21:19 -0800, "Robert M. Gary"
-Robert
You really need to read the help file!
If you've set the FIR's have you downloaded the data from the
internet? i.e. Map (at each zoom level unless you register), Nav,
Elevation? That's how it's updated!
As for the PDA simply 'synchronise CE device' from the icon, via the
PDA cradle using Active Sync.
This prog has so many options you can't expect it to just work without
reading the basic help info. Lots of icons on the top & side of the
screen to select/deselect options.
The first thing to do is right click the mouse and 'search' for your
nearest airfield then click 'Plane Pos'. That puts the plane at the
centre of the screen in your area. If you don't the plane position
could well be in the sea or another FIR anywhere in the world.
You also need to check properties and ensure you set the 'Limit
PocketPC Memory storage to' xxx MB
Old November 15th 05, 10:47 AM
On Mon, 14 Nov 2005 19:15:20 -0600, Darrel Toepfer
Download all the data files, it takes awhile. And also that you have a
compatible GPS. PocketFMS doesn't work with my Garmin GPS III. Works
great with my Magellan 315...
I had a lot of trouble with an old Trimble Flightmate Pro (1993
database) but eventually got it to work. As long as you can get NMEA
sentences, at the right baud rate, with the right parameters selected
it should work.
Flight Planning Software Chris G. Piloting 22 July 4th 05 06:33 PM
[!] Russian Arms software sale Naval Aviation 0 December 18th 04 05:51 PM
Free Flight Planning Software Dean Wilkinson Piloting 20 September 25th 04 03:38 AM
Free Flight Planning Software Dean Wilkinson Products 0 September 18th 04 10:44 PM
Next: Aviation Map software Toks Desalu Piloting 5 May 24th 04 07:55 PM
